oil leak on bellhousing... - Chevelle Tech
 40Likes
post #1 of 58 (permalink) Old Nov 24th, 19, 8:31 PM Thread Starter
Adam
Hey fellas, changed my oil today in my new (to me) 70 Chevelle. I noticed a pretty good amount of oil on the outside of the passenger side bellhousing and around the starter. It drips down to the bottom of the bellhousing and when driving, it looks like it's getting slung down the transmission and the rest of the undercarriage. I wanted to make sure I don't misdiagnose this as a bad rear main seal. The engine was rebuilt recently, so I wasn't expecting an oil leaks, but from research I've done on the forum, it sounds like people experience oil leaks pretty often on freshly rebuilt engines. I'm going to put it up on a lift tomorrow afternoon, but just wondering yals thoughts first. The forum seems to point to either rear main, galley plug, cam plug, or rear corner of valve covers. But with the oil being on the OUTSIDE of the bellhousing, does that rule out the rear main?? Thanks.
vtchopperdude is online now
post #2 of 58 (permalink) Old Nov 24th, 19, 9:41 PM
Vince
Re: oil leak on bellhousing...
i would look around the passenger side valve cover for oil leaking
VinceS427bb is offline
post #3 of 58 (permalink) Old Nov 24th, 19, 10:06 PM
Check the distributor gasket. I had mine leak from there. Had to double up on the gaskets but that resolved it...
Dean 1961 and vtchopperdude like this.
Stickman is offline
post #4 of 58 (permalink) Old Nov 24th, 19, 10:15 PM
Hank
It could be from the valve cover gasket, the back of the intake manifold where it seals to the block especially in the corner where the intake and head come together. If you have a BB with a passenger side dipstick it could be coming out where the tube inserts into the motor.
LeoP, jbs49 and vtchopperdude like this.
HKalin is online now
post #5 of 58 (permalink) Old Nov 25th, 19, 8:05 AM
Mr Bill
Adam,
I would get a bottle of leak tracing die at the parts store and put it in the oil. Drive it for a while and then look for the leak with an Ultraviolet light. With a fresh engine the clean oil can be very hard to see to determine where it is coming from. With the die in it and the UV light you should be able to find it pretty easily.
If it is on the outside of the bellhousing I doubt that it is the rear main seal.
427L88, blm and davewho1 like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #6 of 58 (permalink) Old Nov 25th, 19, 9:00 AM
Check the dipstick tube as well. ALSO, if using a mech fuel pump, it could also be leaking there. I've had this issue.
BillyGman likes this.
post #7 of 58 (permalink) Old Nov 25th, 19, 12:53 PM Thread Starter
Adam
Dipstick tube looks to be ok. Fuel pump looks clean. It's definitely leaking on the back side somewhere.
1970 Chevelle 454, 4 spd Muncie, 12 bolt, 3.31, AC, PS, PB, Ridler 695, Nitto 555
post #8 of 58 (permalink) Old Nov 25th, 19, 12:59 PM
Are seeing any of it on, or dripping off the flywheel/flexplate dust cover? That's where I have a leak on my car. That's why I was curious.
BillyGman is offline
post #9 of 58 (permalink) Old Nov 25th, 19, 1:07 PM Thread Starter
Adam
Adam,
Bill thanks for the advice! This was my weekend plan. Just trying to get people's advice on potential spots that are prone to leak on these motors.
I put it on my buddy's lift this morning before he opened up (owns an exhaust shop), and it's definitely wet mid way up on the bellhousing and dripping down. I noticed some RTV silicon (or similar product) at the rear of the intake manifold. It was definitely put there during the engine rebuild because it has been painted over. So, that's a potential location??
There is some leakage on the drivers side, but not nearly as pronounced as the passenger side. What's weird is none is dripping on the exhaust. I don't have any smell of burning oil, ever. But it definitely leaks more once warmed up. I notice when I start it and back it out of the garage, no drips, but after I come back from a drive, there is noticeable drips on the driveway if I don't immediately pull it in the garage over some cardboard. It runs great, so I don't think it's a major leak, for now, but I want to get it squared away before it becomes an issue. I just hate leaks!!!!!
So, I think the rear main can be ruled out. The origin is higher up. The valve covers have leaked/weeped in both Mustangs I've owned, and my dad's Willys, but not this much, so I am leery to rule them out. But, for it to leak enough to sling it down the undercarriage lends my thoughts to something that is pushing out more oil when under pressure and warmed up. The valve covers shouldn't be under pressure, right? The PCV valve is on the passenger side cover, and routed to the manifold, which looks to be correct. It does have a T fitting and splits into a much smaller tube that goes into the firewall (not sure about that....!!!). But, with it freshly rebuilt, I don't suspect the PCV valve to be the issue.
Thanks again everybody for the inputs. Looking forward to finding this pesky leak! I like the underside just as clean as the top side!!!
Thanks, Adam
post #10 of 58 (permalink) Old Nov 25th, 19, 1:11 PM Thread Starter
Adam
Yes, at the very bottom, it drips, but I believe it is coming from higher up and making it's way down to the lowest point. However, the back of the oil pan is bone dry, so if it were the rear main, then I'd expect the back of the oil pan to be drenched. Mine is not. I can reach my finger between the oilpan and dustcover and it's drity and greasy but not really oily.
post #11 of 58 (permalink) Old Nov 25th, 19, 1:12 PM
Don't rule out the rear main yet.......
blue_69_malibu is offline
post #12 of 58 (permalink) Old Nov 25th, 19, 1:19 PM Thread Starter
Adam
roger that
post #13 of 58 (permalink) Old Nov 25th, 19, 1:32 PM
Sent you a PM
post #14 of 58 (permalink) Old Nov 25th, 19, 1:55 PM Thread Starter
Adam
Sent you a PM
Got it, and replied. Did you get it??? It doesn't show in my sent box....
post #15 of 58 (permalink) Old Nov 25th, 19, 3:24 PM Thread Starter
Adam
Here are some pictures
ID:	609170   Click image for larger version
ID:	609172   Click image for larger version
