Spark plug recomendation? - Chevelle Tech
 7Likes
  • 1 Post By sampoerna415
  • 2 Post By DUTCH MAX HEADWORK
  • 1 Post By scottscheffer55
  • 1 Post By Ken Hayes
post #1 of 9 (permalink) Old Aug 18th, 19, 9:16 PM Thread Starter
Scott Scheffer
Hi all,
I have a gen 1 350 with flat top pistons, 062 Vortec heads, and roller cam and lifters. I'm finishing up the build and wondering if I should use the plugs recommended for those heads. Do the flat top pistons mandate a different type of plug?
Thanks a lot in advance for any information!
scottscheffer55 is offline
post #2 of 9 (permalink) Old Aug 18th, 19, 10:42 PM
Re: Spark plug recomendation?
You need to use the plug type that fit the heads.
oldcutlass is offline
post #3 of 9 (permalink) Old Aug 18th, 19, 10:55 PM
Rame
reach is important, I think you need about 3/4 on those heads maybe, you need to fill in the blanks from there, what you are using it for etc? Probably won't hurt to start with these though R44LTS
sampoerna415 is offline
post #4 of 9 (permalink) Old Aug 18th, 19, 10:56 PM
Al
ACDelco R44LTS would be a good start.
davewho1 and sampoerna415 like this.
DUTCH MAX HEADWORK is offline
post #5 of 9 (permalink) Old Aug 18th, 19, 10:59 PM
Al
I swear I'm not a Parrot.
post #6 of 9 (permalink) Old Aug 18th, 19, 11:46 PM Thread Starter
Scott Scheffer
Thank you all! The car won't be driven much. Once in a while on a weekend to a car show or out for burgers. I'll start with those.
This forum is freaking awesome!
davewho1 likes this.
post #7 of 9 (permalink) Old Aug 19th, 19, 12:04 AM
Al
If you were running the same heads and combination before post some photos of the plugs you were running.
If this is a new installation then that won't help us, but the R44LTS are a good start and won't set you back to much.
Run those plugs a few days then pull a couple easy ones and see how they are running. If you don't trust your plug reading skills, post some pictures here and we'll take a look at them for you.
post #8 of 9 (permalink) Old Aug 19th, 19, 1:16 AM
Ken
I'm runnin same motor and heads....I use R44LTS in it and it runs great.
TODAY IS THE OLDEST YOU'VE EVER BEEN, YET THE YOUNGEST YOU'LL EVER BE, SO ENJOY THIS DAY WHILE IT LASTS.
Ken Hayes is offline
post #9 of 9 (permalink) Old Aug 19th, 19, 12:10 PM
Or an NGK YR5 if you prefer higher quality than Chinese. ( all AC are Chinese now)
