Clean spark plug, oil on threads - Chevelle Tech
 6Likes
  • 1 Post By hjdca
  • 1 Post By 68elky396
  • 2 Post By GuysMonteSS
  • 1 Post By 427L88
post #1 of 11 (permalink) Old Jul 30th, 19, 10:03 AM Thread Starter
I'm reaching out to the team to get some thoughts on my recent findings. I have about 550 miles on my newly rebuilt 396. I was doing some plug readings the other day, just to find that the #2 spark plug has oil on the threaded portion. The plug is burning clean and indicated it was slightly lean, so I corrected that by fattening up the jets by two sizes. Also, the ground strap indicated that the plug was too cold. What would cause the oil on the threads of the plug? I'm running 10w30 royal purple break in oil.
68elky396 is offline
post #2 of 11 (permalink) Old Jul 30th, 19, 10:53 AM
Harry
Re: Clean spark plug, oil on threads
Your intake manifold may have loosened slightly during break-in and might be sucking some oil from the lifter valley and throwing it on the plugs. Also, valve cover gasket might be leaking a little bit. I would tighten both the intake manifold and the valve cover.
Also, are you running a correct PCV valve for your cam ? if not, you may be getting some light crank pressure that is pushing some oil out at WOT, which is hard to figure out at idle.
Cam likes this.
Harry
hjdca is offline
post #3 of 11 (permalink) Old Jul 30th, 19, 11:34 AM Thread Starter
Those are all good possibilities that I had not thought of. I will be retorquing the manifold and checking the valve covers as well. As for the PCV valve being correct, I'm not sure. The one that's installed is for the stock configuration for the L34 350HP. The cam profile has been changed and I get about 17 inches of vacuum at idle. Thanks for your input!
post #4 of 11 (permalink) Old Jul 30th, 19, 2:14 PM
As Harry indicates, slightly leaky VC gaskets can do this.
post #5 of 11 (permalink) Old Jul 31st, 19, 3:47 PM Thread Starter
I'll have some time to spend on my engine this weekend and will let you guys know what I find out.
post #6 of 11 (permalink) Old Aug 7th, 19, 8:19 PM Thread Starter
Here's the update on my 396/402. This thread was addressing the oil on my #2 sparkplug threads. I checked for leaky VC gasket and loose intake bolts, no leaks at valve cover and no loose intake bolts. I did however notice that at idle the PCV valve is rattling and not staying closed. The engine is producing around 17 inches of vacuum at idle. Should I buy another valve for this particular engine, or should I buy a valve that has a different rating? Suggestions or part numbers would be appreciated. Steve
427L88 likes this.
post #7 of 11 (permalink) Old Aug 8th, 19, 7:38 AM
Guy
If you don't mind spending a bit of $$$$$$ there is the ME Wagner adjustable PCV valve;
Dual Flow Adjustable PCV Valve ? M/E Wagner Performance Products
It is a very nice piece and you can adjust it to your vacuum.
Guy
Cam and boyd66k20 like this.
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #8 of 11 (permalink) Old Aug 8th, 19, 2:55 PM Thread Starter
Thanks Guy, I don't mind spending big money when I have to, but I'm not willing to part with that much money for a PCV valve. I'm going to have to search for a different pcv valve that operates at lower vacuum. Maybe the one I have went bad?
427L88 likes this.
post #9 of 11 (permalink) Old Aug 8th, 19, 3:15 PM
PCV are not created equally. Run a search in this forum for the right part number as I cant remember if mine has an "A" or an "F" on the bottom, But it will make a diff and should NOT rattle at idle. Beleive I asked for one for a 1969 Corvette 427/435 HP application.
boyd66k20 likes this.
post #10 of 11 (permalink) Old Aug 9th, 19, 3:40 PM Thread Starter
Thanks for chiming in 427,
I took your advice and searched for a PCV valve for a 427/435hp and it turns out that I have the same one in there now that I just bought this morning. There is an F stamped on the bottom of the valve. It still slightly rattles at idle. Is that normal? Here is a photo of my 396/402. It's not as awesome as some of your engines I see on this site, but I built it along with the rest of the car, and I'm pretty happy with it. Thinking of changing the valve covers to orange.
post #11 of 11 (permalink) Old Dec 7th, 19, 4:44 PM Thread Starter
Here is the latest on this post. I recently pulled the intake manifold to swap it out for the original intake. I looked into the intake ports of the heads and saw some oil build up on the valves. The PCV is still rattling at idle and I believe that the PCV is consuming some of my oil because it is using more oil than it should. Not sure at this point what I'm going to do. I have many things with this vehicle that I am trying to address so I can just enjoy it for a change. Thanks for all the advice.
