in
this forum
in
the entire site
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Chevelle Mechanical
Engine
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 835
Go to page
Go
835
G
Sticky
SBC Stepped Nose Cam in Early Block?
GOSFAST
Jul 14, 2016
41K
Sep 13, 2020
by
Racing
G
Sticky
1966, 67, 68, 69, 70 Chevelle 396 Oil Pan Versus 1967, 68, 69, 70 Camaro 396 Oil Pan Indentification
Gary 396
Jun 30, 2013
7
8K
Jul 1, 2013
by
DaleM
B
Sticky
Adding a PCV vacuum port to Holley carbs
BillyGman
Nov 6, 2010
14
33K
May 26, 2013
by
BillyGman
Need recommendaitons for hydraulic roller lifters for a BBC build
Busted Knuckles
1d ago
20
447
1h ago
by
72SS454Chevelle
G
Gasket for gm aluminum heads
goodshow1923
5h ago
9
133
3h ago
by
goodshow1923
SB400 HEADS
pappydave
9h ago
11
207
3h ago
by
mrpaticular
7
GMPP specs 26* total timing for ZZ454 Crate Engine????
70 SS 454
Sep 3, 2009
11
13K
4h ago
by
Kenmcfetridge
M
oil filters
magicrat56
3d ago
28
739
4h ago
by
schovil69
Any reason NOT to use a gen V big block?
Squaredriver
4d ago
23
727
11h ago
by
DZAUTO
Low oil pessure after oil change
NorthPlainsDrifter
Feb 24, 2024
2K
1d ago
by
cozmacozmy
T
Sbc 400 on 71 chevelle pvc venting question
Toolman1978
1d ago
1
128
1d ago
by
396325
G
Dual flow adjustable pcv valve
GM man
2d ago
22
593
1d ago
by
richiecat4223
Engine Pre ignition?
jjjaffo
4d ago
26
460
1d ago
by
mrpaticular
A
'65 Chevelle Malibu 4 Door 402/M20 Project
abarnett
Apr 27, 2023
79
7K
3d ago
by
abarnett
New ZZ454/440 crate engine burns 1qt oil per 800 miles
Peteyk
Aug 25, 2023
3K
4d ago
by
Spitfire7
J
Incomplete markings on crankshaft. Any opinions?
jsm172
Mar 11, 2024
5
253
4d ago
by
David Bates
B
Second piece of dip stick tube.
Bart3500
6d ago
14
303
4d ago
by
BillK
Pullies
Singer gazelle
Feb 28, 2024
8
461
5d ago
by
Singer gazelle
Where did my oil go?
Roadrunner54
Mar 10, 2024
28
1K
5d ago
by
mrpaticular
J
Oil leak around spark plug
JamesH
5d ago
5d ago
by
mrpaticular
G
Lokar throttle cable in 66
GM man
Mar 7, 2024
9
376
6d ago
by
72LS3Z27
1970 Chevelle 454
Cocchi5
Mar 11, 2024
9
398
6d ago
by
GTO44
Running good one day bad the next-Vacuum? Distributor? Or?
64Elc
Mar 7, 2024
923
7d ago
by
64Elc
Center link hits the oil pan
GEBackbone
Oct 21, 2021
24
6K
Mar 12, 2024
by
72LS3Z27
Tall deck 454..
GLHS60
Aug 7, 2015
Poll
96
31K
Mar 12, 2024
by
The_Foose
SB rebuild tips and advise wanted
72soft-top
Mar 8, 2024
5
231
Mar 11, 2024
by
72soft-top
B
High or Low torque Delco Remy starter for 327?
Bronze68
Mar 10, 2024
4
312
Mar 11, 2024
by
LeoP
J
454 compression ratio questions (please help!)
JohnBoy
Jan 15, 2007
27
50K
Mar 11, 2024
by
Busted Knuckles
B
HEI adjustments in BBC
bornazen
Nov 7, 2010
5
2K
Mar 11, 2024
by
temp2c
B
Decisions-Decisions-decisions
BigAve
Mar 7, 2024
24
799
Mar 9, 2024
by
mrpaticular
S
396 crank grind ?
slowmo55ss
Feb 1, 2024
16
753
Mar 8, 2024
by
Busted Knuckles
67 Big Block with FACTORY PS and Headers
BlueSS454
Mar 8, 2024
6
317
Mar 8, 2024
by
magicrat56
J
Need direction/help from the engine builders on this forum
jsm172
Mar 8, 2024
6
378
Mar 8, 2024
by
Bob Tiley
J
Which Intake will fit
Jimmyc33030
Mar 7, 2024
14
468
Mar 8, 2024
by
Jimmyc33030
C
SBC vs BBC fuel pump identification
chevygod
Feb 28, 2024
11
562
Mar 7, 2024
by
chevygod
L
049 heads 396
Ledzep
Mar 6, 2024
Redirect
N/A
V
Cam and converter combo again again
Volvo240GLT
Mar 5, 2024
Mar 6, 2024
by
Jebchevelle
Solid roller lifters on a Hyd roller cam
68Chevele
Mar 6, 2024
Mar 6, 2024
by
bracketchev1221
1
1 of 835
Go to page
Go
835
Engine
294.7K
posts
88.8M
views
General Engine Discussion.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Philip
Top Contributors this Month
View All
mrpaticular
richiecat4223
B
BillK
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
Chevelle Mechanical
