Need help - Chevelle Tech
 2Likes
post #1 of 16 (permalink) Old Mar 10th, 20, 1:34 PM Thread Starter
Need help
I have a '72 Chevelle 396 w/ an HEI distributor. I am not an engine guy by any means and usually have my Dad walk me through these issues (died 3 years ago). About 3 months ago I tuned up (timing and carb adjustments) my 396 and everything was running fine except sputter and backfire (in the exhaust) when romping on her at about 40mph... which when she's coldish that's the norm. Recently, I went to fire her back up and she acted like she was only firing on 2-4 cylinders. Pulled plugs, replaced cap and rotor (placed the plug wires in the exact same order they came off), plug wires are in good shape, compression checked each cylinder (all good to go). My question is, should I be looking at a new coil and ignition module? What would cause a normal running engine to start running like an air pump? Any help is appreciated.
BCarter72 is offline
post #2 of 16 (permalink) Old Mar 10th, 20, 3:05 PM
Re: Need help
What did the plugs look like internally? Rich running? Sooty, black or wet? If yes, you might have fouled your spark plugs.
B52bombardier1 is offline
post #3 of 16 (permalink) Old Mar 10th, 20, 3:08 PM Thread Starter
Re: Need help
They did in fact look sooty and a little wet, but I cleaned them up with carb cleaner and a wire brush and retried starting the motor with the same result.
post #4 of 16 (permalink) Old Mar 10th, 20, 4:05 PM
Re: Need help
Once a plug gets wet and cooled in fuel, quite often it can't be cleaned up. I'd put a new set of plugs in and see what happens.
I'm also thinking bad gas. I only use fuel without ethanol.
post #5 of 16 (permalink) Old Mar 13th, 20, 7:02 PM Thread Starter
Re: Need help
Rick, thanks for the help... that was what the doctor ordered!!!!
post #6 of 16 (permalink) Old Mar 13th, 20, 7:19 PM
Ole
Re: Need help
I have been running the non-ethanol 92 octane fuel too. Very expensive however.
First Posted to TC as Ole Birkland in Feb 1999
Aces 3383
1969 Chevelle SS396, L78, M22, KK 4.10 posi, F41, Blue Light Stereo, Tilt Column, Burgundy/Maroon w/Red Stripe, Black Bench Seat, PS,
PDB, American Torque Thrust & BFG TA's, fully restored.
Saltherring is offline
post #7 of 16 (permalink) Old Mar 13th, 20, 7:39 PM Thread Starter
It's hard to find non-ethanol mixed gas... can you suggest an additive to help combat the effects of ethanol mixed fuel?
post #8 of 16 (permalink) Old Mar 13th, 20, 8:03 PM
There isn’t such an additive that I know of. If you live near a large body of water, boat marinas often carry non-corn gas
Good luck!
Reelysalty is offline
post #9 of 16 (permalink) Old Mar 13th, 20, 8:21 PM Thread Starter
Unfortunately no I don't... but thanks for the insight
post #10 of 16 (permalink) Old Mar 13th, 20, 8:24 PM
Re: Need help
In our area they call it Rec Fuel (as in recreation). Snowmobilers and boaters mainly use it, also is all I will use in my snowblower and lawnmower not to mention my classic vehicles.
1975TypeS-3 is online now
post #11 of 16 (permalink) Old Mar 13th, 20, 8:44 PM Thread Starter
I'm in Wichita... I could imagine that there are places like that around here but I have yet to find them... only been here for 6 months
post #12 of 16 (permalink) Old Mar 13th, 20, 11:22 PM
leo
Re: Need help
Sta-bil makes an additive for combating ethanol gas, should be in any parts store chain. good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #13 of 16 (permalink) Old Mar 14th, 20, 1:15 AM
Re: Need help
Yes there is
While I am not a fan of additives this stuff actually works
Star Tron Enzyme Fuel Treatment Gas Additive Shooter
BillyGman likes this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #14 of 16 (permalink) Old Mar 14th, 20, 1:18 AM
Kim
Re: Need help
If you have a small airport near you, see if you can buy av-gas there. Great stuff, but some places are snippy about selling it to car guys.
shelteredv is offline
post #15 of 16 (permalink) Old Mar 14th, 20, 9:36 AM
Gavin
Re: Need help
https://www.pure-gas.org/index.jsp?stateprov=KS
B52bombardier1 likes this.
My father tells me I was born 30 years too late.
Ghaasl is offline
