7qt oil pan engine install? - Chevelle Tech
 5Likes
  • 1 Post By oldcutlass
  • 2 Post By BillK
  • 2 Post By bracketchev1221
post #1 of 11 (permalink) Old Jul 5th, 20, 12:04 AM Thread Starter
Long story short, I have a trans dapt 7qt oil pan I got off summit that says it will fit my ‘71. Attempted to install the motor original block with the original tranny connect and it was a couple inchs from clearance(the oil pan was hitting the frame... and the tranny was hitting the firewall scratching the fresh paint...)
Has anyone installed this combo? Or a similar pan with the same dimensions? How did it go? I feel like I’m doing something wrong but I’m not sure what it is!
Next steps is installing the motor without the oil pan then installing the oil pan once the motor/tranny is “in” as much as it can be with enough room to install the pan again.
Any tips!?
Chile is offline
post #2 of 11 (permalink) Old Jul 5th, 20, 12:40 AM
Re: 7qt oil pan engine install?
You need to install the engine and transmission separately if you can't get the car high enough to do it together. If its a BBC you will not get the oil pan on in the car.
lucifershammer likes this.
oldcutlass is offline
post #3 of 11 (permalink) Old Jul 5th, 20, 1:14 AM
Trying to put the pan on with the engine in the car without the gasket leaking is a major struggle.
That pan needs either the engine set straight down onto the mounts to clear the crossmember, with the trans already in place in the car or installed later....you won't get them both it together without possibly having the car off the ground high enough you can really drop the tail of the trans to get the bellhousing area far enough away from the trans tunnel to get enough angle to have the pan clear everything, and then lift the trans tail back up once the motor is close to right down on the mounts.
You do have the trans crossmember out, right??
Amazingly enough, the 6 qt rear sump race pan for the '62-67 Chevy II, with the clearance notch in the front section of the sump, actually fits the Chevelle chassis very well. The Chevy II pan tie rod centerlink notch helps clear the back edge of the Chevelle crossmember and brake line better then the un-notched 7qt race pan does.
Put the Chevy II pan on a buddy's '67 Elky.
Surprise, Surprise
Ericnova72 is offline
post #4 of 11 (permalink) Old Jul 5th, 20, 2:46 AM Thread Starter
It’s a 350sbc. Any tips on getting the tranny in there alone? Can’t use a cherry picker to go that far back.
Chile is offline
post #5 of 11 (permalink) Old Jul 5th, 20, 2:50 AM Thread Starter
I don’t have the trans cross member out. I should just install separate then. Would the gross member make a difference if installing both at the same time with the car on the ground?
Chile is offline
post #6 of 11 (permalink) Old Jul 5th, 20, 3:08 AM
Andreas
Hello.
I did the same conversion and it works.
But it's really tight on all corners.
Quite diagonally from above with the engine jack and under the Transmission with the jack.
Let the engine down slowly and lift it carefully at the Transmission Same time, then push it backwards - very, very tightly.
The oil pan should have been rounded at the front corners, then it would have been no problem.
Crossmember must out.
Watch out for the front brake line, don’t press ist flat...
little Video of my Chevelle Resto:
Andi is offline
post #7 of 11 (permalink) Old Jul 5th, 20, 4:13 AM
To get the engine and trans in as a unit, your only hope is with the trans crossmember out.
I've actually never pulled or installed the engine and trans together on any '60's, 7's, or 80's RWD Chevy without having the crossmember out. Only time the trans crossmember stays in is if the trans is also going to stay in...otherwise, that crossmember is out so you can drop the rear of the trans a good 12-18" as needed.
With the whole thing together and trying to keep the trans tail above the installed crossmember, the bellhousing area of the trans is going to run smack into the firewall before you get the engine any where near the mounts.....that's what you've just met up with, right?
post #8 of 11 (permalink) Old Jul 5th, 20, 1:15 PM Thread Starter
That’s correct! Now I need to touch up the paint. Rookie mistake on my part I guess.
Chile is offline
post #9 of 11 (permalink) Old Jul 5th, 20, 3:43 PM
Mr Bill
I have never pulled or installed an engine and trans together. To sketchy for me. Put the engine in and then the trans. Put the car up on jack stands and roll the trans under it on your floor jack. Done deal.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 11 (permalink) Old Jul 7th, 20, 2:39 PM
Rod
That 7qt. pan definitely complicates things. I know from personal experience. I also scratched fresh paint. I ALWAYS pull the trans crossmember, though.
Rmchevelle is offline
post #11 of 11 (permalink) Old Jul 7th, 20, 6:44 PM
Big oil pans don’t fit. Learned it the hard way. Put them in separate.
Ray
bracketchev1221 is offline
