Fuel Pump and Spark Plug Recommendation - Chevelle Tech
 4Likes
  • 1 Post By Dave Ray
  • 1 Post By mr 4 speed
  • 2 Post By Tommy the Cat
post #1 of 14 (permalink) Old Oct 1st, 19, 9:47 PM Thread Starter
I finally got the motor and trans in the car so now it's time to start bolting on some parts. It's a 468 BB, hyd roller, steel 702 heads, 850 Holley that should be in the mid 500 HP range. This will be a street car.
#1, I am looking for a mechanical fuel pump that will work with both the supply and return fuel lines. I want a pump as stock looking as possible. I believe a 100 gph pump would work.
#2, I need a recommendation on what spark plugs I should use and what the gap should be. I will be using an HEI distributor.
Thx in advance for any suggestions.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #2 of 14 (permalink) Old Oct 2nd, 19, 8:29 PM
Re: Fuel Pump and Spark Plug Recommendation
NO ignition system should have any larger than .045 MAXIMUM spark plug gap, including EVERY HEI ever produced.
What compression ratio will the engine be, please?
LeoP likes this.
Dave Ray is offline
post #3 of 14 (permalink) Old Oct 2nd, 19, 10:21 PM Thread Starter
10.5:1.
Thx Dave.
1970 SS396 Chevelle
SS468 is offline
post #4 of 14 (permalink) Old Oct 3rd, 19, 9:02 AM
Look at the Carter musclecar pumps, they look stock but flow a little bit more than a stock pump.
FWIW, I have run high 11's in the 1/4 mile with nothing more than stock replacement 40727 fuel pump.
427L88 likes this.
mr 4 speed is offline
post #5 of 14 (permalink) Old Oct 3rd, 19, 9:07 AM
Here is a stock looking pump that flows 110 gph for about $26.00
https://www.jegs.com/i/JEGS/555/15961/10002/-1
I would go with E3 Diamond Fire Plugs.
https://www.jegs.com/p/E3-Spark-Plug...57739/10002/-1
ZEN357 is offline
post #6 of 14 (permalink) Old Oct 6th, 19, 11:41 PM Thread Starter
Thx guys for the suggestions.
1970 SS396 Chevelle
SS468 is offline
post #7 of 14 (permalink) Old Oct 7th, 19, 8:30 AM
Re: Help with new crate engine overheating
For 500 hp you need at least the Carter 110 gph.
NGK plugs is all I use anymore. Not Chinese ACs or Autolites. Unsure of the 702 heads seats for a part #.
I gap plugs at 043 for MSD use .
post #8 of 14 (permalink) Old Oct 12th, 19, 11:28 AM Thread Starter
Does a 110 gph mechanical pump require a regulator? Thx
1970 SS396 Chevelle
SS468 is offline
post #9 of 14 (permalink) Old Oct 12th, 19, 12:49 PM
My 496 is running an LS6 replacement AC pump. It has a return line and supplies plenty of fuel. Looks stock because it is stock. I recommend NGK GR5 plugs gapped no more than .045.
70 Camino...Roller
Tommy the Cat is offline
post #10 of 14 (permalink) Old Nov 11th, 19, 10:30 PM Thread Starter
Tom, I see in your signature that your 496 is putting out 628 HP. How does an LS6 pump supply enough gas for that beast if the 454 was rated for almost 200 less horsepower? I'm not questioning your setup just trying to educate myself.
Thanks, Chris.
1970 SS396 Chevelle
SS468 is offline
post #11 of 14 (permalink) Old Nov 11th, 19, 10:52 PM
Thanks, Chris.
Well, folks will tell you the LS6 was underrated by a whole lot for starters. Beyond that.. I don't know. All I can tell you is that this Carter pump (in my post earlier I said it was an AC) supplies 7 pounds from a stand-still to 6,000 RPM in high gear. All the lines, sending unit and switching valve are stock. 3/8" feed, 1/4" return. I was going through a lot of more expensive pumps and I think the stock pushrod might be a factor so I got a lightweight one and installed it with this cheap factory replacement pump and my fuel delivery problems vanished.
I just had the receipt in my hand and I recall the pump cost about $33 in 2015-ish. I'll post the part number when I get home. I have been planning a switch to EFI so the cheap pump was supposed to be just to get me by.... Turns out it's the best one I've had in the truck and I'm still having fun goofing with carbs.
LeoP and boyd66k20 like this.
70 Camino...Roller
post #12 of 14 (permalink) Old Nov 11th, 19, 11:58 PM
Here is the pump I'm using-
https://www.jegs.com/i/Carter/180/M6102/10002/-1
And, of course, it's $3 cheaper now than when I bought mine...
70 Camino...Roller
post #13 of 14 (permalink) Old Nov 12th, 19, 10:17 PM Thread Starter
Thx Tom for the explanation. I will be buying this pump. My cam calls for a bronze tip fuel pump pushrod so I plan to buy that as well.
1970 SS396 Chevelle
SS468 is offline
post #14 of 14 (permalink) Old Nov 13th, 19, 5:14 PM
NGK and Auto-Lite are great spark plugs.
E3, I have had nothing but bad news with them, they shroud the spark way too much, and fully empty wallets for a mediocre, to just plain useless part.
Spark plug heat ranges ARE NOT set by ignition systems, they are set by engine parameters, mostly compression ratios.
Plug gaps are set by the emissions level of the engine, and/or the processor type. An HEI, NO MATTER THE COIL, .045 MAXIMUM. MSD, .045 maximum. Engines with serious compression ratois would need less spark plug gap to overcome the compression resistance (a function of the compression ratio) in the chambers.
Dave Ray is offline
