Which intake to use on 350 rebuild? - Chevelle Tech
 4Likes
post #1 of 18 (permalink) Old Jul 5th, 20, 4:25 PM Thread Starter
Do I toss the old edelbrock and use an original holley, an old winters, or a new aftermarket? I am considering a rebuild of my 350 which is in a 66 with th350.
I am thinking of installing a 200r4; but may stay with the current 350. Looking for around 400 hp & tq. What would be the advantages or drawbacks? Like installation issues, performance, cost, etc. Thanks
Jim_66SS is offline
post #2 of 18 (permalink) Old Jul 6th, 20, 10:27 AM
Mr Bill
Re: Which intake to use on 350 rebuild?
Which Edelbrock do you have ? What carb are you planning to use ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 18 (permalink) Old Jul 6th, 20, 10:55 AM Thread Starter
Current carb is a Edelbrock 1406; but I was thinking of using a holley 3140.
The intake is an Edelbrock from around 1997, I can't seem to find any other identification numbers or stamps.
Jim_66SS is offline
post #4 of 18 (permalink) Old Jul 6th, 20, 11:08 AM
For a mile street small block, I don't think it matters that much. Any aftermarket dual plane will be fine, and probably not more than 5-10 hp between them.
I would recommend staying away from the air-gap manifolds for a cruiser. Manifold heat is your friend if this is going to be mostly driven around at part throttle.
1966Chev likes this.
novadude is offline
post #5 of 18 (permalink) Old Jul 6th, 20, 11:11 AM Thread Starter
Would there be any intakes more prone to vacuum leaks or other issues?
Jim_66SS is offline
post #6 of 18 (permalink) Old Jul 6th, 20, 11:22 AM
Mr Bill
I have always had good luck with Edelbrock intakes as far as sealing and working good. If you are going to go with a Holley carb I would use something a little more modern unless you already have the 3140. I would probably use a 3310 or whatever the latest version is myself. The only thing I dont like about the Edelbrock is the hassle to rejet them if needed. The 1406 is only 600 cfm and might be on the edge if you are really planning on 400HP.
blue_69_malibu likes this.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 18 (permalink) Old Jul 6th, 20, 11:48 AM Thread Starter
Thanks, yes I have a 3140. Isn't the 3140 also a 600 cam?
Jim_66SS is offline
post #8 of 18 (permalink) Old Jul 6th, 20, 12:09 PM
Mr Bill
Not sure. My Holley master parts list only says it came on 396 engine. My 2005 Holley catalog does not list it anywhere either.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #9 of 18 (permalink) Old Jul 6th, 20, 1:27 PM Thread Starter
Yes it is original to the 66 396 auto. But it just an 4160 vacuum secondary holley from back in the day. Only difference in the 66 327 was the jets. 3140 used on auto 3139 o n manual differences being throttle plate. Same thermo choke set up on 327 and 396.
In fact I recently had the 3140 on my 350 small block swaping it for the edelbrock 4160 to see if the edelbrock carb was contributing to my engine problems.
Jim_66SS is offline
post #10 of 18 (permalink) Old Jul 6th, 20, 2:39 PM
I would use the Eddy RPM Performer Air Gap. Just a touch smaller than the RPM and should make good power on a 350.
pannetron likes this.
68Chevele is offline
post #11 of 18 (permalink) Old Jul 6th, 20, 6:29 PM
I've been very happy with my Performer RPM --NON-- Air Gap.
Years ago I had an old Performer 2101. That was a super torquey one, great for the street to 5000 rpms.
My non air gap will go to 6k no problem too.
My big block I'm building I'll use a Weiand Stealth.
First car was a 1969 El Camino. .....I miss it, great car.
Currently: 1967 Royal Plum Camaro
Arch Stanton is offline
post #12 of 18 (permalink) Old Jul 6th, 20, 6:49 PM
Use a regular RPM intake and a Holley 3310.
-Chuck Norris
BillK likes this.
blue_69_malibu is offline
post #13 of 18 (permalink) Old Jul 6th, 20, 8:29 PM Thread Starter
Do any of the edelbrock intakes accept the old style manual holley choke in the intake?
This is a photo of the current intake. It says edelbrock performer; but I don’t see anything else to identify it. Anyone know what it is. I think that has a provision for the choke in the intake.
Jim_66SS is offline
post #14 of 18 (permalink) Old Jul 6th, 20, 9:09 PM
Jim, I'd use the 3140 no problem.. If you want you can send it to me and I'll fix it up for you. that divorced choke deal is a pain to set up and get right. I'd change it over to an electric choke. You can use that manifold fine. This deal is exactly what it was made for.
Are you the same Jim from Mn I talked at the Phx GoodGuys show a couple years ago?
post #15 of 18 (permalink) Old Jul 6th, 20, 9:16 PM
Jim, here's a 3140 on ebay right now, just to give you idea what your carb might be worth. That's a really good carb, used on all kinds of performance 327s and 396s including Vettes, which is the price is so high.
https://www.ebay.com/itm/Holley-3140...-/170367587996
for the money he wants that carb should be re-colored. it's cosmetic but still, for $1K?
