Liquid head gasket repair. - Chevelle Tech
 7Likes
post #1 of 16 (permalink) Old Dec 3rd, 19, 12:14 PM Thread Starter
I know if a vehicle has a blown head gasket it should be replaced. However, I am wondering if anyone has ever used the products that allegedly seal the leak without clogging the engine or causing other issues such as "Steel Seal".
eagleguy is offline
post #2 of 16 (permalink) Old Dec 3rd, 19, 12:39 PM
Jon
Re: Liquid head gasket repair.
I haven't used head gasket product, but once I used product to stop a refrigerant leak. It ended up clogging a screen in the expansion valve and I had to not only replace the hose, but also the valve. If it can plug a leak it means that there is more stuff to cause problems. I would spend the time and fix it the right way.
shovelrick likes this.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #3 of 16 (permalink) Old Dec 3rd, 19, 1:54 PM
Those sealers may or may not seal, and they mess up the whole system during their futile attempts. Only as band aid for something you;re looking to sell off. And even that......
post #4 of 16 (permalink) Old Dec 3rd, 19, 2:03 PM
They don't work in most cases. The only permanent fix is to replace the gasket.
oldcutlass is offline
post #5 of 16 (permalink) Old Dec 3rd, 19, 4:16 PM
Because I'm a dirt cheap guy that was broke for most of my life, I have used a lot of..."backyard fixes" over the years. I'd never recommend others to do it, because half-assed is a great way to describe them, but they worked for me.
But gasket sealers...yes, to a degree. I've used the K&W sealer on a few motors I didn't care about, the kind where I'm planning on pulling the motor anyways, so at worst I'm out $20 and a couple hours of my time if it doesn't work. If it does, hey, maybe it gets me through the winter so I'm not freezing my berries off while pulling the motor to fix it the right way.
It worked on the small leaks. The kind where you're topping off the overflow bottle every other week or so. The leaks where you're lucky to make it to 15 miles to work without overheating...not at all.
I found it also isn't a great plan if you have modern aluminium radiators with the small tubes, as it can plug the tubes just as well as the head gasket. Same thing here for the radiator sealers. I've used that powdered aluminum radiator sealer in a lot of vehicles, and plugged a few radiators too well doing this too, lol. Once as a teenager, I even plugged a water pump with that stuff on my old Grand Am, though at that point I didn't know about weep holes on a water pump, and just kept pouring more powder in the radiator.
But same thing - worked well on the small weeping leaks, but anything bigger it didn't do anything useful, and unlike what the instructions often say, if one doesn't do it, no amount of further treatments will help.
noducksgiven is offline
post #6 of 16 (permalink) Old Dec 3rd, 19, 5:32 PM
I have used "K-Seal" on a ls 5.3 with cracked heads and it stopped drinking antifreeze. I put 8000 miles on truck after "fix" and never lost any more coolant. Sold truck but it's still seen occasionally. They have two different products available i used cheap one as I knew it wasn't head gasket.
Kirk is offline
post #7 of 16 (permalink) Old Dec 3rd, 19, 5:38 PM
Rich
Those radiator biscuits GM sells actually work pretty well, but they are typically used more as a preventative treatment than a fix it treatment. They seal well but don't cause clogs.
71350SS likes this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #8 of 16 (permalink) Old Dec 3rd, 19, 11:44 PM
leo
I'm gonna go contrary to other opinions, I have used Bar's Leak on occasion to stop cooling system/head gasket leaks. When I worked for Good Humor in the garage, we put a container of Bar's Leak in whenever we replaced an engine assembly and it never caused any problems. Your Choice!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #9 of 16 (permalink) Old Dec 4th, 19, 1:52 AM
is this a high mileage motor? Or is it freshly built? If it doesn't have lots of miles on it, then keep in mind that blown head gaskets are caused by engine knock/pinging, and also warped cylinder heads from the engine being run while overheating. So unless the head gaskets have a whole lot of miles on them, you have another problem, and you should first pull a couple of the spark plugs to see if there are dark speckles on the insulator part which would be an indication of engine knock. If that is the case, then it's time to back off on the ignition timing before you destroy the pistons or the piston rings, and use 93 octane gas if you currently use the 89 octane stuff or the 87 octane cat piss at the pump
BillyGman is online now
post #10 of 16 (permalink) Old Dec 4th, 19, 8:21 AM
We used these at the machine shop. If we ever had an engine go in a car and had a little weep at a core plug we would use them. I used them in my Nova with no issue. I think Pioneer markets them too, along with their line of core plugs!!!
bracketchev1221 is offline
post #11 of 16 (permalink) Old Dec 4th, 19, 8:44 AM
I've recently used some Bars Stop Leak with good results so far. But I isolated the heater core and put in my shop-use-only radiator so as to not bother them. Maybe it wouldn't have plugged them up but I took no chances. The regular radiator etc got reinstalled after a week of heat cycling the Stop Leak stuff and draining the system.
So far, so good. Not bad for a 28 dollar head gasket repair.
71350SS likes this.
B52bombardier1 is offline
post #12 of 16 (permalink) Old Dec 4th, 19, 8:14 PM
rkd
Ron
Have used Barrs Leaks several times in the last 50 years or so. It works.
rkd is offline
post #13 of 16 (permalink) Old Dec 4th, 19, 10:25 PM
I have used a product called "Blue devil" head gasket sealer and the first time I used after following the directions to the letter it worked as advertised and sealed the HG.Car was burning antifreeze a little at a time but not leaking it to the ground.
The second time I used it the engine had a intake gasket leak and a head gasket leak so bad it was blowing antifreeze smoke rings as it drove up to the shop.After using it the engine stopped blowing smoke as the engine idled even though it needed 2 separate repairs.
A lot of people will tell you that stuff don't work but I've used it 3 times successfully.If the HG is that screwed up probably nothing will help it but I saw that Hi-mileage 94 or something Chevy van get fixed and I would have no problem giving it a try.The thing is it may work or it may not but when you try it out do it as the directions say to do it.
For instance for the Blue Devil to work right, you have to drain ALL the antifreeze out and use water instead plus remove the thermostat to make it work right,don't skip those parts.I saw someone do it but skipped the thermostat part because he said the thermostat is open so "its not needed". it didn't work that time.
https://gobdp.com/
this is their website and I see they now have a pour and go product that's a little cheaper than the original blue devil product the one I used was around $58.and took 1-1/2 or 2 hrs running time and I put the stat back the following day.
I haven't used any kind of pour and go HG product so those I cannot recommend.
BillyGman likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #14 of 16 (permalink) Old Dec 7th, 19, 4:21 PM Thread Starter
Has anyone ever used the AC/Delco coolant tabs?
eagleguy is offline
post #15 of 16 (permalink) Old Dec 7th, 19, 6:23 PM
Rich
Read the responses in your thread.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
