Electric Choke - Chevelle Tech
 25Likes
post #1 of 39 (permalink) Old Feb 15th, 20, 12:50 PM Thread Starter
Phil
Electric Choke
I have a Holley 3310 on my 396 engine and I do not have the mechanical choke hooked up. I was considering putting a Holley electric choke on my carburetor but I've read some bad reviews about them not working properly. Have any of you had good results with the Holley electric chokes? Not having a choke makes start up and warm up difficult in the cold Winter time. Any advice or suggestions would be greatly appreciated.
bigfish45 is offline
post #2 of 39 (permalink) Old Feb 15th, 20, 12:57 PM
Holley electric choke works OK except a tendency to go to fast idle too often. A quick blip of throttle takes care of it, but nonetheless irritating.
Have you run a Holley w/o choke ? My experience is it’s unnecessary above 40’ or so, if your Holley and engine is well tuned.
If I had to have a choke, I’d go manual
Reelysalty is offline
post #3 of 39 (permalink) Old Feb 15th, 20, 3:50 PM
Re: Electric Choke
I've been running a Holley 3310 with the choke open for the last 10 years in all kinds of weather with temps down in the teens. It starts up fine, you just have raise the idle manually with your foot for a little while.
oldcutlass is offline
post #4 of 39 (permalink) Old Feb 15th, 20, 4:10 PM
Re: Electric Choke
They work just fine when set up correctly, which most people don't do.
Process is thus:
Mount choke, set power up, good source is the IGN terminal on the fuse box. Do leave the old hot air inlet OPEN< use the screen provided, and do not close it off, the choke stove inside the unit needs the very slight vacuum pull to make sure the stove doesn't over heat and fail.
Now, adjustment. After the entire choke is installed, power it up with a jumper wire with alligator clips so you don't have to leave the ignition on to set it. Slightly block the throttle open to allow the choke linkage place the fast idle cam OFF holding the throttle open. Rotate the choke stove to completely close the choke plate in the air horn. SLOWLY open the choke, then close it to the point the choke plate just closes completely, tighten stove retainer screws. Disconnect jumper wire power to the choke, restore car power to choke stove, REMOVE THE THROTTLE BLOCK TO LET THE THROTTLE FULLY CLOSE. Done.
Choke stove: the heating coil inside the plastic cover housing.
Dave Ray is offline
post #5 of 39 (permalink) Old Feb 15th, 20, 4:47 PM
Properly deleted choke ! &#x1f601;
post #6 of 39 (permalink) Old Feb 15th, 20, 6:37 PM
Gary
Re: Electric Choke
Does Holley make some kind of temp sensitive switch to keep the choke from closing when the engine is still warm causing the engine to be overly rich when you start it after 30 min or so. One of the reasons I like hot air chokes
gnicholson is offline
post #7 of 39 (permalink) Old Feb 15th, 20, 6:40 PM
Yes, a bimetal spring aided by 12v in cold weather. I think it works just like a 57 Chevy only heated by electricity, rather than exhaust.
post #8 of 39 (permalink) Old Feb 15th, 20, 6:47 PM
Re: Electric Choke
I've been running Holley electric chokes for over 20 years without any problems. Like Dave said, the key is it's adjustment.
Jerry70 is offline
post #9 of 39 (permalink) Old Feb 15th, 20, 7:01 PM
Just me, but I never thought it is a good idea to light up a cold HP motor immediately to 12-1500 RPM and flood cylinder walls with gasoline. All to save a couple of miles of warm up. Not to mention all that restrictive air horn mess !
post #10 of 39 (permalink) Old Feb 15th, 20, 7:58 PM
Gary
Re: Electric Choke
You are talking about a divorced manifold mounted choke though correct ?
post #11 of 39 (permalink) Old Feb 15th, 20, 8:49 PM
I divorce every one I get !
I take it 3310 doesn’t have provision for elect choke ?
ID:	616618   Click image for larger version
post #12 of 39 (permalink) Old Feb 16th, 20, 5:19 PM
Re: Electric Choke
I don't remember ever seeing a stock 1957 Chevy Rochester carb divorced electric choke. Saw a few in later years have them, not many.
ALL Holley chokes use engine vacuum to pull the choke open when the temp unit is warm. That long part of the casting out the front of it, and the vacuum piston in the bore inside it is called the "choke pull off". Both manual heat, and electric chokes have them.
Dave Ray is offline
post #13 of 39 (permalink) Old Feb 16th, 20, 9:39 PM
Process is thus:
Thanks for that. This is my first electric choke and I've been fiddle farting around with it for a bit, trying to make it work right. The instructions that came with the carb are super vague. It works great now! I need a few hundred in my fast idle, but I'm not super worried since it works.
novadude likes this.
Johnny Bravo is online now
post #14 of 39 (permalink) Old Feb 17th, 20, 4:06 AM
Re: Electric Choke
reely, check the area of the choke horn vs. the area of the vemturiis minus the area of the boosters and tell us again exactly how the choke horn is restrictive.
NickeyChevelle likes this.
post #15 of 39 (permalink) Old Feb 17th, 20, 4:11 AM
Re: Electric Choke
John, if you look at the passenger side bottom of the carb from the back you'll see a stright blade screwdriver slotted screw. turn that screw in 1/4 turn and see how the idle speeds up. repeat as needed.
Do you have an electric choke cap on there? I can't really see in the pic.
