Q-jet pic of interest - Chevelle Tech
 11Likes
post #1 of 18 (permalink) Old Oct 9th, 19, 7:53 PM Thread Starter
I've gotten several questions and requests about the 800 CFM Q lately. Here's a pic
of the difference the 750 and 800 CFM versions of the Q. Personally, I've flowed several Qs and would rate them as 730CFM but that rounds off to 750 and sounds better. In the real world you have to know what you're looking for and have good light to see the difference.
jeff swisher likes this.
post #2 of 18 (permalink) Old Oct 10th, 19, 5:07 AM
von
Lifetime Founding Member
Von
Re: Q-jet pic of interest
Have you flowed the larger 800 cfm version?
von is offline
post #3 of 18 (permalink) Old Oct 10th, 19, 10:23 AM
Jon N.
I have heard the 800 cfm versions were only on Cadillac's and Chevy trucks. Anyone know for sure?
dyno jonn is offline
post #4 of 18 (permalink) Old Oct 10th, 19, 1:30 PM
I believe it was around 1975 that GM went to the larger body with APT and up the size from 750 to 800 cfm. Some of the earlier 800 cfm units were on Pontiac 455 HO's, many of the Buick 430's and 455's. The Chevy trucks held on to the 750 cfm units through 1978 still using the divorced choke. A really good 800 cfm q-jet to get your hands on is carb # 10785212 used on mid to late 1980's HD emissions 454's and motorhomes.
1975TypeS-3 is offline
post #5 of 18 (permalink) Old Oct 10th, 19, 2:18 PM
What makes it desirable?
And - do you have any pics of your S-3?
77 cruiser likes this.
David
davewho1 is offline
post #6 of 18 (permalink) Old Oct 10th, 19, 2:37 PM
They were set up from the factory for big block towing applications, and can be upgraded to performance easily. In normal driving they do not get as heavily into the secondaries improving the economy (mpg's) and low end torque.
I do have a couple pic of my S-3, pretty plain jane white
Will soon start a restoration, the body guy I am working with might have time to get to it this winter. In the mean time am deciding what direction to go with it.
davewho1, 427L88 and GuysMonteSS like this.
post #7 of 18 (permalink) Old Oct 10th, 19, 2:57 PM
Thumbs up Re: Q-jet pic of interest
Good info to know - thanks!
Nice car - I've always liked those.
I really like what Justin has done with his, but YMMV.
https://www.chevelles.com/forums/11158444-post23.html
David
davewho1 is offline
post #8 of 18 (permalink) Old Oct 10th, 19, 3:19 PM
Justin
Good info to know - thanks! <img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
Nice car - I've always liked those. <img src="https://www.chevelles.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
I really like what Justin has done with his, but YMMV. <img src="https://www.chevelles.com/forums/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Thank you, I really appreciate it. The paint it beat and rough because I painted it when I was 17 and really didn’t do a great prep job. I cared more for performance. But, when I got the car when I was 15 it was stock with the exception of a 270h cam, and flowmaster dual exhaust. Had it’s original Quadra jet and everything.
427L88 and davewho1 like this.
JF74chevelle is offline
post #9 of 18 (permalink) Old Oct 10th, 19, 3:51 PM
Very cool Justin!
Tom, I've searched for the big primary bore Chevy carbs for a while years back, and all I ever found was Olds/Buick ones with the inlet snout in front. I thought someone also told me the 800 cfms have 1 or 2 more screws in the top. "13 screw top"... maybe?
post #10 of 18 (permalink) Old Oct 10th, 19, 4:51 PM
Guy
I always liked those Laguna S-3's,very nice !!!
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #11 of 18 (permalink) Old Oct 10th, 19, 7:27 PM
Chevy Trucks sure did, have the 800 Q-jet of a 454 from 1975 in the garage.
68Chevele is offline
post #12 of 18 (permalink) Old Oct 10th, 19, 7:33 PM
Very cool Justin!
The bowl vent is at a 45* angle rather than flat
post #13 of 18 (permalink) Old Oct 10th, 19, 7:38 PM
Guy
I have wanted one for years, fond this one two years ago! California car in Michigan, is original right down to all of the pollution equipment. Engine is showing it's age and is in bad need of a rebuild. I will most likely pull the original engine and trans and put in the corner of my shop, I have a 383 ready to be assembled, and a 427 short block already assembled, my son thinks I should do an LS swap!
GuysMonteSS likes this.
post #14 of 18 (permalink) Old Oct 10th, 19, 7:38 PM
Doesn't have to be a 454 I have some 800's from 79 on up. One was off of my 84 truck with a 305. The latest is a 85.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #15 of 18 (permalink) Old Oct 10th, 19, 7:47 PM
