trw 7053p and 188 heads - Chevelle Tech
  • 1 Post By 71454Chevelle
post #1 of 6 (permalink) Old Aug 19th, 19, 5:14 PM Thread Starter
I bought a 454 engine for 800 dollars complete this last weekend.I figured the heads would be close to what I paid for whole engine and its came with a team g intake roller rockers etc.It had a 7053p trw piston in it and these a for a closed champer head.Has anyone ran this combo before and if so whats the compression and any problems.I didn't see where anything was hitting and they used a normal felpro gasket so nothing thick to get clearance..Would love opinions on it...thanks in advance
joes69 is offline
post #2 of 6 (permalink) Old Aug 20th, 19, 12:17 AM
Re: trw 7053p and 188 heads
Trw 7053 pistons are the same as Speed Pro 2349's or LS6 replacement. If you use a closed chamber head the compression will be a high as 11 to 1. You may need race gas at that ratio.
68Chevele is offline
post #3 of 6 (permalink) Old Aug 20th, 19, 4:59 AM Thread Starter
I was actually going to put the open chamber 188s back on it.I was curious if anyone has run something like this and what kind of compression they had.I think the 118s are somewhere around 119cc
joes69 is offline
post #4 of 6 (permalink) Old Aug 20th, 19, 5:13 AM
jimmyradford
That piston and head combo is about 10:1 compression. Basically the OTC LS-6 crate engine.
TC Member # 4431
'16 GMC Denali XL- 6.2L's are sweet
'07.5 Chevrolet 2500HD-6.6 D-Max
'07.5 Chevrolet Suburban
'67 Chevrolet Biscayne- SS427 L-36/TH400 (Hers)
'67 Hell Camino-BB 427/TH400 (His)
'66 300 Deluxe 2 door-230/PG
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is offline
post #5 of 6 (permalink) Old Aug 20th, 19, 8:20 AM
Darren
Joe, I ran that piston with a set or 049 open chamber oval ports. No issues.
mr 4 speed likes this.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525+++ rwhp
71454Chevelle is offline
post #6 of 6 (permalink) Old Aug 20th, 19, 4:23 PM Thread Starter
thanks so much really appreciate it.e85 and 9psi of boost should be perfect for this
joes69 is offline
