BBC Intake Manifold match up to heads - Chevelle Tech
  • 1 Post By oldcutlass
post #1 of 13 (permalink) Old Jul 16th, 19, 3:42 PM Thread Starter
Jules
I need a quick lesson on the intake side of Iron heads matching up with the intake manifold.
I have a 1997 NOS 502 HO, without the original intake. The intake offered to me by the local Performance shop is the 7163 Edlebrock, the cooling ports in the center don't make sense to me, hoping someone can explain the 'why' and maybe I got the wrong intake?
The gasket covers the two odd shaped areas, top and bottom, and a small diameter hole in the center of the port am I to guess I need to cut this to match the square port? The top is covered only by the gasket once the intake is put in place. ( is it enough to block 15psi of coolant?) Sorry for the babbling talk, hope it makes sense.
Pictures attached, see the area marked up in red.
Thanks!
Best regards
Jules
Name:	502 HO 1997  block cast no 10237300.jpg
ID:	598420   Click image for larger version
Name:	top view 7163.jpg
ID:	598422   Click image for larger version
Name:	port view left.jpg
ID:	598424   Click image for larger version
Name:	Gasket dryfit placement.jpg
Name:	intake dry fit.jpg
mymalibubu72 is offline
post #2 of 13 (permalink) Old Jul 16th, 19, 4:10 PM
Re: BBC Intake Manifold match up to heads
Don't worry about the 2 odd shaped areas casted around the port. Do not open the crossover port, in fact the gasket kit comes with 2 metal plates you should use to block it off. Read the installation instructions carefully, get a can of Gasgacinch, and a tube of the Right Stuff gasket maker for the front and rear walls. Throw away the rubber end seals.
427L88 likes this.
oldcutlass is online now
post #3 of 13 (permalink) Old Jul 16th, 19, 4:22 PM
Harry
That middle square hole with the canyons around it is for heating up the intake manifold on startup. It allows the warm air to rise up and heat up the intake manifold. This is to allow the car to warm up faster. A lot of aftermarket manifolds do not have holes for this warm up. Take a look at my RPM Air Gap manifold, you will see that those middle holes with the canyons around it are totally ignored. All those pictures you posted look normal to me. Here are some pics from when I installed my air gap manifold that can help you. With the air gap, you can even see the "canyons" on the head after installation. The canyons are bigger than the gasket and even the air gap manifold.
Here you can see the "canyon" not covered by the gasket nor the air gap manifold. This is normal.
Harry
hjdca is offline
post #4 of 13 (permalink) Old Jul 16th, 19, 4:27 PM
Ya, I always block the heat passages off on BB heads. Funny, I have 2 of the factory 163 intakes from the newer BBC's ported one and the other is on the shelf. They were the same for 454HO and 502HO. Still one of the best dual plane intakes out there.
68Chevele is offline
post #5 of 13 (permalink) Old Jul 16th, 19, 5:16 PM
Gary
just so you're clear those are heat riser ports and they intersect with the exhaust port. on factory vehicles this era exhaust flowed from one side to the other to quickly heat the intake for quicker warm ups in cold weather. a thermostatic spring in the heat riser valve on the right exh manifold closed when cold and forced exh to flow from one side to the other and gradually opened during warm up where as cross flow of the exhaust stopped. the heated manifold is also important to divorced choke operation. now after I said all that you should block the heat passages unless youre driving the car in very cold conditions. either use the thin stainless block off plates that come with factory replacement gaskets or cut your own out of .030 material and using hi temp rtv glue them on the head side of the gasket. use the gasket for a template to cut the plates.
gnicholson is offline
post #6 of 13 (permalink) Old Jul 16th, 19, 5:21 PM Thread Starter
Jules
I will look into this kit, I didn't get any metal plates. Got the Gasgacinch 9300 and Dynatex blue RTV silicone (chuck the rubber). Thanks!
post #7 of 13 (permalink) Old Jul 16th, 19, 5:26 PM Thread Starter
Jules
Awesome, thank you for the clarification and helping a newbie! I was a little embarrassed to ask but everyone here is more than generous and very kind.
post #8 of 13 (permalink) Old Jul 16th, 19, 8:00 PM Thread Starter
Jules
These are the metal plates to block the heat riser ports I'm guessing. Thanks again!
MRG108, BB CHEVY INTAKE GASKET - Performance Unlimited
Name:	Mr Gasket BBC kit.jpg
post #9 of 13 (permalink) Old Jul 16th, 19, 8:41 PM
Mr Bill
I have never heard of that brand blue silicon but I would use nothing but either the "Right Stuff" or Permatex Ultra Grey or Ultra Black on the end rails. You can also put a very light bead around the water ports on the heads. You really should not need Gasgacinch on a Chevy intake gasket.
I think this is the gasket you have ? That will work fine
https://www.jegs.com/i/Fel-Pro/375/1211/10002/-1
Thats my 2 cents
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 13 (permalink) Old Jul 17th, 19, 7:48 AM Thread Starter
Jules
Thats my 2 cents
This is the one that came as a kit with the intake from Jegs... https://www.jegs.com/i/JEGS/555/210101/10002/-1
post #11 of 13 (permalink) Old Jul 17th, 19, 8:26 AM
Mr Bill
That will be ok. I prefer Fel Pro but the Mr Gasket ones with the printed seal are good too.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #12 of 13 (permalink) Old Jul 17th, 19, 10:13 AM
Yes Jules, those are the plates in the pic you posted. Block off plates.
post #13 of 13 (permalink) Old Jul 19th, 19, 2:32 AM
...The gasket covers the two odd shaped areas, top and bottom, a... is it enough to block 15psi of coolant?
Jules,
Didn't see it mentioned, but those odd-shaped "canyons" are NOT coolant passages... they are just dead space ( they aren't that deep)...
As mentioned, the center is the exhaust cross-over...
TC #1366
Sold
Sold
1966_L78 is offline
