Bouncing vacuum at idle - Chevelle Tech
 3Likes
post #1 of 26 (permalink) Old Apr 6th, 20, 2:47 PM Thread Starter
Hi all,
Sbc400 with standard iron heads
When i connect my vacuum gauge to my full vacuum port on the carb i get irratic vacuum readings between 13-16Hg.
I already put in new sparkplug + cables.
Last autumn I let a mechanic adjusted the valve lash, some where off a bit but before and after the adjustments still the same readings. The fluctuation is very rapidly.
I also checked compression all are between 7,5 and 8. I guess that on the low side but at least all the same.
I have no leak from heads to intake and from intake to carb. I sprayed a lot of breakcleaner onto the seals but no response on idle rpm
What could be the cause? And what can i check?
Ps. I run 22deg advance at idle with connected vacuum advance (dont know if thats relevant for now)
Bart Fransen is offline
post #2 of 26 (permalink) Old Apr 6th, 20, 2:54 PM
Re: Bouncing vacuum at idle
Usually means uneven compression but you say yours are all the same. Maybe something acting up while it's running like a valve, broken ring,. or head gasket
Dansk is online now
post #3 of 26 (permalink) Old Apr 6th, 20, 6:09 PM
Which method did the mechanic use to adjust the valves, if it wasn't the E-O, I-C, find someone to get the adjustments right.
What is initial timing???
How much vacuum advance timing at idle with vacuum advance on full manifold vacuum sourcing???
What idle RPM???
427L88 likes this.
Dave Ray is offline
post #4 of 26 (permalink) Old Apr 7th, 20, 1:32 AM Thread Starter
What idle RPM???
I really dont know how the adjustment was done. What is E-O I-C?
Initial timing is 13 degrees. 9 deg vacuum added at idle connected to full vacuum port. Runs on propane
600rpm idle aprox
post #5 of 26 (permalink) Old Apr 7th, 20, 8:26 AM
All we used to have for engine diagnosis was feeler gauges, vacuum gauge, ears and seat of the pants. I got very used to consulting charts like the ones here. https://www.crankshaftcoalition.com/...gine_diagnosis
The early timing lights were crap. I would always tune to a vacuum gauge in the early 70s. Even after finally getting a nice inductive timing light in 1974 I didnít always trust it to be optimal.
I donít like being manipulated!
Alan F is offline
post #6 of 26 (permalink) Old Apr 7th, 20, 8:31 AM
Vince
What camshaft?
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #7 of 26 (permalink) Old Apr 7th, 20, 11:01 AM Thread Starter
Originally Posted by 69-CHVL View Post
What camshaft?
I guess standard once
post #8 of 26 (permalink) Old Apr 8th, 20, 4:24 PM
I know propane can stand both more compression ratio, and ignition timing, I'd go for 16 INITIAL, 10 VACUUM ADVANCE, on yoour full manifold vacuum, and a total of 38 to 40 deg/BTDC.
71350SS likes this.
Dave Ray is offline
post #9 of 26 (permalink) Old Apr 8th, 20, 5:25 PM
I'd get rid of the vacuum advance for starters.
hydro462 is offline
post #10 of 26 (permalink) Old Apr 8th, 20, 6:40 PM
Hahaha, getting rid of vacuum Advance is a great way to get rid of some free gas mileage, unload some off idle driveability and, self destruct some idle quality !
v8440 likes this.
Reelysalty is offline
post #11 of 26 (permalink) Old Apr 8th, 20, 7:18 PM
Indeed it is!
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #12 of 26 (permalink) Old Apr 9th, 20, 11:30 AM
David Estes
Leave the vacuum advance on, make sure it is connected to full vacuum and not ported vacuum. Connect your gauge to full vacuum and look at this. Listen to Dave Ray
https://www.chevellestuff.net/tech/a...cuum_gauge.htm
Have you ever stopped to think and forgot to start again??
suprdave1 is offline
post #13 of 26 (permalink) Old Apr 10th, 20, 1:15 AM Thread Starter
Originally Posted by suprdave1 View Post
Leave the vacuum advance on, make sure it is connected to full vacuum and not ported vacuum. Connect your gauge to full vacuum and look at this. Listen to Dave Ray <img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" /><img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
That means one of my valves are burned....
post #14 of 26 (permalink) Old Apr 10th, 20, 1:20 AM
Randy
Entirely possible.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #15 of 26 (permalink) Old Apr 10th, 20, 7:06 AM
Vince
What does this mean, the "7,5 and 8"? If you have anykind of cam, the vac gauge will bounce a bit.
What is your idle speed?
