Varying intake temp issue - Chevelle Tech
 7Likes
post #1 of 17 (permalink) Old Dec 20th, 19, 1:13 AM Thread Starter
I am hoping someone can shed some light on this strange issue I am having with my 383 sbc. This spring I installed a dual pass radiator to reduce the engine heat here in Phoenix. It seem to be doing its job during the hot summer, now that it is cool 60 to 70 degrees when I take the car on the highway it runs 165-170 via the electric gauge on the passenger side of the intake while the Driver side will go up to 210 for a minute or two. I have a Dakota Digital dash into pass side and an Autometer electric gauge in the driver side of intake. Why am I seeing the passenger side rise to 210 then drop to say 180 after a couple of minutes and then both will be 185* when I exit and do street driving? I have a 180* thermostat that has been checked, AFR heads and a edelbrock rpm intake. Should I be concerned about this ?
Joer5000 is offline
post #2 of 17 (permalink) Old Dec 20th, 19, 8:39 AM
Re: Varying intake temp issue
Different "hysteresis" responses in the gauges and their sending units. Some are slow to respond others, faster.
1968 likes this.
B52bombardier1 is offline
post #3 of 17 (permalink) Old Dec 20th, 19, 8:53 AM
Mr Bill
You could verify what Rick said by swapping the sending units from side to side and see what happens.
1968, jeff swisher and Kirk's67SS like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 17 (permalink) Old Dec 20th, 19, 6:49 PM
I have had that trouble with cheap thermostats, the Robert Shaw one corrected the problem.
68Chevele is offline
post #5 of 17 (permalink) Old Dec 21st, 19, 12:59 AM Thread Starter
I have replaced the gauge that goes high so,it isnít a gauge issue, why is the driver side see8ng high temps for a coup,e of minutes then dropping back down
Joer5000 is offline
post #6 of 17 (permalink) Old Dec 21st, 19, 10:48 AM
If your engine is only reaching 165-170 on the highway and you have a 180 thermostat, I'd say its a thermostat issue. The thermostat is supposed to regulate the minimum engine operating temp.
oldcutlass is offline
post #7 of 17 (permalink) Old Dec 21st, 19, 1:22 PM Thread Starter
However the diver side does stay above 180?
Joer5000 is offline
post #8 of 17 (permalink) Old Dec 21st, 19, 2:51 PM
Al
What manifold are you running? Let's see a picture of your setup.
Kirk's67SS likes this.
DUTCH MAX HEADWORK is offline
post #9 of 17 (permalink) Old Dec 25th, 19, 2:11 AM
swap the senders as Bill suggested. or, you can just start throwing money and time at it.
post #10 of 17 (permalink) Old Dec 25th, 19, 2:42 AM
You might need to swap the senders AND the gauge wiring, and see if the problem is the same, or if it switches sides. Insert the Dakota Digital and corresponding sender into the drivers side and the Autometer and sender into the passenger side.
There could be some flow pattern issues, but that's hard to tell at this point. I have seen some people use the wrong head gaskets on a big block (perhaps on only one side) which can affect the flow and thereby the temps... Could be the water pump putting more flow into one bank than the other...
But first thing to do is figure if its really a cooling/temp problem or a gauge problem.
TC #1366
Sold
Sold
1966_L78 is offline
post #11 of 17 (permalink) Old Dec 25th, 19, 4:01 AM
My head is spinning while reading your post here above^....first you say it's the drivers side that rises to 210 degrees, then you say it's the passenger side that does that. So which is it???
BillyGman is offline
post #12 of 17 (permalink) Old Dec 25th, 19, 4:50 PM
It also could be where you are taking the temp readings at.On one side of the closed thermostat could be higher than the other side if the thermostat was opening and closing.Are you using the cylinder heads for your temp senders ?
PS one other thing, Merry Christmas
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #13 of 17 (permalink) Old Dec 26th, 19, 3:44 AM Thread Starter
Sorry my mistake the hotter temp is on the driver side, I have will swap the sending units when I get a few minutes. During the warmer months the temps stay the same it only happens in the winter months. Could the thermostat affect only one side?
Joer5000 is offline
post #14 of 17 (permalink) Old Dec 26th, 19, 8:46 AM
I fear that you will see even more wildly varying temperatures if you swap sending units between the gauges. The gauges need certain resistance ranges in their senders for proper calibration and with the swap, they will either be much less accurate or pegged full hot or full cold.
post #15 of 17 (permalink) Old Dec 26th, 19, 1:19 PM Thread Starter
I meant I was going to just move the sending units to opposite side to see if the high temp stayed on the driver side not swap them between gauges.
Joer5000 is offline
