Replace Oil Pan Gasket engine in the car - Chevelle Tech
 18Likes
  • 3 Post By Flipper
  • 3 Post By langss
  • 2 Post By z27
  • 1 Post By pnugene
  • 1 Post By oldcutlass
  • 1 Post By LeoP
  • 2 Post By bry66
  • 1 Post By 68elky396
  • 4 Post By blm
post #1 of 13 (permalink) Old Oct 27th, 19, 4:00 PM Thread Starter
Bruce
I have a small oil leak on my ZZ454 Crate Engine, and I finally tracked the mother down to a split Oil Pan Gasket. Apparently I messed the gasket up when I did the cam swap (to a mild ZZ502 Cam).
How bad is it going to be to replace the Oil Pan Gasket while the engine is in the car? Can I drop the pan and snake the gasket under the oil pump pick up? Ideas? Tips? Since the transmission is a 700R4 I don't have a lot of room in the transmission tunnel to lift the front of the engine up with my shop hoist.
If I have to actually pull the engine completely out of the car, I'm just gonna swap in a 540 short block.
Our You Tube Vids:
NickeyChevelle is offline
post #2 of 13 (permalink) Old Oct 27th, 19, 4:57 PM
Phil
Re: Replace Oil Pan Gasket engine in the car
Looks like your '69 will be receiving an engine upgrade soon...
I've spent most of my money on women and guns.The rest I just wasted...
Flipper is offline
post #3 of 13 (permalink) Old Oct 27th, 19, 5:02 PM
Lang
I never like to rain on anyone's parade, but although it can be done(on a stock unmodified car) with great effort and difficulty, I'm gonna go out on a limb here and say a 540 short block is in your future.....(if that was serious).... Your going to want to lift/raise the front of the engine as high as possible, to clear the crossmember so you can get the pan far enough down to get past the front main.....Trust me when I say.... this is not a fun project doing it in the car.....Been there and done that. Maybe when someone is in their 20's with a bunch of friends helping out. But I have become a large advocate of yanking the engine in favor of the Heavily Labor Intensive Alternative. As always just my .02....
langss is offline
post #4 of 13 (permalink) Old Oct 27th, 19, 6:50 PM
Andy
I've done it. To be honest it is easier to pull it. I had to pull the tranny, remove the flex plate, out the trans back in, then I could get the pan out. Yours should be a one piece , but you still have to get the gasket over the pickup with the windage tray in the way,
Andy's Auto Repair is offline
post #5 of 13 (permalink) Old Oct 27th, 19, 10:59 PM
z27
alex
Yup! I agree with Lang ss and Andy. I have done it both ways.Iin my teens twenties and thirties when I was full of piss vinegar and extra energy it was no problem now in my late 60,s I pull everything much easierand a lot less wear and tear on the carcass. Alex
langss and boyd66k20 like this.
z27 is offline
post #6 of 13 (permalink) Old Oct 28th, 19, 12:43 AM
Randy
It may be easier to pull the body so you can raise the engine, just kidding. I had to change the oil pump on mine while it was just on the frame, and I still had to raise the engine about 18 inches so the pan would clear my flexplate/torque converter.
langss likes this.
Randy
TC # 5401
67 Project SS Clone
pnugene is online now
post #7 of 13 (permalink) Old Oct 28th, 19, 12:54 AM
Quit thinking about, it will take less time and its so much easier to pull the engine and do it out of the car. Went through this exercise this past winter.
langss likes this.
oldcutlass is offline
post #8 of 13 (permalink) Old Oct 28th, 19, 1:06 AM
leo
Pull it!!
langss likes this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #9 of 13 (permalink) Old Oct 28th, 19, 10:10 AM
Bryan
Pull it. It's the perfect time of year to do so, it'll make a good winter project. Unless your garage isn't heated, then I wish you luck!
blm and langss like this.
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #10 of 13 (permalink) Old Oct 28th, 19, 11:28 AM
I have been there, it's time to pull the engine. That's all there is to it.
langss likes this.
68elky396 is online now
post #11 of 13 (permalink) Old Oct 28th, 19, 11:40 AM
blm
Just think of the upside of pulling the engine. It will give you the opportunity to detail everything on the engine and everything in the engine bay quite easily. I think you found your winter project.
Greg P, LeoP, langss and 1 others like this.
blm is offline
post #12 of 13 (permalink) Old Nov 1st, 19, 12:21 AM
GT
A small oil leak. I'd say forget about it. let it leak.
GT is offline
post #13 of 13 (permalink) Old Nov 1st, 19, 8:12 AM
This ^^^^^
So you like oil stains on your garage floor and streaks all over the bottom of the car?.......
When I works, I works hard.
When I sits, I sits loose.
augy is offline
