Help identifying these pistons if possible - Chevelle Tech
post #1 of 20 (permalink) Old Jul 19th, 19, 3:14 PM Thread Starter
I just bought an engine for my restoration project 65 SS, and I was hoping someone may be able to shed some light on what these pistons that are in the engine are, thanks.
Dan1965 is offline
post #2 of 20 (permalink) Old Jul 19th, 19, 3:16 PM Thread Starter
I suppose it may help to tell people what the engine is. It is a 454 standard bore Mark IV
Dan1965 is offline
post #3 of 20 (permalink) Old Jul 19th, 19, 3:48 PM
& Administrator
Re: Help identifying these pistons if possible
Looks like a 71 w/Sp. H/Per. (454) standard bore
Is there any code on the front stamp pad?
Mike is offline
post #4 of 20 (permalink) Old Jul 19th, 19, 4:31 PM Thread Starter
On the block you mean Mike? If so the block casting # is 14015445. I’m trying to figure out what the compression ratio may be with those pistons. The heads appear to be nice heads too their casting # is 14096188. I got a great deal on this engine which I had no plans to buy yet as I am just starting the restoration and had no engine or trans with the car when I bought it.
Dan1965 is offline
post #5 of 20 (permalink) Old Jul 19th, 19, 4:36 PM
& Administrator
Check the B or C location on the block as shown for the engine ID.
Also - https://www.chevelles.com/forums/34-...ston-help.html
Mike is offline
post #6 of 20 (permalink) Old Jul 19th, 19, 4:40 PM Thread Starter
This is what info I have.
14015445...454.......78-90...2 or 4 bolt
And I have pulled the pan and it is a 4 bolt main block, here are the heads that are on it as well
14096188...70-71...rect...OPEN...454 service replacement, also used on later Mark IV LS-6, LS-7 and 454 HO crate motors, 116cc chamber
I believe that 116cc chamber size is incorrect, I believe they are 118cc chambers
Dan1965 is offline
post #7 of 20 (permalink) Old Jul 19th, 19, 4:44 PM Thread Starter
Ok I’ll check those B and C locations for the ID #, I won’t be back to it until the beginning of the week. That stamping # on the top of the piston 6262975, is there any way of identifying the pistons with that #?
Dan1965 is offline
post #8 of 20 (permalink) Old Jul 19th, 19, 4:49 PM
& Administrator
Actual part # is 6262976 if you care to look them up.
I added some info to my previous post so incase you missed the link - https://www.chevelles.com/forums/34-...ston-help.html
Mike is offline
post #9 of 20 (permalink) Old Jul 19th, 19, 5:04 PM
Mike, I zoomed in on the piston number. The last digit is most definitely a 5.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #10 of 20 (permalink) Old Jul 19th, 19, 6:48 PM Thread Starter
Yes it is Paul, this may be a better shot
Dan1965 is offline
post #11 of 20 (permalink) Old Jul 19th, 19, 6:55 PM Thread Starter
Thanks for the info guys, I’m really going to like this forum, I can see that already
Dan1965 is offline
post #12 of 20 (permalink) Old Jul 19th, 19, 7:23 PM
That is what the pistons are. GM rated the 71 LS6 at 425 hp with the 074 heads. They had app. 118 cc. and the compression ratio was 9 to 1. The 188 will have a couple more cc. I would think your compression will be in the 8.6 -8.8 range.
sleeper is offline
post #13 of 20 (permalink) Old Jul 19th, 19, 8:46 PM
I believe the number Mike posted is for a LS6 piston.
Before Tonawanda went to the Gen5 engine, boring and honing big blocks rarely produced the bores they needed and they had pistons + or - for every bore size. I'm thinking this 6262975 stamped piston may be a slight size variant of the listed piston with the 6262976 part number.
How may I help you?
1999 Trans Am-500hp
post #14 of 20 (permalink) Old Jul 19th, 19, 10:05 PM
Jon N.
Much the same as casting numbers on blocks, heads and such aren't the part number that they are sold under by a manufacturer or dealer, pistons and camshaft numbers often are not sold under the numbers cast or stamped into them.
Some times they are only one digit apart, sometimes the complete number is different.
Jon N.
dyno jonn is offline
post #15 of 20 (permalink) Old Jul 23rd, 19, 9:40 PM Thread Starter
Mike here is the ID number from the block C576159
Dan1965 is offline
