Holly Carburetor Identification help needed - Chevelle Tech
post #1 of 7 (permalink) Old Aug 28th, 19, 8:19 PM Thread Starter
For my 396/360 HP June car A.I.R., what would be the correct Holly that should be on the car.
Jerry Coia is offline
post #2 of 7 (permalink) Old Aug 28th, 19, 11:00 PM
Levon
Re: Holly Carburetor Identification help needed
What year Jerry?
Good info here:
https://chevellestuff.net/home/
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 7 (permalink) Old Aug 29th, 19, 1:46 AM
It's a '66, Levon.
David
davewho1 is offline
post #4 of 7 (permalink) Old Aug 29th, 19, 1:49 AM
Vern
Four speed or power glide?
suntreemcanic is offline
post #5 of 7 (permalink) Old Aug 29th, 19, 1:56 AM
Can you post the numbers on the forward facing area of drivers side of the carbs air horn?
Steve R
Steve R is offline
post #6 of 7 (permalink) Old Nov 29th, 19, 3:00 PM
& Administrator
Here's some info he sent me:
1. I have a 6/23/66 396/360hp with an EJ engine code. I believe this indicates a California car with A.I.R./HP
2. I'm trying to locate the correct carburetor. I believe I need a 4160 #3892339 List 3609.
3. I found one but the letter code on the carb is "EY".
4. Can I use this carburetor without the smog setup?
5. Also has a date code of 502. The seller states it is dated the second week of October 1965.
6. Is there a place where I can get the date codes for these carburetors?
I know these are a lot of questions, but I'm just trying to get the car correct as all other parts are matching and original. Love to find a smog setup, but I think that's near impossible!
Mike is offline
post #7 of 7 (permalink) Old Nov 29th, 19, 5:17 PM Thread Starter
Its a 4-speed car
