Can low vacuum effect idle circuit on Q Jet - Chevelle Tech
 9Likes
post #1 of 22 (permalink) Old May 30th, 20, 10:19 AM Thread Starter
Stan
New cam in my small block and ended up with 8-9 in of vacuum. Everything seems OK but cannot get sustainable idle below 1100 rpm. Does a Q Jet require a minimum amount of vacuum for the idle circuit to work properly? If so, can a Q Jet be modified to work with low vacuum?
stanski is offline
post #2 of 22 (permalink) Old May 30th, 20, 1:58 PM
Re: Can low vacuum effect idle circuit on Q Jet
Complete ignition degrees needed for all parameters, and cam degree specs (NOT lift), especially intake closing point, and overall compression ratio, PLEASE.
Very end of the process, not usually needed, but, if the cam is seriously duration, valve timing big, it might need bleed holes in the primary throttle plates, VERY, VERY RARE.
Dave Ray is offline
post #3 of 22 (permalink) Old May 30th, 20, 3:37 PM Thread Starter
Stan
Lift .310/.325 Duration 225/235
Timing at 12 degrees right now
Compression 10:1
stanski is offline
post #4 of 22 (permalink) Old May 30th, 20, 4:08 PM
You're gonna have to open up the Idle restrictions & down channel restriction & maybe the Idle air bypass.
You probably have the mixture screws out so they are just about to fall out?
A little more timing too.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #5 of 22 (permalink) Old May 30th, 20, 8:51 PM
Compression 10:1
This tells me virtually NOTHING of how the timing is set up, nor the overall duration of the cam, let alone the closing degree of the intake valve. Hard to get the right info out, when there is nothing to go by.
Now:
INITIAL timing: 12 deg/BTDC
Vacuum advance degrees added by full manifold vacuum, unknown
Full IDLE timing, unknown
Mechanical advance curve, unknown
TOTAL initial and mechanical timing, unknown
Cam overall degrees, unknown
Cam degrees @ .050, 225/235
Lift: not important
Intake valve closing degrees, unknown
Lobe centers, unknown
Engine idle speed, way too high
Info would help.
Dave Ray is offline
post #6 of 22 (permalink) Old May 30th, 20, 9:07 PM
What Dave said. and 12 degrees is not going to be enough for a cam like that. You need to be looking at about 20 or so. try that first, it will speed up the idle and allow the the throttle blade angle to be returned to more normal position. try hooking the vacuum advance to manifold vac. it may help.
The idle feed restrictions can be drilled but it takes special extra long .038 or .039 drill. not many have these.
hydro462 likes this.
post #7 of 22 (permalink) Old May 30th, 20, 9:27 PM
Should ask too what is the carb from, number.
77 Monte
post #8 of 22 (permalink) Old May 31st, 20, 7:09 AM
Your going to have to raise the initial timing. I had to run straight timing on a few cars to get them to idle okay. If you have a vacuum booster you will have to get a pump, hydro boost or convert to manual.. Also you can change the brake pedal feel if you move the rod to the upper hole (6:1) manual ratio..
hydro462 is offline
post #9 of 22 (permalink) Old May 31st, 20, 7:33 AM
225* @ .050 isn't all that big of a cam. You should have more vacuum than that. You sure you don't have a vacuum leak?
427L88 likes this.
nitrofox is online now
post #10 of 22 (permalink) Old May 31st, 20, 8:22 AM
Keep in mind y'all, @ 8-9" Hg, the power piston is likely raised a bit by the stock spring, and increasing the surface area of the primary jet. QUESTION: if so, would Stan be seeing dripping fuel from the primary boosters @ idle? Or only if the pri throttle plates are open too far?
Alan F and 71350SS like this.
post #11 of 22 (permalink) Old May 31st, 20, 9:18 AM
Power valve wouldn't make the boosters drip, but opening the throttle too far will or too high fuel level.
427L88 likes this.
77 Monte
post #12 of 22 (permalink) Old May 31st, 20, 12:26 PM
The @.050 numbers are not a good indicator of how radical, or not a cam is. It all depends on the ramps on the lobes past the .050. Fast opening, more degrees under curve, less engine vacuum, higher overall degrees number. Slower ramps, less overall duration, better vacuum, more sedate, easier to control with timing and carb.
So, once again, what are the numbers we asked for, so we can help you accurately?
Dave Ray is offline
post #13 of 22 (permalink) Old May 31st, 20, 12:46 PM
Gary
First thing I would do is get the timing up to 18 220 degrees or so then drop the idle speed. Keep it high enough where it will idle. Once it's warmed up take your hand and gradually choke the primary side of the carburetor a little at a time and see what this does to your idle speed. If the RPM Rises its lean. If it raises much more than 50 you need to work on the idle circuit. Have you tried to adjust the mixture screws?
gnicholson is offline
post #14 of 22 (permalink) Old May 31st, 20, 1:17 PM
Here's some things I did years go when I ran Q-jets. First put your cam on a 114 lca and that will help with vacuum. Second use a spring from an ink pen (might need several for the right one) but out flat out works with big cams. Third, if all else fails but a new Q-jet form Jet performance slap it on and enjoy the ride.
68Chevele is offline
post #15 of 22 (permalink) Old May 31st, 20, 1:48 PM Thread Starter
Stan
Carb # is 1708224
stanski is offline
