Valve train noise - Chevelle Tech
post #1 of 8 (permalink) Old Jun 2nd, 20, 9:44 AM Thread Starter
Valve train noise
69 Chevelle
468ci
Comp cams solid roller cam and lifters
Harlem Sharp roller rockers
10:5-1
Any idea's or suggestions?
https://www.dropbox.com/s/ztdyyqtaeh..._0294.MOV?dl=0
reddog003 is offline
post #2 of 8 (permalink) Old Jun 2nd, 20, 10:28 AM
Re: Valve train noise
Originally Posted by reddog003 View Post
69 Chevelle
468ci
10:5-1
Could be as simple as a rocker needing adjustment or even a blown exhaust gasket
moncam is offline
post #3 of 8 (permalink) Old Jun 2nd, 20, 10:33 AM Thread Starter
Thanks for the suggestions. Just checked valve lash and they are in spec. Compression tested all cylinders and all are within 10 percent.
post #4 of 8 (permalink) Old Jun 2nd, 20, 11:22 AM
Vince
Doesnít sound bad from here. What is the recommended lash? Maybe tighten it up by a couple of .000ís to see if the noise is reduced.
But that sounds like my hydraulic rollered 502.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #5 of 8 (permalink) Old Jun 2nd, 20, 11:39 AM Thread Starter
Thank you for your suggestion. I will re check today.
The hot lash is set .016 intake and .018 exhaust.
post #6 of 8 (permalink) Old Jun 2nd, 20, 7:48 PM
Does it have a stud girdle? If so make sure it has enough clearance for rockers to open and close.
Did you pull rockers and make sure they are not hitting retainers on bottom of rocker body? Pushrods wrong length and it can happen..... pull valve covers and start it, some roller rockers tend to hit valve covers and you might need to clearance them in a few spots.
Kirk is offline
post #7 of 8 (permalink) Old Jun 2nd, 20, 8:05 PM
Zach
Here's a video of mine... I've tried everything. I've been driving it without any issues.
https://youtu.be/zW01JsUiTH8
Sent from my SM-N975U using Tapatalk
OneBadA$$68SS is offline
post #8 of 8 (permalink) Old Jun 2nd, 20, 9:39 PM
Are you sure the valve springs aren't hitting coil bind? I reckon you may have checked all the geometries by now. But if not, like Kirk says, pop a cover and roll the motor over slowly and check the valves at full lift. Each one. Then do the other side. Unless you've double checked all that already.
You are using the EO-IC valve lash method, yes?
Mechanical fuel pump?
