Gen 5 454... what retro fit hyd roller lifters? - Chevelle Tech
 3Likes
  • 1 Post By BillK
  • 1 Post By Busted Knuckles
post #1 of 14 (permalink) Old Apr 20th, 20, 5:21 PM Thread Starter
Been searching online, not finding anything specific. Some even say for 87 and older blocks only.
Basically, it is a 94 dated block - ATK short block. AFR 265s with hyd roller springs. GMPP ZZ502 HO camshaft. I was going to buy Howard's, but started reading several bad reviews about them coming apart. Then there was the Morel debacle a few years back...
Thanks in advance
1972 SS 454 Chevelle - 468/M21/3.73
1969 Malibu L48/M20/3.31 -> L72 swap
1968 Malibu 307/PG -> LQ9/80E swap
Originally Posted by 69-CHVL View Post
How do you retire from something you rarely do?
Its like a welfare reciepiant saying there done working...
carpoor is offline
post #2 of 14 (permalink) Old Apr 20th, 20, 5:28 PM
Re: Gen 5 454... what retro fit hyd roller lifters?
If you have a gen5 BB,you dont need retro rollers,just rollers.
Gen 5 blocks were from 1991 til 1995.
Gen 6 started 1996,mark 4s require retro rollerts if you want them.The last mark 4 year was 1990.
Check your casting numbers over at mortec.com
Also,I was told by a Summitracing techy that Sealed Power was the manufacturer for the GM rollers of those years.
EDIT-Just reread your post.Did you not mean to say retro?
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #3 of 14 (permalink) Old Apr 20th, 20, 5:56 PM Thread Starter
Yes. This block originally had a hyd flat tappet cam. It is not set up for the intake "spider" to retain the non link bar style lifters. It looks very much like a Mark IV in the lifter valley.
These Melling brand lifters came up in my search #BB817RF16 & Lunati #72331-16
carpoor is offline
post #4 of 14 (permalink) Old Apr 20th, 20, 7:28 PM
Could you post the casting numbers of that block?
Project-
72LS3Z27 is offline
post #5 of 14 (permalink) Old Apr 20th, 20, 7:58 PM
Thanks in advance
If you looking for a quiet lifter that does not matter what you run for oil and no special adjustment trying to get rid of the noise, Go with the Johnson lifters. So far I have not had one complaint except they are quiet. LOL
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
post #6 of 14 (permalink) Old Apr 20th, 20, 9:46 PM
Mr Bill
Brian,
I have never had a problem using Comp Cams lifters in the past. Never had a noisy set and never had any failures. Put two sets in a pair of 502 Mercruisers 2 years ago for my cousins boat and they are still fine.
LeoP likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 14 (permalink) Old Apr 20th, 20, 10:08 PM
Rock auto sells hyd retro fit hyd lifter pretty cheap.
68Chevele is offline
post #8 of 14 (permalink) Old Apr 21st, 20, 7:28 AM
Gen 5 uses the same lifters as Mark IV. The factory rollers with tall lifter bores started with the Gen 6.
72LS3Z27 likes this.
Gary Adrian
Busted Knuckles is online now
post #9 of 14 (permalink) Old Apr 21st, 20, 9:03 AM
I honestly thought gen5s had them like the 6s.Although Ive never had a gen 5.Thanks for the clarification.
Project-
72LS3Z27 is offline
post #10 of 14 (permalink) Old Apr 21st, 20, 11:11 AM
^ no problem. I'm a Gen 6 hoarder. And a SBC 400 block hoarder. And a project hoarder.
One man's old junk is another's treasure, I've done considerably better than the stock market even though SWMBO (She Who Must Be Obeyed) doesn't put much stock in it
LeoP likes this.
Gary Adrian
post #11 of 14 (permalink) Old Apr 21st, 20, 12:14 PM
Marcus
Thanks in advance
I have used Comp cams both their standard and short travel, howard 91161(they are gaterman same as trickflow TFS-21400005) howard 91167, trickflow TFS-21400005 and several sets of Morel 4603. All except one set of the howard 91167 has and are still working excellent the Morel 4603s are little noisy cold.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #12 of 14 (permalink) Old Apr 21st, 20, 12:18 PM
Marcus
https://www.rockauto.com/en/parts/en...ve+lifter,5548
This?^^^^^^
Have you tried them? Price seems to good to be quality?
post #13 of 14 (permalink) Old Jun 28th, 20, 4:00 PM Thread Starter
Ended up with the Lunati lifters, have not installed... bouncing between several projects.
carpoor is offline
post #14 of 14 (permalink) Old Jul 1st, 20, 10:25 AM
Marcus
ended up with the lunati lifters, have not installed... Bouncing between several projects.
72331-16?
