rod bearing part number - Chevelle Tech
  • 1 Post By BillK
post #1 of 3 (permalink) Old Aug 31st, 19, 6:47 PM Thread Starter
Im putting together a 454 and the crank is turned .010 on both rods and mains.I put the rod bearings in and im only getting about .001-.0015 of clearance.Im looking to see if theres a bearing that will give me at least another .001 of clearance.Im using the king bearings currently that are .010 and need another .001 to be in tolerance..thanks so much
joes69 is offline
post #2 of 3 (permalink) Old Aug 31st, 19, 9:28 PM
Mr Bill
Re: rod bearing part number
I dont use very many King bearings but Clevite has their CB743HN available in .009 under-size which I believe would give you an extra .001 clearance.
That being said . . . . I have never had any luck checking rod clearances with plastigage. Things just move around too much and I don't see how you can torque the bolts without mashing the plastigage too much. I would take one of your rod and piston assemblies to your machine shop torqued together and have them measure the bearing id with a good bore gauge like the one on a Sunnen Rod Hone.
The other thing you can try is put one rod and piston in and leave it loose. Slide a .002: feeler gauge in between the bearing and the crankshaft and then tighten the rod bolts. If you can pull the .002 feeler gauge out then you know you have at least .002" clearance. This will at least give you an idea whether the plastigage is telling the truth.
Steve R likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 3 (permalink) Old Aug 31st, 19, 10:12 PM Thread Starter
thanks so much for the info.I will try the .002 feeler gauge and see how it works.The bearing does seem pretty tight and normally it moves side to side on the crank journal and these are pretty much locked.The bearings are dry so would add to it not moving as easy as well will just have to do some more checking.I have micrometer and bore gauge that I use as well as the plastigauge.
joes69 is offline
