Dart pro 1 OP or brodix race rites oval ports - Chevelle Tech
 12Likes
  • 3 Post By shovelrick
  • 2 Post By Malibu ss 64
  • 1 Post By shovelrick
  • 3 Post By Malibu ss 64
  • 2 Post By Tom Mobley
  • 1 Post By Malibu ss 64
post #1 of 10 (permalink) Old Nov 18th, 19, 11:37 PM Thread Starter
Hey all, I am finishing up a little 489 build and it's time for cylinder heads. I had planned on the dart pro ones but they are just a bit more then I want to pay. The brodix race rites seem like a good choice that are about 500 cheaper per head.
My goal is 600hp/600tq for this engine. I'll be running a full roller voodoo cam. And fuel injection.
Any thoughts? Or other decent oval ports for around 1200 per head?
Binford is offline
post #2 of 10 (permalink) Old Nov 18th, 19, 11:52 PM
rick
Re: Dart pro 1 OP or brodix race rites oval ports
Get in touch with Mike Lewis aka Wolfplace
Wolfplace, Malibu ss 64 and fr8dog like this.
shovelrick is offline
post #3 of 10 (permalink) Old Nov 19th, 19, 2:01 AM
Marcus
I have a set of race rites on my 489 and it has nearly 600hp/600tq.
Bought them from Mike Lewis aka wolfplace.
https://www.lewisracingengines.com/
Only other head is same price range if alu I know of are Edelbrock or gmpp ”rovals” if you want a us made head.
Afr 265 is 200-300$ more.
Wolfplace and shovelrick like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #4 of 10 (permalink) Old Nov 19th, 19, 9:29 AM Thread Starter
Get in touch with Mike Lewis aka Wolfplace <img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
I was looking at the gmpp heads.
The afrs I was looking at was a whole extra grand.
Are the race rites you have worked over?
Otherwise what's the advantage of just buying them from summit or jegs versus Mike?
Binford is offline
post #5 of 10 (permalink) Old Nov 19th, 19, 9:34 AM Thread Starter
Also I would be interested to hear the quick specs of your whole build, cam specs/ compression, etc. As mine isn't quite done yet.
Binford is offline
post #6 of 10 (permalink) Old Nov 19th, 19, 9:52 AM
rick
My rotating assembly is from Wolfplace, "959" 4 bolt studded block alighned honed mains & cyl., .030 over for 489 ci, forged manley H beam rods, scat 4.25 forged crank, autotec/racetec forged 22.7 dome pistons, total seal rings IIRC, have to look up bearings, cams a voodoo hyd roller 231/239 .600 lift, howards max effort roller lifters and going with a set of 115 cc CNC option rec port 294 race rites from Wolfplace, should be about 10.77:1 comp., eddy rec port air gap & 850 holley
I didn't want to go big on cam I'm adding a/c next year
Binford likes this.
post #7 of 10 (permalink) Old Nov 19th, 19, 12:18 PM
Marcus
No extra work except smoothing them out in the intake ports theres a lip after the CNC in the opening. I went with CNC chambers.
He can order then with valve seals on the exhaust from summit or jegs they only have on the intake. When I bought my heads(actually have bought two sets) he was cheaper and have better customer service.
Its a 10.4:1 489 built 2007.
73 2 bolt 454 #289 block bored 030 linehoned arp studs, blueprinted melling m77 oilpump, Callies dragonslayer crank, compstar 6.385” rods, srp 18 cc pistons, perfect circle moly rings, Tci sfi flexplate, Pro race sfi,
moroso 20403 oilpan, Comp cams custom hyd roller 242 [email protected] .621 .616 112 ls on billet core with cast gear, Morel 4603 lifters, Comp hi tech pushrods, Brodix 270 cc race rite oval 115 CNC chambers, Crower endurance stainless steel roller rockers,edelbrock air gap, pro system 1000 hp. Most parts bought from Mike Lewis assembled it in my garage.
Has over 20 000 miles on it so far.
Wolfplace, shovelrick and Binford like this.
post #8 of 10 (permalink) Old Nov 19th, 19, 9:11 PM
Mike adds value by knowing all the little options available that aren't generally known. He's helped me get stuff just right several times. usually gets better prices too.
post #9 of 10 (permalink) Old Nov 20th, 19, 11:24 AM Thread Starter
I see wolfplace lurking. I wonder if he has anything to add? I'm not ready to pull the trigger on heads today. I got to get through the holidays first.
So I got some time.
Binford is offline
post #10 of 10 (permalink) Old Nov 20th, 19, 12:08 PM
Marcus
So I got some time.
Email or call him and ser what he says.
77 cruiser likes this.
