Help - BBC 396 - 440 Stroker Street Build - Chevelle Tech
 23Likes
post #1 of 52 (permalink) Old Feb 26th, 20, 10:23 PM Thread Starter
Hey
I am putting together a 396 +.090 (4.185" bore) 4.00" stroke, 440ci engine for my 1969 chevelle. This is a street only engine, hydro brakes, manual transmission
So far, I have the block freshly machined and a box of O.E engine parts that came off the 1969 motor.
My goal is to get to 500hp N/A, without spinning the motor to 8k rpm
I am looking for suggestions on:
aluminum Head brand and combustion chamber size
Cam profile and duration
Compression ratio and piston dome cc
I know I will have more questions to come, Thank you in advance!
satx_675 is offline
post #2 of 52 (permalink) Old Feb 27th, 20, 7:11 AM
Re: Help - BBC 396 - 440 Stroker Street Build
Edelbrock and others have 110cc heads that combine with about 22cc dome pistons that would make about 10.0-1 compression ratio depending on gasket thickness and bore notch. what style lifter are you planning?
pbcbob is offline
post #3 of 52 (permalink) Old Feb 27th, 20, 7:35 AM
I am guessing you are going to have a set of pistons made for it. So based on that, pick a cylinder head and then just have the piston made to match that. And then the cam will be based on the flow characteristics of the head.
71454Chevelle likes this.
Ray
bracketchev1221 is offline
post #4 of 52 (permalink) Old Feb 27th, 20, 8:21 AM
jeff
The 396 is not that hard to get 500HP from.
Read this.
Chevrolet 396 Big Block - Super Chevy Magazine
And this may also help.
https://www.chevelles.com/forums/13-...ke-500-hp.html
If you have the 1969 oval port heads and know how to port heads a little I would use them.
427L88 likes this.
jeff swisher is offline
post #5 of 52 (permalink) Old Feb 27th, 20, 3:11 PM
Here is something I helped a kid with in the late 80's He had a real nice 68 Chevelle SS 396 4 speed car that ran 14.40'[email protected] and he wanted to go faster than the fox body guys back then as they would beat him. I tole the kid we need to do some new heads and a very mild cam. So he went with the 350hp 396 cam and after some persuasion he reluctantly did a set of Peanut Port heads. I told him I would but the heads from him if the did not perform well, so that was enough to try them. The heads only had the 2.19 and 1.72 exhaust valves, no porting and with a performer intake and his stock Q-jet the car ran [email protected] Needless to say he was very happy. He never told his buddies with other 396 cars what he used for heads and he always beat them. Besides would you put a 265cc head on a 400 SBC? of course not, then why would you do that to a lesser 396 BBC.
the heckler likes this.
68Chevele is offline
post #6 of 52 (permalink) Old Feb 28th, 20, 12:38 AM
Why would you spend the money on an odd displacement stroker instead of building a 454 based stroker?
1967 Chevelle 496BB/TH400/Strange S-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Rat Muscle Parts Hauler)
2015 Harley Davidson Road Glide Special (Cruiser)
2007 Harley Davidson Road King Custom (Bar Hopper)
2018 Chevy Silverado LTZ Duramax (Daily Driver)
My Chevelle:
C & D Performance
North Texas Chevelles
Motorhead62 is offline
post #7 of 52 (permalink) Old Feb 28th, 20, 6:52 AM
isnt this just a .090 block with a 454 crank?
Jim Mac is offline
post #8 of 52 (permalink) Old Feb 28th, 20, 7:26 AM
'69, no 454 blocks yet, the purists will find it and harass the owner for not staying "original".
Unless it's a top shelf concours type car, I'd tell the purists to pound sand and I'd drop a 496 or 505 stroker in 'er.
Gary Adrian
Busted Knuckles is offline
post #9 of 52 (permalink) Old Feb 28th, 20, 7:38 AM
You’ll get more gross HP,
stroking your 396
but you’ll get the HP at the
expense of a slower revving engine.
Reelysalty is offline
post #10 of 52 (permalink) Old Feb 28th, 20, 8:05 AM
stroking your 396
How much slower? Enough to time it?
Ray
post #11 of 52 (permalink) Old Feb 28th, 20, 8:51 AM
What kind of Compression ratio did it have? Weren't peanut ports all 119cc? That's running pretty good for an old-tech 350hp factory cam.
novadude is offline
post #12 of 52 (permalink) Old Feb 28th, 20, 9:21 AM
satx 675, dont waste too much money on alloy heads as your bore size and ci wont work them well at all. oem 781 are likely your best choice or RR-ovals in iron if you have no heads. In fact, this may be the application where the shrouded ( for a 4.25" X4") old closed chambers work OK. Small combustion chamber = compression. And they're barely shrouded for a 396.
Anywhere near 500 is going to require a roller cam imho, PROPERLY matched to your heads. To me, that is the "system" you ought be entirely focused on. In fact, you might get ahold of a pro, like Straub or Foxwell if they dont chime in here, and see which head/cam combo might shine for a small bore low displacement rat.
post #13 of 52 (permalink) Old Feb 28th, 20, 9:25 AM
stroking your 396
Short stroke also produces more HP...faster.
post #14 of 52 (permalink) Old Feb 28th, 20, 11:10 AM
Could you explain how the short stroke does that?
sleeper is offline
post #15 of 52 (permalink) Old Feb 28th, 20, 11:25 AM
My short stroke 3.76" made maybe 510 @68 00, my 4" makes [email protected] w/ smaller cam.. That's how!
The key here is cylinder filling that small bore and short stroke. No HP gains here, its a hinderance you have to design around. You'll need a ton of ram effect and "port-torque" from the valve event timing/port config to support any decent HP under 7000 rpm.
