Help with block ID - Chevelle Tech
 2Likes
  • 1 Post By Billdini
post #1 of 14 (permalink) Old Jun 4th, 20, 9:14 AM Thread Starter
Help with block ID
This is a 76 350 block from a truck. Does this plug just above the timing cover tell you anything about the block? 3970010 casting number.
Jim_66SS is offline
post #2 of 14 (permalink) Old Jun 4th, 20, 11:17 AM
Re: Help with block ID
I have that same plug on my 68 327 L79. What is your engine code in front of the passenger head, block pad
Here is what I found searching the web
"That's the 1/8" NPT hole with the square-head plug at 11:00, just above the timing cover, on all Flint V-8's; the machining process was different for the front oil gallery intersection between Flint and Tonawanda, so Tonawanda blocks didn't have the hole or the plug. That's a key issue on Corvettes, as all Corvette small-blocks came only from Flint V-8 (as did all Z/28 302's). Photo below." (sorry photo is missing from the original post.)
- John Hinkley"
GLHS60 likes this.
Billdini is offline
post #3 of 14 (permalink) Old Jun 4th, 20, 11:39 AM Thread Starter
- John Hinkley"
Not sure how that is helpful, just the plant Z for fremont and sequence number along with the V for Flint, where it was built, the date, and the suffix code for the application. TBK suffix, assembled in May of 76.
Jim_66SS is offline
post #4 of 14 (permalink) Old Jun 4th, 20, 12:32 PM
It is just a drilling that leads to the main oil galley in the block, the pipe plug was just the way the factory sealed it off after the drilling operation. It doesn't mean anything significant, basically it is just a potential point to either place an oil pressure gauge line, a lubrication line to oil a turbocharger, or a lube line to oil a air compressor for air brakes on big trucks.
Not a rarity or something that makes the block "special".
Ericnova72 is online now
post #5 of 14 (permalink) Old Jun 4th, 20, 3:15 PM
You asked what it was and I found the answer for you. I do not understand how that is not helpful. Am i missing something?
blue_69_malibu likes this.
Billdini is offline
post #6 of 14 (permalink) Old Jun 4th, 20, 5:16 PM
& Administrator
Sure it's not TKB - no TBK in 76
Mike is offline
post #7 of 14 (permalink) Old Jun 4th, 20, 5:28 PM Thread Starter
Yes TKB transposing error.
Jim_66SS is offline
post #8 of 14 (permalink) Old Jun 4th, 20, 5:32 PM Thread Starter
Didnít mean it the way you took it, sorry. I was looking for weather it might be a 2 or 4 bolt.
Jim_66SS is offline
post #9 of 14 (permalink) Old Jun 4th, 20, 6:34 PM
No way to tell with that casting number, I've had both.
Gary Adrian
Busted Knuckles is offline
post #10 of 14 (permalink) Old Jun 4th, 20, 6:45 PM
& Administrator
Here you go:
TKB 76 350 165 4B,AT TR
Mike is offline
post #11 of 14 (permalink) Old Jun 4th, 20, 8:52 PM
If the motor is an original, unmolested core, and has an 8 in balancer, then chances are it is a 4-bolt. Particularly as it is a truck motor. Otherwise drop the pan if you can!
chrisstandring is offline
post #12 of 14 (permalink) Old Jun 4th, 20, 10:00 PM
Thatís why I mentioned my 327 has it although my 68 is a large journal crank like the 350. All 327ís are 2 bolt. I was wondering why my block had it but thought it was just an old block thing until your post.
Billdini is offline
post #13 of 14 (permalink) Old Jun 5th, 20, 12:02 PM
& Administrator
Or stick a USB type camera into the drain plug bung and have a look-see.
Mike is offline
post #14 of 14 (permalink) Old Jun 5th, 20, 2:56 PM Thread Starter
Yes appears unmolested, except for head, intake, and possibly cam change. And big 8" balancer.
Jim_66SS is offline
