EFI 4 bbl conversion questions - Chevelle Tech
post #1 of 3 (permalink) Old Oct 14th, 19, 12:19 PM Thread Starter
I'm planning on doing the EFI 4 bbl kit on my 64 Chevelle. 350 crate motor, mild cam, roller rockers, gear drive, quick fuel carb, I'm thinking around around 300-330 HP. Running a 700R4 trans. Motor/Trans are pretty new, only has 1170 miles on it.
Questions are-
1. Which kit is better between Holly Sniper and FITECH and Why?
2. If i do a LS swap later on, is the FI kit compatible with the LS engine if I run
a 4 bbl LS type manifold ?
3. What's the best way to tap the return line into existing fuel tank? Or is it
easier/better to get a new EFI tank?
4. Anybody who has done the swap, how good is the hand held tune
computer software that comes with the kit?
I've done a search, but cant find some of the answers for my questions. Thanks for any advise!
joegio is offline
post #2 of 3 (permalink) Old Oct 14th, 19, 5:44 PM
Re: EFI 4 bbl conversion questions
Questions are-
1 Personal Preference/Budget I guess
2 I think so but I'm not a LS guy
3 This I can help with. Whatever you do, use an intank pump with return line in the sender, then what I did was use a Corvette LS filter/regulator that has return line from it, so only 1 line to the front of the car. I swapped out to a 1995 B Body plastic 23 gallon tank and used all of it's pump/fittings.
4 better than me, I really don't mess with it, and just drive it. It isn't perfect, but far better than it was with the carb, and it was OK with the carb before the swap.
Pioneer4x4 is offline
post #3 of 3 (permalink) Old Oct 17th, 19, 12:33 AM Thread Starter
Thanks for the info!
joegio is offline
