Valvetrain noise won't go away, please help - Page 4 - Chevelle Tech
 28Likes
post #46 of 106 (permalink) Old Apr 21st, 20, 4:13 AM
Re: Valvetrain noise won't go away, please help
Originally Posted by OneBadA$$68SS View Post
Long story short, I was having a clacking noise in the valvetrain which you'll hear in the video, so I replaced the lifters with Johnson hydraulic roller lifters, custom pushrods and new springs to match and the noise is still there. I adjusted the valves multiple times and multiple different ways. What else could this noise be? Could I have a bad roller rocker? I'm losing my mind over this...
https://youtu.be/Yv6uLVnm7RM
Sent from my SM-N975U using Tapatalk
I dont know what the issue is but I have an inline six (Ford) with the same issue after rebuild. Different animal (engine wise) but the exact same sound. Hope you figure it out.
65cayne is offline
post #47 of 106 (permalink) Old Apr 21st, 20, 4:52 AM
65 cayne.I built a 300 6 once and the pushrod socket in the rocker arms were so worn they would not allow oil to come out of the puhrod....sounds crazy but true story.light relief in the socket with a dremel to prove theory and all was well...replaced rocker arms and never took the cover off again....off topic but....
Andrew Mattson is online now
post #48 of 106 (permalink) Old Apr 21st, 20, 11:10 AM
Bill, did you get back home to Win or are you stuck in AZ??
Hi Bill nope been back home for about 3 weeks all good
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #49 of 106 (permalink) Old Apr 21st, 20, 6:29 PM Thread Starter
Zach
Same noise, I don't know where to go from here.
https://youtu.be/fAl1bKJKAgw
OneBadA$$68SS is online now
post #50 of 106 (permalink) Old Apr 21st, 20, 6:56 PM
Now I dont hear that one little "ball peen" sound. I best go back and listen , but the prior video I thought I heard one very distinct sound. that sounds like a roller valvetrain more. But it is loud.
post #51 of 106 (permalink) Old Apr 21st, 20, 7:00 PM Thread Starter
Zach
I agree. I adjusted them while running, backed them off till a clack, turned in until it stops, then half turn. Should I be going more?
post #52 of 106 (permalink) Old Apr 21st, 20, 7:51 PM
Sounds the same as my solid roller.
64 Chevelle 496
StevenS is offline
post #53 of 106 (permalink) Old Apr 21st, 20, 8:15 PM
I still think you should adjust with EOIC Running is ok for small cam but you need to get right on base circle and find zero lash from there
I know some will set preload on Race lifters for first time before intake goes on so they can see the plunger Is right up and not sticking ir collapsing with no pushrod play. Then preload 1 turn Or whatever then note where the adjuster set screw ends up So in the future if they redo preload the set screw Setting should be the same
When I see I see a rocker set screw end up different I know something is wrong
I would call Johnson and find out plunger travel and see if you can lash tighter
Race lifters have very tight tolerances between body and plunger sometimes it takes some miles to Quiet down but your noise is excessive but since it seems to be consistent tells me its in the way lifters preloaded If was just one or two clacking then thats different
I feel your pain I been thru this with 1000.00 plus Race lifters ( another brand)
CDN SS is offline
post #54 of 106 (permalink) Old Apr 21st, 20, 8:25 PM
mike
Get you a good heavy glove and apply sideways pressure on each rocker with steady throttle, you should be able to find the noisy ones. Or get a heater hose and hold up to your ear.
hydro462 and Kirk like this.
slowmo55ss is offline
post #55 of 106 (permalink) Old Apr 21st, 20, 8:37 PM
bbm
Did you make sure pushrods are not "bottoming out" in the guide plate? Also Short travel lifters are usually a little noisy.
427L88 likes this.
bbm is offline
post #56 of 106 (permalink) Old Apr 21st, 20, 8:48 PM Thread Starter
Zach
The suggested preload on the box is .035 +/- .010. the total travel is .093.
post #57 of 106 (permalink) Old Apr 21st, 20, 10:43 PM
I like to use a wooden broom handle against my ear, you can put other end on header tube or intake port for each cylinder......the noisemakers will be obvious
71350SS likes this.
Kirk is offline
post #58 of 106 (permalink) Old Apr 22nd, 20, 10:30 AM
start with the intake rockers, with it running tighten the rocker until it kills that cylinder then back off as little as needed, I'm still interested in the oil pressure
pbcbob is offline
post #59 of 106 (permalink) Old Apr 22nd, 20, 10:46 AM
Sorry Zach, my experience has been with solid lifters, feeler gauges and utter precision. I had a pro build my 467, he set up the HR valvetrain, and I hope to not have to check it for some time.
My "stethescope" is still 2.5' of 5/16" fuel line. Any form of "unidirectional mike" helps a ton to isolate.
Zach you DO have that brass-tipped fuel pump pushrod if mech pump? I bought two ( spare) from Straub Tech upon instructions from Vortechpro.
post #60 of 106 (permalink) Old Apr 22nd, 20, 11:14 AM Thread Starter
Zach
@427L88
Running an electric fuel pump
427L88 likes this.
