#5 Running Hot - Chevelle Tech
post #1 of 17 (permalink) Old Jul 14th, 19, 1:24 PM Thread Starter
#5 Running Hot
I have a Gen1 383 with Dart SHP 200 Aluminum heads, Comp 274 Extreme cam, Performer RPM intake.
I'm getting #5 running hot/lean, about 125 degrees F hotter than my other cylinders when running a temperature gun on the header. I get mild fluctuations in the vacuum at idle and it's a little rough (not related to cam).
I've done the carb spray check for a vacuum leak. No difference. Compression checks all came back in the same range.
Anything else you could recommend checking for a hot/lean cylinder? thanks!
scottpreston is offline
post #2 of 17 (permalink) Old Jul 14th, 19, 2:16 PM
I was going to say and exahust valve not closing properly. Have you checked your valve lash again after noticing this condition
Ironman711 is offline
post #3 of 17 (permalink) Old Jul 14th, 19, 2:18 PM
And how close are the compression readings
post #4 of 17 (permalink) Old Jul 14th, 19, 3:32 PM Thread Starter
Re: #5 Running Hot
Compression close within 5psi on all cylinders. Just reset valve lash last fall when I installed new rockers. I'll look again at the valve lash, but wouldn't an exhaust valve not closing cause the left bank to run rich? i don't see any difference in the exhaust between the two, right bank is steady 12.5 at idle.
post #5 of 17 (permalink) Old Jul 14th, 19, 4:44 PM
Harry
Re: #5 Running Hot
Timing too retarded maybe ? Gas burning in header maybe ? Maybe try increasing the timing at idle 5 or 10 deg. and see what happens ? maybe that cylinder will clean up ?
Harry
hjdca is offline
post #6 of 17 (permalink) Old Jul 14th, 19, 6:21 PM
Re: #5 Running Hot
Valve in liftr not operating properly, not keeping valve set correctly.
I had a friend's chevelle years ago, brand new rebuilt engine my pal installed, would read good compression on test, fire it up, number 8 went away. Lifter for the intake on th number 8 was pumping past valve settng, holding intake valve open when oil pressure was raised when engine ran. Replaced brand new lifter, problem solved.
Recheck valve settings first, E-O, I-C method only.
1966Chev likes this.
Dave Ray is offline
post #7 of 17 (permalink) Old Jul 14th, 19, 10:51 PM
The lifter could be failing especially if it's sat for some time
post #8 of 17 (permalink) Old Jul 14th, 19, 11:27 PM
Levon
Re: #5 Running Hot
Intake gasket leak on that cylinder??????????????
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #9 of 17 (permalink) Old Jul 15th, 19, 7:12 PM Thread Starter
Re: #5 Running Hot
Lifters were just replaced <500 miles ago, my first thought was Intake Gasket leak. Seems to be conflicting installation, some say to use Gasgacinch sealant, some say to use RTV. I didn't use RTV on the intake side, in fact the gaskets I use already had a bead meant to seal them.
post #10 of 17 (permalink) Old Jul 16th, 19, 12:31 AM
Re: #5 Running Hot
Where does the vacuum for the power booster come from? #5 runner?
Schurkey is offline
post #11 of 17 (permalink) Old Jul 16th, 19, 12:48 AM
Re: #5 Running Hot
Actually, the sealer on the intake manifold gaskets, you have the end sealing covered, RTV works in place of the rubber end seals.
That stuff around every intake port and water port is a compound used not only on gaskets, but as a gasket for metal to metal junctions, metal to rubber, etc.
The motorcycle industry uses a sealer that is the same as the beads, called Three-Bond, and is anything from 4, 1104, 1194, and other levels of sealer. They use it between engine cases that have no gasket but the T-B compound, on gaskets, and just about anything except exhaust heat areas. Motorcycle manufacturers have it as well, Honda Bond, and the number, Kawasaki Bond, Yama-Bond, Suzuki seal, and on.
I use it to seal rubber intake manifolds on bike engines, to the aluminum head flanges,
I don't know what it is called in the automotive industry, but it is great stuff, and different colors on different gasket sets.
Key is to get the surfaces clean, clean, CLEAN, and install, let set up for a couple of hours before use. Cleans up easily with acetone or lacquer thinner, and it stays a touch wet.
Dave Ray is offline
post #12 of 17 (permalink) Old Jul 16th, 19, 9:26 AM Thread Starter
Re: #5 Running Hot
No actually I have a Holley 4160, the Brake Booster comes off the Carb near the rear. The manifold in the rear has a plug.
post #13 of 17 (permalink) Old Jul 16th, 19, 10:47 AM
Did you recheck the valve lash and how much do you run the motor or how long has it sat up. And if it sat up or wasn't run very much. Bc if you set the valve lash and then the motor sat for a period of time with the spring pressure on the lifters its possible even if it was done 500 miles ago that it could be bad. Over winter when my motors are not being run I loosen the rockers so there is no pressure on my lifters just for this reason. And I've seen brand new comp cam roller lifters be stuck now as soon as we called them about it they made it good on there end. They set another set no questions asked
post #14 of 17 (permalink) Old Jul 16th, 19, 11:17 AM
Re: #5 Running Hot
an intake leak would also be pulling oil mist from the galley. So #5 plug would look sooty.
post #15 of 17 (permalink) Old Jul 16th, 19, 2:48 PM
Re: #5 Running Hot
Not if the leak was only at the top of the port/gasket, Gene.
Dave Ray is offline
