another cam suggestion question - Chevelle Tech
 7Likes
  • 2 Post By Paul J
  • 2 Post By mr 4 speed
  • 2 Post By swampy 6x6
  • 1 Post By hydro462
post #1 of 12 (permalink) Old Mar 6th, 20, 2:10 PM Thread Starter
Paul
I have a 396, 9:1 CR, 148 heads, Edelbrock Performer2 intake/750 carb, Hooker super comp headers, 3.07 differential in a 69 El Camino. Currently has a hydraulic cam with specs close to the one used in a 350 hp 396. It's a weekend driver only. Motor does fine but like everyone else I wonder "what if". That being said, are there any suggestion on a more aggressive hydraulic cam that could perk this motor a little more? Yes, I know I could replace it with a 454, and that may happen sometime, but there aren't many miles on this current build.
Paul J
'69 El Camino SS
396 CI,Hooker Super Comps
TH400, HEI, Performer Intake, 750 cfm
Paul J is offline
post #2 of 12 (permalink) Old Mar 6th, 20, 2:19 PM
The cam world is yours,
once you get rid of that 3.07 !
Reelysalty is offline
post #3 of 12 (permalink) Old Mar 6th, 20, 3:08 PM Thread Starter
Paul
Re: another cam suggestion question
Forgot to mention, TH400 trans.
Paul J
'69 El Camino SS
Paul J is offline
post #4 of 12 (permalink) Old Mar 6th, 20, 3:09 PM Thread Starter
Paul
My highway driving is much nicer than my buddy with his 3.73's.
hydro462 and shovelrick like this.
Paul J
'69 El Camino SS
Paul J is offline
post #5 of 12 (permalink) Old Mar 6th, 20, 3:20 PM
Paul, I think a cam like this would work perfect for your application:
https://www.competitionproducts.com/.../#.XmKwR6hKiUk
427L88 and Paul J like this.
mr 4 speed is offline
post #6 of 12 (permalink) Old Mar 6th, 20, 3:52 PM
Gerry
I think those 148 heads were the open chamber style for the 265 hp 396 engines.
Have they been worked over or are they stock?
Either way do you know the flow numbers on them?
If you have that, it will be fairly easy to pick a cam that will work well with your combo.
67 SS BBC
4.11's
bradley67 is offline
post #7 of 12 (permalink) Old Mar 6th, 20, 4:05 PM Thread Starter
Paul
They are stock. From searching the site, The heads are basically the same as the 325 and 350 hp versions but with a larger combustion chamber for the 9.0-1 compression ratio, 112cc-122cc chambers.
Paul J
'69 El Camino SS
Paul J is offline
post #8 of 12 (permalink) Old Mar 6th, 20, 5:47 PM
Gerry
Can you get the flow numbers @ 28 hg? - .100Ē thru .550Ē lift?
Mark @ Vortecpro might know.
67 SS BBC
4.11's
post #9 of 12 (permalink) Old Mar 6th, 20, 11:15 PM
hi
compression 9:1cr very limiting
diff gear 3.07 go 3.3 3.4
convertor stall ? easily fixed any thing over stock would be an improvement
head design and flow ??
The above are limiting factors
Use an Edelbrock RPM package as a guide
123pugsy and Paul J like this.
swampy 6x6 is offline
post #10 of 12 (permalink) Old Mar 7th, 20, 7:32 AM
rick
Don't forget about matching valve springs if you go much more than stock lift
shovelrick is offline
post #11 of 12 (permalink) Old Mar 7th, 20, 9:20 AM
I would keep what you have and play with the timing. Try advancing the initial to 20 and the mechanical to 14 all in by 2400, since you have a 3:08..
That is a perfect street set up. Don't fall for that lumpy cam nonsense and give up bottom end performance and power brakes..
Paul J likes this.
hydro462 is offline
post #12 of 12 (permalink) Old Mar 8th, 20, 9:20 AM
p40
butch
stan weiss has a web site with head flow at 28 hg
p40 is offline
