Can an engine run too cool? - Chevelle Tech
 61Likes
post #1 of 49 (permalink) Old Apr 5th, 20, 3:04 PM Thread Starter
Rob
Iím having a tough time dialing in my quadrajet. Itís a 396 stroked to a 440. Iíve followed all the cooling threads thru the years and have a 160 degree thermostat in, there 1/8 holes drilled, a high flow impeller on the original water pump rebuilt by the Dutchman in Oregon, a 4 core radiator, shroud, clutch fan, sealed off the sides of the shroud to the radiator. Iíve got a gauge package which Iím sure is not real accurate but the temp indicator never gets to the first bar- under any conditions.
Hereís my stupid question, is it possible to run too cool? Hereís why I ask. I canít seem to dial in my Sean Murphy quadrajet. Itís set up perfectly, it has great manners, I have Autolite 3924í s for plugs- theyíre in a good heat range and I canít seem to keep them from a slight soot appearance.
I just took a 100 mile cruise, 50 street, 50 highway. 3:73 in the rear so itís spinning good on the highway. I have no black smoke on a flick or a flooring of the throttle. I stopped to fill it up- Iím in So Cal and itís 65 degrees. I can touch the radiator, I can touch the manifolds for a moment, itís very cool under the hood. Would going to a 180 degree thermostat be better? Should I go to the next plug up in heat range?
Iím running a 72 main, 48 b rods, I set the float at .375 from the top as I was getting a wet gasket on carb- that worked. I have an AC pump on with a regulator set at 6 lbs. still running rich as evidenced by the plugs.
Plugs looked great before I converted to a 4 speed from an automatic. Might be something there too? Would love any suggestions and input. Rob
RHinkel764 is offline
post #2 of 49 (permalink) Old Apr 5th, 20, 3:10 PM
jeff
Re: Can an engine run too cool?
I have had a few that ran cold like under 140 unless I stuck a piece of cardboard in front of the radiator or just a plastic sack or a couple blue paper towels you get at the gas station.
Winters here I need to block the radiator.
Try that first and see if you can get it to 160 or 190.
If that does not clear it up then step up the heat range of the spark plugs.
Clean the spark plugs before you set out on the next trial run. Or at least one of them to get a fresh reading
RHinkel764 and fenns70 like this.
jeff swisher is offline
post #3 of 49 (permalink) Old Apr 5th, 20, 3:31 PM
Why Quadrajet ?
Reelysalty is offline
post #4 of 49 (permalink) Old Apr 5th, 20, 3:34 PM Thread Starter
Rob
Original one to the car with an automatic. 7028210
71350SS and LeoP like this.
post #5 of 49 (permalink) Old Apr 5th, 20, 3:37 PM
Only change is auto to 4 speed ?
Are you lugging car ?
Why not put a Holley on for driving, save Q for car shows ?
post #6 of 49 (permalink) Old Apr 5th, 20, 3:41 PM
Originally Posted by Reelysalty View Post
Why Quadrajet ?
Quadrajets can run great! Why not a Q-Jet?
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is offline
post #7 of 49 (permalink) Old Apr 5th, 20, 3:45 PM
Guy
Change that 160 degree thermostat for a 180 and see if that helps.
It's an easy thing to try.
I use a Milodon High Flow 180 thermostat and the rest of my cooling system is very similar to how you describe yours and mine works very well,no running too hot or too cold issues here !!
The Milodon High Flow does not require the holes drilled in them.
Guy
71350SS, LeoP, BillyGman and 3 others like this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #8 of 49 (permalink) Old Apr 5th, 20, 3:50 PM Thread Starter
Rob
Quadrajet once set up is pretty reliable. Just canít seem to get it right here. Only change was auto to manual. Strike that, I did add the rebuilt high flow impeller water pump..
post #9 of 49 (permalink) Old Apr 5th, 20, 4:39 PM
mike
You're gonna get soot with it running that cool, carb may be fine? like has been said, install 180 stat.
slowmo55ss is online now
post #10 of 49 (permalink) Old Apr 5th, 20, 5:12 PM
jeff
My SBC with a 160 never opens and a 180 will not either.. small holes drilled in them.
I suppose if I quit drilling them.
My Nova I could drive 8 miles down the highway with NO cooling fans on before it got to 160.
I have a fan on my 57 and I have went 100+ miles down the highway at 3000 rpm and never got off 140 temps.
My temp gauge is in the thermostat housing. This is below 60 degree days.
I have stuck my thermostat in a pan of water on the stove and turned the fire on under it to see when it opens.
A good thing to do with all new thermostats. I cook every one of them and found 2 bad ones that were new.
427L88 and kmakar like this.
post #11 of 49 (permalink) Old Apr 5th, 20, 5:36 PM
Mr Bill
So what is the problem ??
If you never looked at them would you think there was anything wrong ? Even the slightest bit of idling time can start to soot up a plug. I think you are worrying about nothing. The only way to get a real accurate reading from a spark plug is to make a WOT pass and shut of the engine clean and coast to the side of the road and pull a plug.
In my opinion it is better to run an engine as hot as possible within reason. It will be more efficient. That is why newer vehicles all run at much higher temps. But . . I dont think it going to affect your plugs any.
Alan F, LeoP, RHinkel764 and 1 others like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #12 of 49 (permalink) Old Apr 5th, 20, 6:01 PM
Jonathan
My 4.3L V-6 boat has a 160 degree stat.
My daily drivers have either 180-190 degree stats.
My diesel has a 200 degree stat.
The Chevelles do have 180 degree stats.
Each engine had different requirements.
LeoP likes this.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is offline
post #13 of 49 (permalink) Old Apr 5th, 20, 6:07 PM
Yes an engine can run too cool, you need the heat to dissipate the moisture that builds through condensation inside the engine and in the oil. Fuel does not vaporize well at low temps causing combustion issues. Run a 180* thermostat and all those issues go away.
oldcutlass is offline
post #14 of 49 (permalink) Old Apr 5th, 20, 6:15 PM
👍 I use 160 in 2 cars (sometimes 180 for some heat in winter). Not unusual to drive 10 miles in 85’ weather w/o fan coming on (set about 175) in 383.
There’s a reason engines are dynoed at 160.
post #15 of 49 (permalink) Old Apr 5th, 20, 7:14 PM
Please post both timing specs initial, vacuum advance degrees, along with full manifold or ported, total, and comp ratio, cam DEGREES,m don't care about lift, and what materials the block and heads are.
YES, engines can, and do run too cold when set up/tuning advice isn't correct for the applications.
Cast iron block, cast iron heads, 180 degrees, cast iron block, aluminum heads, 192/195 degrees. Sounds like there aren't any problems in the cooling system setup.
What reason is it that dictates an engine be "dyno'd" at 160 deg/F. engine temperature, please?
LeoP and davewho1 like this.
Dave Ray is offline
