Pump to carb gas line problem - Chevelle Tech
 7Likes
  • 1 Post By hessz24
  • 2 Post By jeff swisher
  • 3 Post By Ericnova72
  • 1 Post By Tom Mobley
post #1 of 11 (permalink) Old May 30th, 20, 11:55 AM Thread Starter
Want to use the Edelbrock setup, but the filter is right up next to the runner on my old intake. The water hose nipple is in the way too. Suggestion? I think a spacer that would move the banjo fitting out a bit might work, but if I find one (maybe a fat washer?) would it leak? Any suggestions would be appreciated. Sorry about sideways pic. Don't know how to fix that. Thanks.
Notes is offline
post #2 of 11 (permalink) Old May 30th, 20, 12:23 PM
Can the filter be relocated? Can you plug that water port and use another one?
Kirk's67SS likes this.
hessz24 is offline
post #3 of 11 (permalink) Old May 30th, 20, 12:38 PM
jeff
Re: Pump to carb gas line problem
That fuel line looks like a flexible line.
You could make a bracket to hold it away from the fitting and use the front intake bolt to secure the bracket. Longer intake bolt will be needed.
Or how about cutting that fuel line and moving the filter somewhere else.
Kirk's67SS and blue_69_malibu like this.
jeff swisher is offline
post #4 of 11 (permalink) Old May 30th, 20, 2:05 PM Thread Starter
Thanks for the suggestions. Line from carb to filter is solid. Obviously, so is the filter. Can't move either out from the intake runner or water fitting. (unless I use a spacer at the banjo fitting)
End of the solid line is female. Both ends of the filter are male. One end of the black flexible line is female to fit the filter. Other end is male to fit in the pump. Can't think of a way to put the filter anyplace but where it was designed to go.
Notes is offline
post #5 of 11 (permalink) Old May 30th, 20, 3:06 PM
Greg.
I would never ever have a Fuel Filter on Top of a Intake
there it is just asking for Vapor Lock
and the Engine falling Flat at the Top End of the 1/4 or anywhere at WOT
Here is a Pic where my Fuel Filter and Regulator is Located on the PassengerSide Inside Fender
and where I start the Fuel Line Insulation to the Carb
and a Pic of the Insulated Fuel Line from it to the Carb
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #6 of 11 (permalink) Old May 30th, 20, 3:15 PM
Get a tubing bender and bend the hard line on the carb about 1-1/2" below the banjo fitting to swing the lower half of the line and filter out toward the valvecover. Won't take much, not even a 15 bend, something like 7-10.
Ericnova72 is online now
post #7 of 11 (permalink) Old May 30th, 20, 4:52 PM
I agree about getting it away from the intake/heat. At least In front of or higher up. Similar to what Jeff is suggesting, maybe another AN hose 4"-6" between the filter and the hard line to the carb putting the filter exit directly in front of the Intake? It would take a few more movements and If you have the hood clearance, put a 1/2" spacer under the carb? Mine is in a similar location but I have a 1" spacer so the filter sits above everything.
cage2592 is offline
post #8 of 11 (permalink) Old May 30th, 20, 9:23 PM Thread Starter
Thanks for all the suggestions. I'm going to try a spacer under the carb and see how that works. Thanks again
Notes is offline
post #9 of 11 (permalink) Old May 30th, 20, 10:16 PM
leo
A thicker washer, a copper or brass one might do the trick, good luck!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #10 of 11 (permalink) Old May 31st, 20, 9:14 AM
Just be careful with the spacer and height as you may induce some run issues which will require you to re-tune. Shouldn't be much. Usually 1/2" should be fine. Putting a 1" on my wife's 68 Camaro needed a slight Mixture screw tune and idle adjustment.
cage2592 is offline
post #11 of 11 (permalink) Old May 31st, 20, 10:47 PM
be careful about putting a spacer under the carb. hood clearance is an issue with these cars. if you do put a spaver under the carb, don't just slam the hood. many guys have a "learning opportunity" after they saw the carb stud sized bump in the hood after doing that.
blue_69_malibu likes this.
