70 ls5 carb - Chevelle Tech
post #1 of 16 (permalink) Old Aug 10th, 19, 6:23 PM Thread Starter
70 ls5 carb
Does anybody know the correct carb part number for a 70 LS5 car,uto with AC
Thanks for any help
Remmag is offline
post #2 of 16 (permalink) Old Aug 10th, 19, 6:23 PM Thread Starter
Damn spell check,that was auto with ac
Remmag is offline
post #3 of 16 (permalink) Old Aug 10th, 19, 6:52 PM
Re: 70 ls5 carb
7040204
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Check out
on Facebook
Vintage Musclecar is offline
post #4 of 16 (permalink) Old Aug 10th, 19, 7:16 PM Thread Starter
Thank you sir
Remmag is offline
post #5 of 16 (permalink) Old Aug 10th, 19, 10:14 PM
Re: 70 ls5 carb
1970 LS-5--Auto= 7040204
1970 LS-5--M-22= 7040205
You can also use a 7040202, Thats what I have on my 1970 Sta. Wgn. 468 driver.
My one owner -M-22 has the "05 " on it. You would have a FAIR chance on finding a "04 ". The 05s are getting hard to come by.
A restored 04 or an 05, Will be pricey.
Robinls5 is offline
post #6 of 16 (permalink) Old Aug 10th, 19, 10:22 PM Thread Starter
Thanks for the info
I plan on getting me one over the winter
I am trying to get everything correct in my car
Thanks for the info
Remmag is offline
post #7 of 16 (permalink) Old Aug 10th, 19, 10:35 PM Thread Starter
If I could ask one other question.
My car has factory case iron manifold with replacement q jet set op for divorced choke
The rod and the part that bolts to the manifold is gone
I have found where I can get one but my question is
What heats the spring up to work the choke
Is it just heat from the intake or is there something else I am missing
Thanks for the help
Remmag is offline
post #8 of 16 (permalink) Old Aug 10th, 19, 10:44 PM
Randy
Re: 70 ls5 carb
There is a heat passage in the intake that runs exhaust from one side head to the other. That's where the heat comes from to work that coil spring. The heat riser on the passenger side exhaust closes when its cold and directs the exhaust thru the intake.
redrocket1953 is offline
post #9 of 16 (permalink) Old Aug 10th, 19, 10:45 PM
The manifold heats the choke stove. I have a 202 I do not want. This morning I saw a 205 for 30 bucks on local Craigslist here, I think it’s gone, I’m looking..
67ss4spd is offline
post #10 of 16 (permalink) Old Aug 10th, 19, 10:51 PM Thread Starter
Ok dumb questions but please bear with me
Is the heat passage in the intake actually internal
Is there a hole in the intake where the heat escapes to let the heat go to the spring or does it heat the metal
Is the heat riser you are talking about the piece that sets between the exhaust manifold and the exhaust pipe
I do remember seeing that there
My car isn't here to look at or take pics of
In the body shop right now
Thank you all for your help
Remmag is offline
post #11 of 16 (permalink) Old Aug 10th, 19, 11:03 PM Thread Starter
I count two pics of the carb but can't attach ,I'm not sure why
Remmag is offline
post #12 of 16 (permalink) Old Aug 10th, 19, 11:51 PM
leo
Re: 70 ls5 carb
It heats the manifold under the choke spring, there should be a cover for the choke spring to keep the heat in, good luck!!
If you want to try to find an already to install carb, I recommend www.customrebuiltcarbs.com They can probably find and provide you with the correct one, good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #13 of 16 (permalink) Old Aug 11th, 19, 9:51 AM
Re: 70 ls5 carb
Originally Posted by Remmag View Post
Thanks for the info
Thanks for the info
Are you looking for a dated one?
If so, what's the build date of your car?
Check out
on Facebook
post #14 of 16 (permalink) Old Aug 11th, 19, 10:46 AM Thread Starter
I am looking for one
Build date is first week of may 70
Remmag is offline
post #15 of 16 (permalink) Old Aug 11th, 19, 4:04 PM
Re: 70 ls5 carb
Here is how the choke stove works. Your right side exhaust manifold has a " HEAT RISER " Its a hunk of iron with a butterfly and a spring. ( it is bolted between the R. Side exhaust manifold and the head pipe)When it is KOLD the butterfly is closed, This forces the engine exhaust from the right side to go through the exhaust crossover that is built in to the stock cast iron intake.
Now with all of this going on the exhaust heat ( going through the intake manifold) passing under and around the " COIL SPRING " inside the choke stove. As the coil spring get warm to hot it expands and unwinds, When this happens the coil spring inside the choke stove starts to MOVE the rod.
The rod that is being MOVED is attached to the Carb. butterflys.
When the butterfly is close or (cold engine). A closed butterfly will along with vacuum suck a lot of raw gasoline into the Q-Jet to keep a KOLD engine running.
When the engine gets warm enough to have the fuel " ATOMIZE with Oxygen "........... SCHZAAAAM the engine runs wonderful. YES a lot of parts to call it an automatic choke....... In the 30s--40s-50s you would find a knob under the dash, What did it do. This knob had a cable that was attached to the Carb. butterfly. This was a manual choke. With a manual choke you had to PUSH the knob "IN" after the engine was warm, If you forgot to do this the FREEKEN ENGINE would DRINK gas and not run for $H!t,,, you would get P!$$ed because you forgot to push the CHOKE KNOB in........
This message is about choking the engine not your chic---....
427L88 likes this.
Robinls5 is offline
