Engine block pad decode help - Chevelle Tech
 2Likes
  • 2 Post By BillK
post #1 of 13 (permalink) Old Oct 14th, 19, 4:51 PM Thread Starter
I have searched everywhere for this. I found all the other codes but not the engine im looking at.
Long story short I am in the process of purchasing a Chevelle and one I am looking at has the code T0211GBG. I cant find the GBG anywhere. Its a Chevelle SS tribute vehicle.
The number is correct as I have a picture of it.
Any help would be appreciated!
z28wiz is offline
post #2 of 13 (permalink) Old Oct 14th, 19, 5:04 PM
Mr Bill
Re: Engine block pad decode help
What is the casting number of the block ? Are you sure it isnt CBG ?? That is a 71-72 454 code.
buenymayor and Saltherring like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 13 (permalink) Old Oct 15th, 19, 10:40 AM Thread Starter
I will look for that and its definitely the numbers and letters I posted above. I talked to a chevy parts dept, and they said it could possibly be a fleet truck block. They were stamped differently. Don't know how true that is.
z28wiz is offline
post #4 of 13 (permalink) Old Oct 15th, 19, 1:21 PM
Mr Bill
What engine do you think it is and what year car ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #5 of 13 (permalink) Old Oct 15th, 19, 1:31 PM Thread Starter
Well it’s 1970 Malibu which was made to
a Chevelle ss ls5 clone. It’s for sure a 454. Just trying to figure which block?
z28wiz is offline
post #6 of 13 (permalink) Old Oct 15th, 19, 1:48 PM
Mr Bill
I bet it is CBG or supposed to be. Dont discount the fact that mistakes were made at the factory. Humans more than likely set up the stamps and a G looks almost like a C See what the casting number is and the date code.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 13 (permalink) Old Oct 15th, 19, 1:57 PM
jimmyradford
I downloaded the pic to blow it up. That's GBG for sure but possibly meant to be CBG? I couldn't find anything on it.
TC Member # 4431
'16 GMC Denali XL- 6.2L's are sweet
'07.5 Chevrolet 2500HD-6.6 D-Max
'07.5 Chevrolet Suburban
'67 Chevrolet Biscayne- BB 427/TH400/10 bolt (Hers)
'67 Hell Camino-BB 427/TH400/4.10 (His)
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people. And they are more useful in general.
badrad is offline
post #8 of 13 (permalink) Old Oct 15th, 19, 2:54 PM
Al
That's a newer block produced much later than 1970. Get the casting date and casting numbers off the block. Check the pad behind the alternator for additional stampings. Get the casting numbers and dates for the heads and we'll be able to tell what heads you have, To get the head info, you'll have to remove a valve cover.
ID:	605524   Click image for larger version
post #9 of 13 (permalink) Old Oct 15th, 19, 5:09 PM
Mr Bill
By the way, where exactly is the number stamped on the block ? Trying to figure out your picture and drawing a blank.
Never mind I figured it out. I have a later model Mercruiser block here that is stamped in that spot.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 13 (permalink) Old Oct 15th, 19, 6:10 PM Thread Starter
I’ll try and get the other numbers when I go see the vehicle again.
The numbers stamped are T0211GBG.
So I assume it’s a boat engine?
z28wiz is offline
post #11 of 13 (permalink) Old Oct 15th, 19, 6:10 PM
Al
Here's a photo of later blocks. They have a machined circular surface just above the timing chain cover(upper arrow). Many will have the con VIN stamped on the pad behind the alternator or as depicted by the lower arrow. The numbers on the pad are often lost when the block is decked. The font on the circular pad is much smaller on the engines I have here as compared to the ones shown by the op.
T0211GBG = Tonawanda block. The 0 is most likely 1980 or 1990 because 70 blocks did not have the circular pad above the timing cover. Casting numbers and casting date will help narrow it down. Like the others, I can't find GBD listed in any sources. I con vin might narrow the original application-if found.
post #12 of 13 (permalink) Old Oct 15th, 19, 6:24 PM
Al
My eyes might be playing tricks on me, but check to see if there are other smaller stamped in numbers above the large stampings we can see fairly well in your photo. Many boatbuilders used over the counter crate engines marked XXA which was a near equivalent to an LS6 engine.
post #13 of 13 (permalink) Old Oct 15th, 19, 8:20 PM
Mr Bill
Not at all. The block I have happens to be but those blocks were used more in trucks and cars than boats. A marine engine would have a totally different code.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
