396/325hp - Chevelle Tech
 13Likes
post #1 of 16 (permalink) Old Mar 27th, 20, 7:17 PM Thread Starter
396/325hp
I have a 1968 Chevelle ss stock 325hp
A guy has a aluminum intake date code correct for a 396/454 for round ports but I think my heads are oval, does it make a big difference
I want more horse power and was going to change intake anyways, would these be a could consideration
Thank you
Doug/chevelle is offline
post #2 of 16 (permalink) Old Mar 27th, 20, 7:47 PM
Guy
Re: 396/325hp
Round and oval port heads are quite likely the same thing.
There are 3 general head/port shapes for the BBC;
Peanut port and oval and rectangular port.
If you provide part or casting numbers that would help determine what parts you have.
Guy
Steve R likes this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #3 of 16 (permalink) Old Mar 27th, 20, 7:52 PM
Re: 396/325hp
I don't think Chevy ever made an aluminum BB intake other than square port or for a Quadrajet.
Jerry70 is offline
post #4 of 16 (permalink) Old Mar 27th, 20, 7:57 PM
Ole
Re: 396/325hp
If this is a stock L35 396/325 the best way to add horsepower is a camshaft upgrade. The L35 was notoriously under-cammed and one can easily add 25-50 HP by changing camshafts. Be sure to upgrade valve springs at the same time. I also recall an untouched '68 L35 396 that I removed from a Caprice Wagon in the early 1980's that had 5/16" pushrods. If your engine has the same I would change those out for 3/8" also.
Oh, and welcome to Team Chevelle, Doug!
von, BRN2RUN and shovelrick like this.
First Posted to TC as Ole Birkland in Feb 1999
Aces 3383
1969 Chevelle SS396, L78, M22, KK 4.10 posi, F41, Blue Light Stereo, Tilt Column, Burgundy/Maroon w/Red Stripe, Black Bench Seat, PS,
PDB, American Torque Thrust & BFG TA's, fully restored.
Saltherring is offline
post #5 of 16 (permalink) Old Mar 27th, 20, 8:01 PM
Ole
Re: 396/325hp
Back in 1970 I purchased an Edelbrock C396 oval port manifold for my '68 L34 Chevelle. It was machined for square-bore carbs, not spread bore.
Aces 3383
post #6 of 16 (permalink) Old Mar 27th, 20, 8:09 PM
jimmyradford
Re: 396/325hp
He's referring to the '68-69.5 Corvette L-36 intake. It's an aluminum, low rise spread bore to fit under the low hood line.
Steve R likes this.
TC Member # 4431
'16 GMC Denali XL- 6.2L's are sweet
'07.5 Chevrolet 2500HD-6.6 D-Max
'07.5 Chevrolet Suburban
'67 Chevrolet Biscayne- SS427 L-36/TH400 (Hers)
'67 Hell Camino-BB 427/TH400 (His)
'66 300 Deluxe 2 door-230/PG
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is online now
post #7 of 16 (permalink) Old Mar 27th, 20, 8:12 PM
Re: 396/325hp
I bought a winter's aluminum q jet intake at a swap meet awhile back. it was a marine intake with the brass liner under the thermostat housing. jim
Jim Mac is offline
post #8 of 16 (permalink) Old Mar 27th, 20, 8:23 PM Thread Starter
Thanks, I am having a hard time learning how to reply on here
Anyways casting number s are 3883948
And 3917213
Good to know about the cam
post #9 of 16 (permalink) Old Mar 27th, 20, 8:26 PM Thread Starter
Also the number for the intake is 3933163 code 2
post #10 of 16 (permalink) Old Mar 27th, 20, 8:42 PM
Guy
Re: 396/325hp
I couldnt find anything that matches the first #.
The second shows as a cast iron intake for a 390 HP 427.
The third # is,IIRC,a Winters aluminum intake for the High Performance solid lifter 396,427 and 454.Rectangular port version.
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #11 of 16 (permalink) Old Mar 28th, 20, 1:15 AM
Re: 396/325hp
3883948 is a cast intake for a '67 vette or chevelle or Impala. Q jet of course.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is offline
post #12 of 16 (permalink) Old Mar 28th, 20, 5:25 AM
von
Lifetime Founding Member
Von
Re: 396/325hp
IMO you're wasting your time and money on a different intake for your 325 hp 396. The stock iron '68 intake isnt a bad piece and I doubt if there's much hp to be gained on an intake swap. Your time and money would be much better spent on the aforementioned cam and spring upgrade. In addition, carb and dist tuning, headers, exhaust, ignition also would bring a bigger bang for the buck. If you're keeping the stock snorkel type air cleaner, A few holes cut in the back side bottom, out of sight and outboard of the filter, will work wonders for upper rpm power and still be stock appearing to the casual observer.
von is offline
post #13 of 16 (permalink) Old Mar 28th, 20, 8:31 AM
Swap distributer for Pertronics or MSD, adding a Holley DP, and headers helped me the most.
If you change to Winters intake w/rectangular ports you’re still choked off by little heads.
Reelysalty is offline
post #14 of 16 (permalink) Old Mar 29th, 20, 2:26 PM
Re: 396/325hp
I agree, back in the day my buddy had a 69 Chevelle 396/325 . It ran 14.9 stock. Like everyone else back then his first mod was an aluminum manifold and holley carb . It then ran 15.0 - 15.1's . He installed headers and it went 14.9's . He then went BACK to cast iron intake and quadrajet it went 14.7's . He then swapped cam, lifters, v springs and it went 14.2's with no traction. The intake you have isn't that bad!It was the cam that was the weak link, even the 396/350 cam was VERY mild!
von and Georgia69 like this.
BRN2RUN is offline
post #15 of 16 (permalink) Old Mar 29th, 20, 2:48 PM
Freddy
Re: 396/325hp
Welcome to the site.
Freddy
Freddy Mercado is offline
