1970 Chevelle 307 Reassembly location - Chevelle Tech
 3Likes
  • 1 Post By Ericnova72
  • 1 Post By spoffie1962
post #1 of 5 (permalink) Old Jun 29th, 20, 1:24 PM Thread Starter
Hello all,
I have torn down my 307 in my 1970 Chevelle. I am putting it back together now with vortec heads and intake. My car came factory with the 307 no air, no power steering, and no power brakes.
I bought all the pulleys and brackets from a member last fall to convert my car over to power steering with the option of adding AC later. I am putting everything back together and I am a little lost. My shop manual is a bit confusing and I am hoping someone out there can tell me how these brackets go so I can install my parts and break in my motor. Here are all the brackets and pulleys I have. I appreciate the help in advance.
ID:	631512   Click image for larger version
ID:	631514   Click image for larger version
ID:	631516   Click image for larger version
s1nemesis1s is offline
post #2 of 5 (permalink) Old Jun 29th, 20, 7:47 PM
Re: 1970 Chevelle 307 Reassembly location
Bracket you are holding in picture #3 is the power steering pump to waterpump leg bracket, it fits around the passenger side of the steering pump body while the upper section in picture #4 fastens to the bolt boss on the driver side water pump leg. Slotted hole goes to boss/stud on bottom back of steering pump
Bracket on the right in picture #5 bolts to the front face of the driver side of the steering pump, the slotted end swings past the front of the exhaust manifold and connects to a bracket there, which is the bracket in the center in Picture #5.
That bracket on the left pic #5 lower end bolts under at the motor mount to block bolts, at the upper end at the front exhaust manifold bolt, and the bolt currently sticking in the bracket faces the front of the car and is the one the slot in the other bracket slides on for belt adjustment.
Picture #2, small tubular bracket at the 5:30 o'clock spot is part of the alternator brackets set, not the power steering, the little tab on it bolts to the lug on the back of the alternator case and the tube section lines up with the long thru-bolt passage on the side of the alternator case to be a tube spacer for the long bolt to pass through that holds the alternator to the cylinder head.
s1nemesis1s likes this.
Ericnova72 is online now
post #3 of 5 (permalink) Old Jun 29th, 20, 10:14 PM Thread Starter
I sincerely appreciate you taking the time and effort to help me with this - THANK YOU!!!!
post #4 of 5 (permalink) Old Jun 30th, 20, 8:34 AM
Ericnova72 gave you a good description so here's some pictures to go along with that. I do have headers so the lower A/C bracket is left off (no issues with that BTW) but hopefully the pics help a little.
ID:	631604   Click image for larger version
ID:	631606   Click image for larger version
ID:	631608   Click image for larger version
ID:	631612   Click image for larger version
ID:	631614   Click image for larger version
123pugsy likes this.
spoffie1962 is offline
post #5 of 5 (permalink) Old Jun 30th, 20, 8:35 AM
One more-
If you need more detailed photos just let me know.
