LS3 Crate Engine or 6.0 build? 69 Chevelle - Chevelle Tech
 4Likes
  • 1 Post By Chad1969
  • 1 Post By Robinls5
  • 1 Post By JF74chevelle
  • 1 Post By cuisinartvette
post #1 of 10 (permalink) Old Oct 29th, 19, 12:46 AM Thread Starter
At the point where I need to decide to build a used 6.0 truck engine or pay up and get a LS3 crate engine? I'm leaning towards the crate engine less hassle no need for hp tuners etc. As always would be curious to hear from others who may have been down this road
69Chvll likes this.
Chad1969 is offline
post #2 of 10 (permalink) Old Oct 29th, 19, 10:10 AM
Re: LS3 Crate Engine or 6.0 build? 69 Chevelle
Not real positive. I do remember G.M. has a crate engine that is for a ( PRE) 1973 or older G.M. car. It comes with the wiring and the tranny also I believe its around a 440 H.P. engine? A friend of mine stuck one in an early vette, 60s something?
Very easy install due to the fact it was designed to " GO IN " a pre 73- " A " body. Due some research, Then open your wallet! I think the complete engine package, Engine, Wiring, tranny, Harness, needed sensors, Etc. was around 10 grand, Not sure. All of the items you do not WANT or NEED are NOT on this pre 73 G.M. " Hot Rod " package.
Way to much " Engine Stuff " is available today. If you got the Cash!
BigBlockLover likes this.
Robinls5 is offline
post #3 of 10 (permalink) Old Oct 29th, 19, 2:14 PM
I believe Robin is talking about the E-Rod system engines from GM. I saw some of these up in Charlotte not long ago. Robin's right, you get what you need and nothing you don't need. Here's a link to the engines:
https://www.gmperformancemotor.com/category/ERODE.html
"No replacement for displacement!"
BigBlockLover is offline
post #4 of 10 (permalink) Old Oct 29th, 19, 3:33 PM
Justin
No need for hp tuners. The easiest way to do an LS is terminator X. That’s the way I’m doing it. I am picking up a 6.2 short block.
JF74chevelle is offline
post #5 of 10 (permalink) Old Oct 29th, 19, 8:46 PM Thread Starter
Originally Posted by JF74chevelle View Post
No need for hp tuners. The easiest way to do an LS is terminator X. Thatís the way Iím doing it. I am picking up a 6.2 short block.
I have not really been really up to date following trends but I have been hearing good things about Hollley's Terminator X lately. Is there an advantage to ie. cost savings or anything else as to just buying a package deal LS3 crate engine? Will you be that much ahead once you've pieced everything together?
At this point its a toss up between GM Performance's 430hp or 480hp LS3 crate engine. But this Terminator X has me curious I need to explore the pros cons, cost difference.
Chad1969 is offline
post #6 of 10 (permalink) Old Oct 29th, 19, 10:48 PM
Justin
If you’re going with a crate motor just run the ECU for that motor that GM sells.
pannetron likes this.
post #7 of 10 (permalink) Old Oct 30th, 19, 3:36 PM
x2 probably no better system than the oem. Id charge up acrate before trusting a 200k mi engine, some have a little too much faith in them.
Youre still going to spend some cash either way may as well get new.
Chad1969 likes this.
cuisinartvette is offline
post #8 of 10 (permalink) Old Oct 30th, 19, 7:08 PM Thread Starter
I think I'd agree but said new LS3 crate engine $10,000 + once installed vs used 6.0 LS with Holley Terminator X engine management $5000 possibly higher? decisions decisions
Chad1969 is offline
post #9 of 10 (permalink) Old Oct 31st, 19, 1:00 AM
Justin
You can’t do an LS swap for much less than 5k if you’re willing to do more work and look for deals.
post #10 of 10 (permalink) Old Oct 31st, 19, 12:47 PM
Justin
Meant to say CAN* do for much less
