Front Oil SEAl - Chevelle Tech
  • 1 Post By Tom Mobley
post #1 of 8 (permalink) Old Feb 23rd, 20, 7:52 AM Thread Starter
Front Oil SEAl
Pd a professional to stop oil leak from under timing chain cover area. He replaced front seal that rides on harmonic balancer (396).
Cure lasted a week. It was damp when I got home which I credited to him not cleaning up. What did mechanic do wrong ? He said harmonic balancer grove looked good, no scarring.
Reelysalty is online now
post #2 of 8 (permalink) Old Feb 23rd, 20, 9:18 AM
autumngold
Re: Front Oil SEAl
fel pro had a bad run of crank oil seals amongst others.Get a new seal and measure it to be sure.
1970 ls-5 numbers matching
marcrose is offline
post #3 of 8 (permalink) Old Feb 23rd, 20, 9:28 AM Thread Starter
Thanks !
post #4 of 8 (permalink) Old Feb 23rd, 20, 9:03 PM
Mr Bill
Re: Front Oil SEAl
Are you sure it is the seal ? Clean it off real good with some brake clean and then put some die in the oil. Run it for a while and use a black light to see where the leak is coming from for sure. Oil can get blown around and fool the best of us when trying to find a leak. I personally have not seen any bad seals from Fel Pro and that is all I will use.
Also make sure you dont have a lot of blowby forcing the oil out of the seal.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #5 of 8 (permalink) Old Feb 23rd, 20, 9:58 PM Thread Starter
I pd someone to swap it out. After a week, one drop on cardboard. I found fresh oil pushing my finger between oil pan and damper,
When seal was replaced, I cleaned up and painted front of oil pan and squirted brake clean in area to remove any residual oil.
I have PCV valve to back of carb and tall filtered vent in other valve cover. Is this sufficient ?
post #6 of 8 (permalink) Old Feb 23rd, 20, 11:12 PM
Re: Front Oil SEAl
Yes, unless the engine has abnormal amounts of blow-by.
engine warmed up and idling, pull the breather out put your thumb over the hole. Before long there shouid be either vacuum or pressure in that hole. vacuum = good. pressure = not so much.
boyd66k20 likes this.
post #7 of 8 (permalink) Old Feb 24th, 20, 8:31 AM
Re: Front Oil SEAl
You can get a speedi sleeve from Napa to press on the harmonic balancer. It'll give the seal a fresh surface to ride on and hopefully stop the leak.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #8 of 8 (permalink) Old Feb 24th, 20, 8:35 AM Thread Starter
Thanks Hotwire,
I have an idea this is the problem.
So many shops have a “Just get it out and hope he doesn’t come back mentality”
