Picking up a 400 SBC - Page 6 - Chevelle Tech
 73Likes
post #76 of 89 (permalink) Old Dec 4th, 19, 4:31 PM
Re: Picking up a 400 SBC
I use Dem-Kote class F red insulating enamel. I got a spray can of it at a nearby electric motor rebuilding shop. It's what they use on the insides of electric motors. I've done 3-4 engines with the same can. It covers well and I've never had any come off.
nitrofox is offline
post #77 of 89 (permalink) Old Dec 4th, 19, 4:48 PM
Tom, Glyptol or some other paint?
Dupli Color rattle can, Chevy orange from O'Riellys.
This paint is over 20yrs old.
ID:	610002   Click image for larger version
mr 4 speed likes this.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #78 of 89 (permalink) Old Dec 5th, 19, 2:30 AM
Originally Posted by Aaron View Post
The casting numbers on the heads I took off are 462624.
C& P'ed from link below:
462624
350
76-87
1.94/1.50 or 2.02/1.60
76cc Crack prone
Chevy Casting Number identification - Block casting numbers
good link with lots of OEM Chevy numbers
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #79 of 89 (permalink) Old Jan 25th, 20, 2:50 PM Thread Starter
Wanted to give you my update on my 400 sbc find.
Yes, it was a virgin bore 400. Full deck height.
Everything looked real good on first inspection.
Had NO cracks in the usual spots on the 400.
The machinist sent it to the hot tank and it came back looking real good.
Upon inspection of the caps, he found that the oil pump main had cracks in it and another crack in the bolt boss.
So...its no good.....back to square one. Have less than 800 in this block, but its less than 800 down the tubes....
Should of just saved an bought an aftermarket block. Would have a good chunk of that done.
Aaron is offline
post #80 of 89 (permalink) Old Jan 25th, 20, 3:37 PM
Bummer.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #81 of 89 (permalink) Old Jan 25th, 20, 3:41 PM Thread Starter
Originally Posted by 77 cruiser View Post
Bummer.
Your right about that!
Machinist said it looked like a redneck had overtorqued some bolts......
Aaron is offline
post #82 of 89 (permalink) Old Jan 25th, 20, 4:12 PM
I have an old 400 std. bore engine in the garage that has a 268H CC cam performer RPM and has 487X heads. Will run on 87 oct. and goes like a bat out of hell for a mostly stock 400. Was going to sell it but I am doing a 406 testing this year and I might clean it up to toss it in the race car just to see what it runs for the 1st. test then go to the good 406 next. Would make for a great youtube videos.
shovelrick likes this.
68Chevele is offline
post #83 of 89 (permalink) Old Jan 25th, 20, 11:31 PM
I feel your pain!
As I mentioned earlier, I am done buying 400 factory blocks - I will go with a Dart SHP instead. In my area, if the block checks out ($125 for a clean and crack check) you still have another $600 in machining - add to that the cost of acquiring the block and you typically have $1,000 if not more into a factory block. If you can find a Dart blem block, the can be had for $1,300 and it is a better block.
I did acquire another 400 a couple of months ago, but it was motivating the truck I purchased. I bought the truck because it was a 1978 GMC from Arizona and has a solid body, it just happened to have a 1972 400 under the hood (original 350 truck). I am not hopeful that the engine is useful, I know it blew head gaskets twice before I got it, it has a 1973 - 350 head on one side and a 1972 - 400 head on the other, have not torn it down enough to see if steam holes were put in the 350 head. There was no antifreeze in the oil when I drained it, but there was oil in the cooling system!
I currently have a 1974 - 350 I rebuilt myself that is still on a stand ready for break-in. My current plan is to put that engine in the GMC, but there is that side of me that wants to check out the 400 before I condemn it. At this point I will not even consider selling the 400 until I have it torn down and crack checked - if it is good I can sell with confidence, if not I saved someone from being mad at me! If it does turn out good, I can see I may want to rebuild it and use it in the truck - torque is my friend in that chassis.
As for my Chevelle, I am dusting off a 427 big block I had laying around to put in my sons 1966 Caprice - he is selling the Caprice and I am not selling the 427 with it!
1975TypeS-3 is offline
post #84 of 89 (permalink) Old Jan 26th, 20, 12:13 AM
George
Sorry to hear it. Thats the way my luck goes normally.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #85 of 89 (permalink) Old Jan 26th, 20, 12:30 AM Thread Starter
Yep! It is what it is George. I hate to say that old of the old blocks are starting to show their age....
Aaron is offline
post #86 of 89 (permalink) Old Jan 26th, 20, 4:19 AM
Hi
yup
the old 400 blocks are showing there age now . Mainly because they have done a lot of miles [corrosion] but still many have failed due to poor repairs DOH !!! . If u don't no how to do something ask or send it to the machine shop --simple really..
Aaron
there have been many articles about block prep and u discovered why . Thankfully the issues were discovered .
The after market blocks have way way thicker bores . The articles mention bores as thin as .090 on production blocks !!!!!
Pinch point or MCSA min cross section area IS KING . Port volume follows next ,then valve size
On a 400 cuin
port size of 1206 gasket is best
2.08 valve size minimum
afr 195 competition head 1.9 pinch [street version does not flow enough] the comp version is a little small but ok for 383
afr 210 comp 2.1 pinch
Brodix 215 cc heads have a reasonable flow. MCSA?? approx. over 2.1 ?? Brodix don't tell ya
difference between 195 vs 210 head is 10-15 hp
biggest gain is inlet manifold change 20hp
biggest cam 230/236 or 236/242 HR for street mainly for brake vacuum
peak hp 5800---6100
242/248 seems to be common . Peak hp 6100---6300rpm Dart 215 heads
Afr 220cc comp heads 2.180 pinch 2.1 valve and make power to 6500rpm with 250/260 SR cam
afr227 comp 2.3 pinch ,,,,valve=2.1 shaft rockers required 260++ SR cam 6700--6800 peak 13:1 CR 640hp
Remember the chevy port must be inefficient as smaller ports can flow better in other brands .
Ford Windsor AFR 200cc head with 2.160 PINCH makes a ton of hp on a 408 240++HR
swampy 6x6 is offline
post #87 of 89 (permalink) Old Jan 26th, 20, 7:57 PM
George
Yeah I couldnt roll the dice on one or spend the $$$ on an aftermarket block...LS was the way for me to go. Hopefully it was a good decision in the end...
'71 Malibu
Geo71 is offline
post #88 of 89 (permalink) Old Feb 1st, 20, 1:49 PM Thread Starter
Picked up my block today and I have a question.
I didn't ask my machinist about this, but he indicated its very expensive and kind of pushed it aside, so I didn't inquire more. He doesn't have the machine to do the job anyways.
I think the block itself is ok, its just that rear main cap that has the damage and cracks to it.
I already have the studs of the block.
Can I just replace the rear main cap? Im not building a racer here. Just a stout cruiser at around 550 horse.
If so, how much would I be spending on making this repair?
Aaron is offline
post #89 of 89 (permalink) Old Feb 1st, 20, 2:21 PM
Yes you can just replace the main cap and take a chance, but it may need to be line honed. Cheaper to just get another block.
