rod vise vs soft jaws and proper technique? - Chevelle Tech
post #1 of 9 (permalink) Old Sep 4th, 19, 6:53 PM Thread Starter
Question rod vise vs soft jaws and proper technique?
Is it worth is to get a connecting rod vise vs soft jaws on a 5" vise if I'm going to build an engine once in a blue moon?
Also do you tighten the bolts with the parting line exposed or both sides covered with the clamping surface (after hand tightening, before final torque)?
Just ordered a Mitutoyo dial bore gauge, time to start building this 496! Thanks!
garage specialty is offline
post #2 of 9 (permalink) Old Sep 4th, 19, 7:40 PM
Re: rod vise vs soft jaws and proper technique?
Use a couple of 1-by dimension lumber (1x4's are best) and clamp between. I always leave the parting line visible.
Gary Adrian
Busted Knuckles is offline
post #3 of 9 (permalink) Old Sep 5th, 19, 9:34 AM
I use a couple pieces of wooden outside corner moulding from the local lumber yard. It looks like angle iron, but made from wood. It's 1 1/8" X 1 1/8" and just lay one side on top of the vise, the other side goes between the jaws. No fumbling trying to hold the rod and line up the wood. You can also use tape to hold the pieces to the vice
nitrofox is offline
post #4 of 9 (permalink) Old Sep 5th, 19, 4:04 PM
Mr Bill
The only problem with a regular vice is getting them in it so you can get to both bolts ? Maybe with a huge vice but I just tried it with the 6" one I have here and it wasnt happening. Other than that it would be ok.
When I do them in the rod vise I have them clamped with both the cap and the rod clamped in the vise.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #5 of 9 (permalink) Old Sep 5th, 19, 6:55 PM Thread Starter
i was thinking the same thing. maybe upside down one side at a time?
post #6 of 9 (permalink) Old Sep 5th, 19, 8:23 PM
Mr Bill
Sounds like a pain. The only time you really should need to torque them out of the engine is to check the rod clearance so why not see if your machine shop would let you use their rod vise and check them. I have done it a few times for customers.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 9 (permalink) Old Sep 5th, 19, 8:25 PM
Mr Bill
One other thought . . . do you have a press ? If so just get a couple of scrap pieces of steel or aluminum and use the press to clamp the rod down.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #8 of 9 (permalink) Old Sep 6th, 19, 8:02 AM
Jesse
How do you guys split the caps on rods that have dowel pins? I bought one of those splitters but it won't fit a SBC rod with the bearing in it. I seem to ding a couple bearings taking them apart.
Jesse
6426yy is offline
post #9 of 9 (permalink) Old Sep 6th, 19, 9:35 AM
Mr Bill
I just clamp the cap end in the rod vise and grab the rod and move it back and forth / up and down. You can do the same thing with a regular vise and some soft jaws or actually just a rag. Does not take much to get the caps loose on that type of rod.
You can also just hold the rod and smack the cap on the side with a plastic hammer or old screwdriver handle. Comes right off.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
