Edelbrock performer intake questions - Chevelle Tech
 9Likes
  • 1 Post By WakkoWarner
  • 4 Post By 68Chevele
  • 2 Post By Jim_66SS
  • 1 Post By 68Chevele
  • 1 Post By cuisinartvette
post #1 of 8 (permalink) Old Dec 12th, 19, 12:00 PM Thread Starter
Hey Folks,
I was able to get this kit
https://www.summitracing.com/parts/e...RoCQnAQAvD_BwE
From Amazon while on sale, also using my rewards points, and a gift card for a total of 378 out of pocket - it was a complex phone order lol. I have been looking into Lokar cables from summit - but here is my question.
I know I need a coolant neck, but besides that, what holes will I need to plug up on this bad boy for a 350 SBC application into my 70 Chevelle? Are there any good specific temp sensors I can get, or oil sensors? I am open to all ideas - I just know there must be open ports that I need to fill or need to use for sensors. It seems to be a popular intake so I thought I would ask you all. Thanks so much!
I found these...not sure if I need them: https://www.summitracing.com/parts/edl-8052
s1nemesis1s is offline
post #2 of 8 (permalink) Old Dec 12th, 19, 12:51 PM
Re: Edelbrock performer intake questions
The kit you purchased comes with 4 of the pipe plugs - enough to fill all four holes on the intake if necessary. You will probably only fill one of them - the one that is closest to the thermostat outlet. The one on the right side is usually used for the heater. Some people use the one on the left side for a coolant temperature sensor. The one behind the carburetor pad is what most people use for the power brakes (you will need a low height 90 fitting - if you had a Holley carburetor, you would also need a short spacer gasket so that the rear fuel bowl would clear the fitting).
s1nemesis1s likes this.
My Chevelle w/ open headers:
WakkoWarner is online now
post #3 of 8 (permalink) Old Dec 12th, 19, 4:31 PM Thread Starter
Many thanks!!! Very helpful!
post #4 of 8 (permalink) Old Dec 12th, 19, 5:26 PM
Never use steel plus in an intake manifold, they are a b***h to get out later. Always put brass plugs in. You will thank me later when you need to get them out someday.
68Chevele is offline
post #5 of 8 (permalink) Old Dec 12th, 19, 7:21 PM
Is that why the 66 original aluminum intakes all seem to have thread problem at those points?
68Chevele and s1nemesis1s like this.
Jim_66SS is offline
post #6 of 8 (permalink) Old Dec 13th, 19, 6:15 PM
Yes, those steel ones are a real pain to take out. Just this year I had an old Torker intake that had some steel square plugs in it, bought a special socket off Amazon and with no head and my new cordless gun took them right out. Never had any luck with anything work so good. Nice thing was it did not damage the threads upon removal.
post #7 of 8 (permalink) Old Dec 14th, 19, 10:07 AM
you can always buy a Tstat housing that has ports in it too if you need more
cuisinartvette is offline
post #8 of 8 (permalink) Old Dec 14th, 19, 3:52 PM Thread Starter
Bought some brass plugs and also a tstat housing with extra inlets on it as wel
You guys are golden! THANK YOU!
