Best SBC Valve Cover Gaskets - Chevelle Tech
 3Likes
  • 1 Post By von
  • 1 Post By rkd
  • 1 Post By 77 cruiser
post #1 of 12 (permalink) Old Nov 18th, 19, 10:26 AM Thread Starter
von
Lifetime Founding Member
Von
I've always used cork but get leaks at the rear lower corner. These are the 60's/70's style heads. Are the rubber gaskets better or should I stick with cork?
von is offline
post #2 of 12 (permalink) Old Nov 18th, 19, 11:56 AM
Bruce
Re: Best SBC Valve Cover Gaskets
I've tried both. Call me old fashioned, but I'd settled on cork for the chrome factory-style Valve Covers (on cast heads). I just glue them to the Valve Covers and bolt the covers on. They've been on and off several times and I haven't had a problem.
I'm trying rubber gaskets on the cast Valve Covers (on aluminum heads) the 'Bu currently has and I see some seepage. In the spring I'll be putting cork gaskets in.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 12 (permalink) Old Nov 18th, 19, 12:17 PM
I have a set of these & no leaks in 3 yrs., but I have alum. heads with a machined surface.
https://www.summitracing.com/parts/f...make/chevrolet
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #4 of 12 (permalink) Old Nov 18th, 19, 12:28 PM
I have the vortec style heads with the raised rail and center bolts. I use the rubber gaskets glued to the valve cover which are cast aluminum, and have no leaks at all.
55 Chevy Resto Mod - Sold
99 Corvette - Sold
68 El Camino - L79 Tribute
BobinPA is offline
post #5 of 12 (permalink) Old Nov 18th, 19, 8:07 PM Thread Starter
von
Von
With that price I'll stay with cork.
potent rodent likes this.
von is offline
post #6 of 12 (permalink) Old Nov 18th, 19, 8:18 PM
rkd
Ron
I went back to cork on both the Chevelle and the Mustangs. Just Hi tack them onto the covers and they seem to work fine.
von likes this.
rkd is offline
post #7 of 12 (permalink) Old Nov 18th, 19, 8:40 PM
They came with a set of valve covers, or I may not have paid that for them either. But the covers have been off a couple times & no leaks.
von likes this.
77 Monte
post #8 of 12 (permalink) Old Nov 19th, 19, 2:04 PM
I just replaced my chronic leakers with the Fel-Pro VS 12869 T. I got them at Advance Auto.
Just torque them down as per the instructions, and watch out for the tiny (yes tiny) tab with the note the side to install nearest the push rods. No leaks for me now.
1971 Malibu Sport Coupe 350 (Lunati Voodoo 20120711 cam) / 350 / 3.31 12 bolt posi. 2-1/2 inch torque tech exhaust with walker turbo mufflers.
I love a science project that involves an auto.......
71MalibuSC is offline
post #9 of 12 (permalink) Old Nov 19th, 19, 3:23 PM
iv ran cork for years on big and small blocks with and without alum heads no leaks . make sure your valve covers are not bent
potent rodent is offline
post #10 of 12 (permalink) Old Nov 19th, 19, 8:25 PM
I have had pretty good luck with the Jeg's rubber with a steel center. Seal great.
68Chevele is offline
post #11 of 12 (permalink) Old Nov 19th, 19, 9:49 PM
Felpro and many other manufacturers make a cork or rubber with a steel insert. With my Z28 I didn't want to take off my factory finned valve covers when i went to roller rockers and used two stacked with slightly longer bolts and they gave me the clearance that I needed without any leaks for years. They stay put.
Billdini is online now
post #12 of 12 (permalink) Old Nov 20th, 19, 2:07 AM
I usually do the cork; small amount of RTV on valve cover side, and plenty of wheel bearing grease on head side. After heating up and running, the grease makes the cork VERY pliable/soft and allows it to form to the head. When you go to remove them, they pop right off, instead of sticking, tearing, and making mess.
I'd like to say it was my idea, but someone much smarter told me; works great.
540 Olds is online now
