What is this linkage? Do I need it? - Chevelle Tech
 2Likes
  • 1 Post By Jim Mac
  • 1 Post By oldcutlass
post #1 of 8 (permalink) Old Oct 12th, 19, 5:08 PM Thread Starter
Dillon
I am working installing a new intake and carb. No clue what this linkage is for or its purpose. Currently there is no attachment for it on new carb. It was attached to post with throttle return springs.
ID:	605344   Click image for larger version
D16136 is offline
post #2 of 8 (permalink) Old Oct 12th, 19, 5:23 PM
Re: What is this linkage? Do I need it?
That linkage on the right with the slot? It's for the kick down on your TH350 transmission.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #3 of 8 (permalink) Old Oct 12th, 19, 5:39 PM Thread Starter
Dillon
It won’t reach the new carb linkage. Should I install an extension? I assume it is supposed to extend as throttle is applied?
D16136 is offline
post #4 of 8 (permalink) Old Oct 12th, 19, 6:04 PM
You may need to mod the bracket and buy a stud kit. It extends all the way at full throttle.
oldcutlass is offline
post #5 of 8 (permalink) Old Oct 12th, 19, 9:06 PM
https://www.googleadservices.com/pag...CABEgLtiPD_BwE
Dean 1961 likes this.
Jim Mac is offline
post #6 of 8 (permalink) Old Oct 13th, 19, 10:13 PM Thread Starter
Dillon
Exactly what I needed!
D16136 is offline
post #7 of 8 (permalink) Old Oct 13th, 19, 11:32 PM
That's not exactly what you need, you need a throttle cable bracket that will move everything closer to the carb and the proper studs on the carb.
https://www.jegs.com/i/JEGS/555/157336/10002/-1
LeoP likes this.
post #8 of 8 (permalink) Old Oct 14th, 19, 8:33 AM Thread Starter
Dillon
wow 36$ for a bracket. This does look like a better option and allows adjustments for both throttle and lockdown. My throttle reached fine but I like the idea of having both cables on one bracket.
D16136 is offline
