1972 Frame motor mounts 350 engine - Chevelle Tech
 2Likes
post #1 of 19 (permalink) Old Jan 9th, 20, 11:27 AM Thread Starter
Hi to all.
When I bougth my 1972 Chevelle, the previous owner bolted/welded some clam style (1975 and older?) frame engine mounts on the crossmember. I just want to make sure that the ones I'm ordering are the right ones for a GM 350. Also, I will be using the poly ones for engine mounts. Everything is supposed to fit together?
Thanks for the help!
ID:	613036   Click image for larger version
ID:	613038   Click image for larger version
Enjoy the ride!
Ratty72 is offline
post #2 of 19 (permalink) Old Jan 9th, 20, 12:18 PM
Re: 1972 Frame motor mounts 350 engine
You've got the right style frame mounts pictured. HOWEVER, make sure you get the right size. If you're using a 250 or 307 engine, they came with a pair that is taller than those used for the larger displacement small blocks and all big blocks. They look identical from a distance.
Next to each other, if I recall correctly, there's about a 1/2" difference in height.
The energy suspension motor mounts work well.
Bronze68 is offline
post #3 of 19 (permalink) Old Jan 9th, 20, 1:16 PM Thread Starter
Thanks for your reply. I'll make sure to order the good ones.
Thanks!
Enjoy the ride!
Ratty72 is offline
post #4 of 19 (permalink) Old Jan 9th, 20, 1:38 PM Thread Starter
Will those be the correct ones?
It's listed for both BBC and SBC but in the application, it also lists " 5.0L/307"... I think they are the correct ones but...
https://www.summitracing.com/int/parts/amd-w-995
Thanks,
Enjoy the ride!
Ratty72 is offline
post #5 of 19 (permalink) Old Jan 10th, 20, 9:03 PM
Tim
If I can add a question to this thread, my 71 Chevelle currently has a 350, I just bought a 454. Do the engine mounts on the frame need to be changed?
Tim's_2nd_Chevelle is offline
post #6 of 19 (permalink) Old Jan 10th, 20, 9:34 PM
Here's a page showing the difference, scroll down: https://www.chevellestuff.net/tech/engine_mounts.htm
A lot of folks sell these. Here's one like you need (at bottom): East Coast Chevelle | Chevelle Restoration Car Parts
327, 350, 396, 402, 427, 454, etc.: all the same frame mounts.
Kirk's67SS likes this.
Bronze68 is offline
post #7 of 19 (permalink) Old Jan 10th, 20, 10:19 PM
In a word No.
Quote of the day.
'The difference between trash pick up and a yard sale is the distance the stuff sits from the curb".
1968 is online now
post #8 of 19 (permalink) Old Jan 15th, 20, 1:20 PM Thread Starter
Soooo.... I just received my frame motor mounts from Summit (https://www.summitracing.com/int/parts/amd-w-995) and I have a little problem. It looks like I have 2 left mounts OR maybe 307 mounts? The 2 mounts have 5 bolts to bolt them on the cross member and the holes for the long connecting bolt are round (based on what I've seen so far, one should be oblong?)
The measurement from the base of the mount to the round hole is 1 inch. They are 1.5 inch tall and 2.5 inches wide at the base.
Can anyone confirm if they are the correct 350/BB mounts?
Is it OK if I have 2 lefts (or Rights) mounts
ID:	613642   Click image for larger version
ID:	613644   Click image for larger version
Enjoy the ride!
Ratty72 is offline
post #9 of 19 (permalink) Old Jan 15th, 20, 5:40 PM
Greg.
Not sure as I have a 67 Chevelle
but there should be a Left one and a Right one as in Summits Pic
and as indicated in this below pic
if you are trying to line up the Holes in the Mounts with the Frame Holes
see Related Parts at the Bottom of this page also
https://www.ss396.com/chevelle/ACE-9794.html
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #10 of 19 (permalink) Old Jan 15th, 20, 6:50 PM
see Kirks pic. the tall frame mount is usually referred as the 307 frame stand. the shorter one is for all other V-8s. AFAIK nobody has ever discovered why the 307 mounts were taller/narrower than all the others. The 307 block is not different in that area. I'd leave in the ones you've got. the clamshell mounts are superior in every way to old style. Plus there's an unpleasant surprise waiting fr you. With the lower control are installed it's very difficult to get at the nuts on the bolts that hold the mount stand in place. Many guys have resorted to cutting the heads off the bolts.
In the second pic in post #8, the long tabs with the bolt holes hang over the front of the crossmember. Yes it seems kinda weird but that's the way they were.
post #11 of 19 (permalink) Old Jan 15th, 20, 6:53 PM
Jonathan
FYI... The 307 mounts on the engine will fit on a 350.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is offline
post #12 of 19 (permalink) Old Jan 15th, 20, 6:57 PM
here's another pic
post #13 of 19 (permalink) Old Jan 15th, 20, 6:58 PM
won't attach the pic, I've posted it numerous times before. Dang
post #14 of 19 (permalink) Old Jan 15th, 20, 7:06 PM
try again
post #15 of 19 (permalink) Old Jan 15th, 20, 7:12 PM
Ratty, be aware that the people on a vendors order desk are unlikely to know about this. They'll probably one listing that covers all. No sense confusing them with facts, just try another. Hinshaws in NC is usually good.
Chevelle_Nut likes this.
