Picking up a 400 SBC - Chevelle Tech
 73Likes
post #1 of 87 (permalink) Old Oct 15th, 19, 5:17 PM Thread Starter
Got an opportunity to pickup a 400 SBC tomorrow for 500 dollars.
What should I be looking for?
Motor is all together and running on a stand. It was on a airboat for a short while. Was bought from a guy who built it with a RV cam. The owner knows very little about it. It has stock heads on it and the bore is unknown.
I figure it might be worth picking up since Im thinking of building a 406 or larger for my 67.
Aaron is offline
post #2 of 87 (permalink) Old Oct 15th, 19, 5:48 PM
Re: Picking up a 400 SBC
I have had several 400 SBC over that last few years but you can't get anything for them now with the big LS craze. Look for the 2 bolt mains as they are stronger for any kind of performance build being able to use splayed main caps. Most 400's respond well to the same add on's as any other SBC. Put some Vortec heads on it and the 400 will fly, just have to use good fuel as the compression can be close to 11. to 1 and that can get costly. I have one 400 that has some stock 80cc heads, 268 CC, Performer RPM with cheapo headers and a good carb, that motor just flat out fly's to 5500 rpm. My 12 to 1 406 has gone the best of [email protected]
Aaron, 68post and badrad like this.
68Chevele is offline
post #3 of 87 (permalink) Old Oct 15th, 19, 5:50 PM Thread Starter
68Chevele - just looking to build a strong street engine...nothing more...need to run pump 93.
68Chevele likes this.
Aaron is offline
post #4 of 87 (permalink) Old Oct 15th, 19, 6:49 PM
hi
Have block crack tested around head bolt and steam holes at least .
Sonic test bores .
Felpro do a high water flow gasket from memory that's recommended.
Always run steam holes in heads
Piston selection is better than ever re street forged, weisco pro tru street, mahle power pak . Try to use a combo with at least 5.7 length rods .
Balancing try to shoot for internal is preferable . Either use adapter bearings for 350 crank/ stock 400/ after market cast or forged steel
A pre balanced rotating assembly is best for the budget
Aaron and vortec710 like this.
swampy 6x6 is online now
post #5 of 87 (permalink) Old Oct 15th, 19, 6:51 PM Thread Starter
Motor is complete right now...running on a stand...anything to look for in a running motor that is different from other SBC's?
Aaron is offline
post #6 of 87 (permalink) Old Oct 15th, 19, 7:07 PM
Hi
compression test --only an indication
leak down test closer to 10% leakage the closer to rebuild time [2-5% when new ]
oil pressure test---what is the oil grade ?
what do the spark plugs look like
colour and smell of oil
condition of coolant
Inside a valve cover is there sludge
post #7 of 87 (permalink) Old Oct 15th, 19, 7:37 PM Thread Starter
Got those covered.
Aaron is offline
post #8 of 87 (permalink) Old Oct 15th, 19, 7:44 PM
I assume it is a dry set up with no water in the block. It would be nice to see it hold water and not leak thru the head gaskets or blow white smoke when it runs. Maybe you could rig up a water pressure test. I wish you were in Ohio. I have one I would sell.
Aaron and B52bombardier1 like this.
69SS454 is offline
post #9 of 87 (permalink) Old Oct 15th, 19, 8:25 PM
I like the 400 small block because it make good torque, seat of the pants feel. Unfortunately the one I picked up last month turned out like this:
Now deciding if I go back to the 383 I started, or go with a 6.0 LS that my son keeps pushing me towards.
1975TypeS-3 is offline
post #10 of 87 (permalink) Old Oct 15th, 19, 8:27 PM Thread Starter
What happend to the 400?
Aaron is offline
post #11 of 87 (permalink) Old Oct 15th, 19, 8:46 PM
Really do not know! It was a decent looking block, but I always have the cracked checked before I get into machining. I have found ones that had froze and cracked the valley near the head surface like you see here, but this crack is towards the bottom of the water jacket. I still have a good 4-bolt 1970 350 block that is bored .030 over and oiled down, I know that is a good block, but I really wanted a 400. Might get a Dart SHP block because by the time I purchase another 400 block, clean and crack check ($140 in our area), line hone, parallel deck, bore and hone I will be close to the cost of a new SHP block!
Aaron and 68post like this.
post #12 of 87 (permalink) Old Oct 16th, 19, 6:35 AM
Hi
The reality is with a 400 block . They are only worth money if they have been bored no more than .020 bored .These days pretty rare . As we have said once u sonic test bores , crack test block and machine . An aftermarket block is only a little more . The biggest benefit is thick cylinder walls. Prevents overheating .. Resale will always be better also.
Other 400 setups
Do blueprint sell blocks only . They do sell a short.
Edelbrock sell blocks
Brodix and Dart are probably more $$
post #13 of 87 (permalink) Old Oct 16th, 19, 7:47 AM
jimmyradford
I love SB 400s and had one in HS. It ran hard too. If you update it, I'd look into longer rod/lighter piston set ups because the crank is already heavier than normal. The main webs crack and drop the crank into the pan when it goes bad. Lots of guys ran them dirt track while I was drag racing min and that was the biggest issue.
TC Member # 4431
'16 GMC Denali XL- 6.2L's are sweet
'07.5 Chevrolet 2500HD-6.6 D-Max
'07.5 Chevrolet Suburban
'67 Chevrolet Biscayne- SS427 L-36/TH400/10 bolt (Hers)
'67 Hell Camino-BB 427/TH400/4.10 (His)
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is offline
post #14 of 87 (permalink) Old Oct 16th, 19, 3:02 PM
I understand completely, just use some 993 heads or the ones on my one 400 487X (X means 80cc not a special port) heads, that engine is 8.8 compression but still went really well. Best part is it ran on 87 oct.
post #15 of 87 (permalink) Old Oct 16th, 19, 4:39 PM
I had a .030Ē over 400 in my 70. Forged pistons, stock rods & heads RV cam. All I can say is I really miss all of that torque.
67
70 (SOLD)
Alwhite00 is online now
