Bbc forged crank with grooved mains? - Chevelle Tech
 3Likes
post #1 of 18 (permalink) Old Dec 8th, 19, 5:53 PM Thread Starter
Jani Heino
What **** is this. Any pros and cons about this grooved crank.
Janih is online now
post #2 of 18 (permalink) Old Dec 8th, 19, 7:39 PM
Re: Bbc forged crank with grooved mains?
Cons - Stress raiser!, reduced bearing area.
chrisstandring is offline
post #3 of 18 (permalink) Old Dec 8th, 19, 8:19 PM
Verle
Years ago we did this, theory being to assure better oiling to the bearings.
Ran those engines hard, shifting at 7500 RPM, never had a crank failure.
Verle
Tulsa, Ok
Verle is offline
post #4 of 18 (permalink) Old Dec 8th, 19, 9:52 PM
Mr Bill
Looks like a cast crank to me unless the photo is deceiving.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #5 of 18 (permalink) Old Dec 9th, 19, 2:44 AM Thread Starter
Jani Heino
Seller claims that this is gm forged crank,
I dont have the casting numbers yet.
Janih is online now
post #6 of 18 (permalink) Old Dec 9th, 19, 8:45 AM
have seller sell it to somebody else. That's a garbage deal left over from the 50's.
Strength of an oil film is dependent on the area. there's reasons why nobody grooves cranks or bearings anymore. good reasons,
post #7 of 18 (permalink) Old Dec 9th, 19, 10:51 AM Thread Starter
Jani Heino
Sounds great. Thats is only forged crank i have found here in Finnland that is for sale.
Janih is online now
post #8 of 18 (permalink) Old Dec 9th, 19, 11:01 AM
Can you post a few more photos, preferably of the entire crank shaft from a couple of different sides?? If we can see the parting line on it, then we can most likely determine if it is cast or forged.
My Chevelle w/ open headers:
WakkoWarner is online now
post #9 of 18 (permalink) Old Dec 9th, 19, 11:58 AM Thread Starter
Jani Heino
will post more pictures when get some.
Janih is online now
post #10 of 18 (permalink) Old Dec 9th, 19, 12:05 PM Thread Starter
Jani Heino
Tale goes like this, these were grooved by gm machinists to use in early 70s LS6 engines instead of crossthrilled cranks. can also be found from early Hardin marine bbc engines.
Janih is online now
post #11 of 18 (permalink) Old Dec 9th, 19, 1:10 PM
When did manufacturers and/or OEM start grooving the top (unloaded) main bearing shell?
Gary Adrian
Busted Knuckles is offline
post #12 of 18 (permalink) Old Dec 9th, 19, 1:54 PM
Not much help, but if you want to come to Indiana, I have a good, factory, from a running engine, never reground forged Mark IV 454 crank I'll make you a deal on.
Droptop72 is online now
post #13 of 18 (permalink) Old Dec 9th, 19, 3:07 PM
I was thinking if that groove wasn't too deep and the crank was still at standard size then maybe it could be machined out but that groove looks to be too deep to machine out.
What's the most a crank could be cut to fix some damage ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #14 of 18 (permalink) Old Dec 9th, 19, 4:02 PM
If it's a steelie, there's no reason it couldn't be welded up and turned.
71350SS and badrad like this.
Gary Adrian
post #15 of 18 (permalink) Old Dec 9th, 19, 6:40 PM
jackie
The general consensus has always been to never groove a Chevy Crank, you cross drill instead.
The older publication, “How to Hotrod Big Block Chevys” had some figures stating that you cut the load carrying capacity of the mains by as much as 30% when grooving that Main journal.
As for steel or cast, just look at the forward crank throw. If it has a large flat forge line, it’s a steel forging. If the line is really thin, it’s a cast modular iron crank.
jackie schmidt is online now
