Valvetrain noise won't go away, please help - Page 7 - Chevelle Tech
 28Likes
post #91 of 106 (permalink) Old Apr 22nd, 20, 7:31 PM
Re: Valvetrain noise won't go away, please help
I installed 7/16 pushrods in mine. Could not find adjustable guide plates for 7/16. Went thru a ton of plates till I got all centered. Amazing how different plates can be between manufacturers.
64 Chevelle 496
StevenS is offline
post #92 of 106 (permalink) Old Apr 22nd, 20, 8:02 PM Thread Starter
Zach
Just hope this solves my noise so I don't have to pull the heads...
Sent from my SM-N975U using Tapatalk
OneBadA$$68SS is online now
post #93 of 106 (permalink) Old Apr 23rd, 20, 12:44 PM
I hope so too. I have broken guide plates after changing cams, and not right away either.......and it's a real concern when your 40 miles from home. I have used comp cams, Manley and oem too.
IT will take some time to get the adjustment correct with the adjustable guide plates, make sure you rotate the motor checking for clearance every pushrod and rocker . And once you get them set you might want to have them welded so they don't loosen up on you later
Kirk is offline
post #94 of 106 (permalink) Old Apr 23rd, 20, 9:28 PM
ptu
Barry
Comp cams extreme energy cams are noisy like this. Do an online search about this.
After looking at the picture, your rocker arms may be hitting the outside of the valve spring retainer. Pushrods may be too short.
ptu is offline
post #95 of 106 (permalink) Old Apr 26th, 20, 11:14 AM Thread Starter
Zach
Ok, update as of yesterday...noise got better until after I drove it about 2 miles. It then sounded similar to before but I believe it maybe be a loose valve adjustment, you could hear it from around cylinder #8 which is new. Here is a video before I took it for a drive..how's it sound to you?
https://youtu.be/zW01JsUiTH8
post #96 of 106 (permalink) Old Apr 26th, 20, 12:22 PM
mike
You need to address the rocker alignment, or did you already? side to side as well as contact pattern on the stem, on all of them.
slowmo55ss is online now
post #97 of 106 (permalink) Old Apr 26th, 20, 12:23 PM Thread Starter
Zach
Originally Posted by slowmo55ss View Post
You need to address the rocker alignment, side to side as well as contact pattern on the stem, on all of them.
I did that, new guide plates are on, perfect side to side movement as well as rocker sweep. Took my time and made sure.
post #98 of 106 (permalink) Old Apr 26th, 20, 12:25 PM
mike
OK, I edited my last post.
post #99 of 106 (permalink) Old Apr 26th, 20, 12:31 PM
Maybe is my computer but its sound way better
64 Chevelle 496
StevenS is offline
post #100 of 106 (permalink) Old Apr 26th, 20, 12:34 PM Thread Starter
Zach
I agree it sounds a lot better in that video until after I drove it, then it went back to a similar noise from before BUT I think I could hear a clacking near cylinder 8.. readjusting valves again today
post #101 of 106 (permalink) Old Apr 26th, 20, 12:51 PM
mike
Still noisy imo. Not related, but I thought I heard some spark knock on that second throttle blip?
post #102 of 106 (permalink) Old Apr 26th, 20, 3:57 PM
So did you go back and adjust them using the EOIC method ?
Did any of the settings change from last time ?
Are all set screws and dame height
Making note if all the set screws End up at same height is important if you have some not the same then those are the ones that need A closer look or relash
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #103 of 106 (permalink) Old Apr 26th, 20, 4:31 PM Thread Starter
Zach
I just readjust them with the EOIC, and went almost a full turn, .045 preload this time.
post #104 of 106 (permalink) Old Apr 26th, 20, 4:33 PM Thread Starter
Zach
Is 10w30 possibly too light of an oil? Maybe a heavier oil will help?
post #105 of 106 (permalink) Old Apr 26th, 20, 4:56 PM
rick
My Howards Max Effort/Gaterman hyd roller lifters call for 10W30 oil, have you checked valve guide to retainer clearance?
shovelrick is offline
