Help identifying these pistons if possible - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old Aug 6th, 19, 5:40 PM Thread Starter
Ok well it looks like if Sleeper is correct on the compression ratio with this combo on the engine. It should be a good pump gas engine. I would think it should make good horsepower with a nice cam say 240 duration .600 lift, it has roller rockers on the heads now so I may not have to put a whole lot of $$$ into it to make a nice engine for my 65 resto mod
Dan1965 is offline
post #17 of 20 (permalink) Old Aug 6th, 19, 6:43 PM
Greg
Re: Help identifying these pistons if possible
The first pic looks like my 10.25 comp closed chamber's
2cool is offline
post #18 of 20 (permalink) Old Aug 31st, 19, 11:10 AM Thread Starter
I’ve found a set of what the seller says are LS-6 pistons in good shape. Can anybody shed any light as to what these may be compression wise with a 118cc chamber head.
Dan1965 is offline
post #19 of 20 (permalink) Old Nov 13th, 19, 1:00 PM Thread Starter
Ok I finally found some info on these pistons in the How to Hot Rod Chevy Big Blocks book, turns out they are .030” over size bore forged and should be 9:1 compression so a lot of what you guys posted here was damned close. I’ll put the thumbnail here for anyone else who may ever need the info.
Dan1965 is offline
post #20 of 20 (permalink) Old Nov 16th, 19, 8:43 PM
Bill R
Originally Posted by dyno jonn View Post
Much the same as casting numbers on blocks, heads and such aren't the part number that they are sold under by a manufacturer or dealer, pistons and camshaft numbers often are not sold under the numbers cast or stamped into them.
Some times they are only one digit apart, sometimes the complete number is different.
This is correct. The casting/forging number is not necessarily the part number. The automobile manufacturer may have more than one supplier for a particular part. The forging number on this piston identifies the details of that part, but a piston supplied by Sealed Power will have a different part number for the same piston sourced by TRW, Dana Corp., etc., etc.
LeoP likes this.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
