Valvetrain noise won't go away, please help - Page 5 - Chevelle Tech
 28Likes
post #61 of 106 (permalink) Old Apr 22nd, 20, 12:43 PM
Adjusting running is OK
But “if “you have tight Piston to Valve clearance you run the risk of tagging a piston if you tighten down too fast go slow thats why on an engine with big cam EOIC is preferred and more precise IMO. I would try 1 full turn if they are std travel lifters
How much time/ miles in this engine with these lifters
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #62 of 106 (permalink) Old Apr 22nd, 20, 12:50 PM Thread Starter
Zach
Re: Valvetrain noise won't go away, please help
@CDN SS
Gonna do EOIC, one turn on them. Doing it now, we'll see how it goes.
Sent from my SM-N975U using Tapatalk
OneBadA$$68SS is offline
post #63 of 106 (permalink) Old Apr 22nd, 20, 1:02 PM
I see where you say travel is .093 thats shorter than I thought So i see why they say .035 So no more than I turn
I hope this not the valve kissing the piston because flycut not radiused enough
shovelrick likes this.
CDN SS is offline
post #64 of 106 (permalink) Old Apr 22nd, 20, 1:18 PM
rick
Zach I only read the beginning of the tread but have you looked in a plug hole with a bore scope to see if any marks are on the piston from valve contact? I had a P/V sound and it was from the shop that put bigger valves in my heads didn't cut the guides down even though I left my cam card with them, top spring retainer hitting the valve stem seals & guides, sounded just like P to V hitting BTDT before, pulled the heads and went to a better auto machine shop
shovelrick is offline
post #65 of 106 (permalink) Old Apr 22nd, 20, 1:45 PM
Shovelrick makes a good point
If this readj does not change anything. Then time to look in cylinder at piston Your sound is so consistant tells me ots either a lash procedure or some interference of parts
CDN SS is offline
post #66 of 106 (permalink) Old Apr 22nd, 20, 1:46 PM Thread Starter
Zach
Just noticed this while adjusting
post #67 of 106 (permalink) Old Apr 22nd, 20, 1:53 PM
How did you set your rocker geometry ? Hopefully using the “ midlift” method
CDN SS is offline
post #68 of 106 (permalink) Old Apr 22nd, 20, 1:57 PM Thread Starter
Zach
I did.
post #69 of 106 (permalink) Old Apr 22nd, 20, 2:00 PM
What does it look like with valve open Those are all closed is lash backed off on thst pic
CDN SS is offline
post #70 of 106 (permalink) Old Apr 22nd, 20, 2:10 PM Thread Starter
Zach
Adjusted at max lift..
@CDN SS
post #71 of 106 (permalink) Old Apr 22nd, 20, 2:12 PM
It appears that your "preload" is being set with the rocker body, not the roller tip! The one rocker in the center looks like it has been hitting the valve on the bottom side, unless that's something else.
The guide plates are wrong, not centering rocker on valve.
Might need adjustable guide plates
Kirk is offline
post #72 of 106 (permalink) Old Apr 22nd, 20, 2:15 PM
Hmm is rocker hitting retainer too.
CDN SS is offline
post #73 of 106 (permalink) Old Apr 22nd, 20, 2:19 PM Thread Starter
Zach
Rockers don't appear to be hitting retainers. Is this bad machining or do I need adjustable guide plates?
post #74 of 106 (permalink) Old Apr 22nd, 20, 2:19 PM
Yep sure points to guideplates need alignment
Thats better than valve hitting piston
CDN SS is offline
post #75 of 106 (permalink) Old Apr 22nd, 20, 2:23 PM
Is this rocker damaged, or some foreign material on it?
Kirk is offline
