496 pro comp oval port hp# - Chevelle Tech
 9Likes
  • 2 Post By greensahara
  • 1 Post By 68Chevele
  • 1 Post By greensahara
  • 3 Post By greensahara
post #1 of 12 (permalink) Old Sep 15th, 19, 7:29 PM Thread Starter
jason
i had done some searching a long time ago when i was building this bbc. I was trying to see if i could find hp potential with the pro comp large oval heads. I started out just wanting to re-gasket and change the cam in a 454 i bought but that snow balled. i had 781 heads but the cost to go to bigger valves was more than the pro comp heads so i went with those. I used the 305cc oval port heads and they needed a little cleanup. i don't remember exactly what. scat internal balanced stroker crank, pro comp h beam rods, probe 18cc dome forged pistons, pro comp air gap intake, 1 inch spacer, holley 950 street hp, some cheaper roller rockers, arp longer rocker studs, arp head and main bolts. moroso oil pan with windage and scraper (i think) should be about 10:1 but i didn't verify head gasket or deck height with builder. i called harold and used voodoo solid flat 30110742 but cut on 112 lsa from 110. 249/257 @.5 and 610/625 ( He said would 112 lsa move power band down some since i'll run ac and overdrive.) It made 630hp at 6300rpm and 615ft lbs at 3800. i am just posting in case someone was looking at a similar combination. this will be for a mostly street chevelle w a 4l80e. if you had specific questions i could try to find an answer.
still gonna be awhile before its on the road.
mr 4 speed and badrad like this.
greensahara is offline
post #2 of 12 (permalink) Old Sep 15th, 19, 7:34 PM
Re: 496 pro comp oval port hp#
Pretty good numbers for procomp stuff. Now you just have see if the castings hold out.
greensahara likes this.
68Chevele is offline
post #3 of 12 (permalink) Old Sep 15th, 19, 8:24 PM Thread Starter
jason
trying to add some pics isn't easier for me. lol
Name:	bbc on dyno.jpg
mr 4 speed likes this.
post #4 of 12 (permalink) Old Sep 15th, 19, 8:30 PM Thread Starter
jason
test
post #5 of 12 (permalink) Old Sep 15th, 19, 8:33 PM Thread Starter
jason
custom big tire engine cradle
post #6 of 12 (permalink) Old Sep 16th, 19, 5:21 AM
jimmyradford
Really impressive numbers.
TC Member # 4431
'07.5 Chevrolet 2500HD-6.6 D-Max
'67 Chevrolet Biscayne- BB 427/TH400/10 bolt (Hers)
'67 Hell Camino-BB 427/TH400/4.10 (His)
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people. And they are more useful in general.
badrad is offline
post #7 of 12 (permalink) Old Sep 16th, 19, 7:26 AM
Allen
Originally Posted by greensahara View Post
test
That's a great looking gray. What specific color is it?
Blown1932 is offline
post #8 of 12 (permalink) Old Sep 16th, 19, 7:36 AM
Great build and results
mr 4 speed is offline
post #9 of 12 (permalink) Old Sep 16th, 19, 11:08 AM
Agree...guides also.
cuisinartvette is offline
post #10 of 12 (permalink) Old Sep 16th, 19, 11:58 AM
Marcus
Nice nrs there are a couple here that used the pro comp ovals and has made great nrs.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #11 of 12 (permalink) Old Sep 16th, 19, 2:38 PM
Rod
Love the cradle! 630 hp? Impressive. Did they give you a dyno sheet? Post it, if you can.
Rmchevelle is offline
post #12 of 12 (permalink) Old Sep 16th, 19, 5:16 PM Thread Starter
jason
i got it off a 2018 nissan altima gun metal gray. using metalux paint and clear.
1N4AL3AP1JC162931
kermitsass and Blown1932 like this.
