ATK 383 Updated - I jinxed myself - Chevelle Tech
 8Likes
post #1 of 24 (permalink) Old Oct 17th, 19, 12:40 PM Thread Starter
I just posted an update on my new 383 from ATK about my happiness and satisfaction of the motor and jinxed myself. I’ve noticed about a quarter size oil spot in my garage the past couple weeks. I thought it was just the driver side valve cover and replaced the gasket because it was leaking a little bit from there. Yesterday, I noticed the spot was still there and saw the oil leak was coming from the rear of the oil pan. I torqued the oil pan bolts and they were a little loose. I checked this morning and the oil spot is there again. I use pieces of cardboard to make sure the spots are fresh. I don’t believe it’s the rear main seal. I’m very confident it’s the oil pan. I’m barely losing any oil on the dipstick.
Any recommendations on how to stop this leak without pulling the motor or replacing the brand new gasket it came with?
Are break in oils more susceptible to leaking?
Should I just keep it filled up until the break in period is over and hope that a regular conventional oil may help swell the gasket like the high mileage oils claim to do?
Any thoughts or recommendations are greatly appreciated! Thanks!
JerseyDevil5 is offline
post #2 of 24 (permalink) Old Oct 17th, 19, 12:48 PM
Re: ATK 383 Updated - I jinxed myself
No, leaks don't fix themselves by changing oil. I would call ATK and see how they want you to proceed. Don't risk your warranty.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 24 (permalink) Old Oct 17th, 19, 12:49 PM
are you using synthetic oils?
Marc S
71 SS 454 ELCO
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #4 of 24 (permalink) Old Oct 17th, 19, 12:53 PM Thread Starter
I’m using their recommendation of Joe Gibbs BR40 break in oil. I have a little over 100 miles on it.
I didn’t think a regular oil would solve this issue, but was wishfully thinking.
Thanks!
post #5 of 24 (permalink) Old Oct 17th, 19, 1:32 PM
Mr Bill
JD,
I would put some die in the oil and run it for a while longer. Then use a UV light to make sure where it is coming from. Clean oil in a new engine can travel a long distance but always seems to end up near the back. Is there a bolt in the hole in the front of the block that goes to the fuel pump pushrod ?
Name:	Fuel pump bolt.jpg
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #6 of 24 (permalink) Old Oct 17th, 19, 2:31 PM Thread Starter
JD,
Yes, I have the ground from my alternator attached right at that spot. The oil is very clean, so I’ve been feeling for it with my bare hands. I can see exactly where it’s coming from and it’s right at the back of the oil pan where it meets the rear main seal. Before I put the motor in, I considered replacing the pan and gasket with higher quality ones since it was already out, so I wouldn’t have to worry about it down the road. Hindsight’s always 20/20, they say!
post #7 of 24 (permalink) Old Oct 17th, 19, 2:42 PM
It's a brand new crate motor. You shouldn't have to change....anything.
Good luck. Oil leaks.....are not fun.
BTW: Pre-1987 or post 1986 block?
blue_69_malibu is offline
post #8 of 24 (permalink) Old Oct 17th, 19, 2:50 PM Thread Starter
I agree 100%. I shouldn’t have to deal with leaks on a brand new motor. I don’t want to have to do all of the work to replace the gasket. Since I installed the motor myself, I think the most I would get from ATK is a replacement gasket.
It’s a post 86 block.
Thanks!
post #9 of 24 (permalink) Old Oct 17th, 19, 2:58 PM
You think. Contact them and you'll know.
Then we can help you make a good plan.
70 Camino...Roller
post #10 of 24 (permalink) Old Oct 17th, 19, 3:06 PM
Mr Bill
Originally Posted by JerseyDevil5 View Post
Itís a post 86 block.
I am surprised. Those gaskets are typically pretty bulletproof
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
post #11 of 24 (permalink) Old Oct 17th, 19, 3:42 PM Thread Starter
It may just be me, but shouldn’t the oil pan/gasket cover a little more under the real main seal? Is everyone able to see where it’s leaking at? I know the pictures aren’t the best.
ID:	605702   Click image for larger version
ID:	605704   Click image for larger version
post #12 of 24 (permalink) Old Oct 17th, 19, 3:47 PM
Just curious - are you missing a nut on that torque converter bolt in the third picture??
My Chevelle w/ open headers:
WakkoWarner is offline
post #13 of 24 (permalink) Old Oct 17th, 19, 3:50 PM Thread Starter
Here are a few more. It seems like the lip of the pan is bent inwards and not covering the full surface that it should. I could be completely wrong though. What does everyone think? This is 100% where the leak is coming from.
ID:	605708   Click image for larger version
ID:	605710   Click image for larger version
post #14 of 24 (permalink) Old Oct 17th, 19, 4:21 PM
Mr Bill
Unless I am totally out of it . . . . that is not a late model block. That is a pre 1986 two pc rear main seal block. At least it sure looks like it from the pictures. I can see the flange on the crankshaft that the flexplate bolts to.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
post #15 of 24 (permalink) Old Oct 17th, 19, 4:23 PM
Mr Bill
I might be wrong that might be the seal holder I am looking at.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
